Toggle navigation
Categories
Discussions
About Us
Privacy Policy
Sign In
Home
Repetier-Firmware
Tips & Tricks
replace the new image use ssh
user
April 2021
edited April 2021
in
Tips & Tricks
Hi! I want upgrade my an raspberrypi from the new image v25 use ssh. Can i do it? At the moment i has installed an older image.
Repetier
April 2021
You need to write the image to sd card so you can not be logged in. But you can copy your server configuration/files by backing up /var/lib/Repetier-Server or using our Repetier-Server Monitor to create the backup and upload it later.
Sign In
or
Register
to comment.
