How to add this screen to repitier firmware 1.04?
Hello
I used RUMBA v1.1 a few years with Prusa 3d printer & screen (see pic). Now I finish building of Hbot and after flashing hbot firmware I lost access to screen. Looks like I forgot name of it, I didn't flashed this controller since 2015.
Screen
https://3dtoday.ru/upload/posts/main/M9riArkQH7rXk5UmrWru9s4GgpZ01nx7zv2TcexNqKZyfpceXR.jpg
https://3dtoday.ru/upload/posts/main/c7EhnOgDXZX1wL3aQT5kNOzM0n2he31TUAZqRTJVt42dMCQ3mv.jpg
I tried this screens but still no access to screen
https://3dtoday.ru/upload/posts/main/iV4hbIyeqoVudyeyhZW933VvEijhhvaXf7eUe1CMJAk0EsGOcL.jpg
https://3dtoday.ru/upload/posts/main/GaCJQVqTKxBqkKobeMsfLVMfsPw5XQp6ffFSzPb7Qo0fe72vU9.jpg
May be I have to make changes in configuration.h file ?
Thank you in advance.
  • Looks like a 20x4 character display so first variant is correct. No extra config required. But make sure you map the 2 flat cables correctly and also the rotation. Is not on all as you think. So check some image son internet and watch where the red marked cable is positioned.
  • No, second name is right choice, but I had encountered with  very strange problem, when I unchecked other languages except english, arduino ide did compilation and started writing but after a while it reported about connection error. It took for me 2 days to understand that problem with unchecked languages.
    that how it was looks like
    Reading | ################################################## | 100% 0.01s
    avrdude: Device signature = 0x1e9801 (probably m2560)
    avrdude: reading input file "C:\Users\SSD\AppData\Local\Temp\arduino_build_171813/Repetier.ino.hex"
    avrdude: writing flash (113348 bytes):
    Writing | #####avrdude: stk500v2_ReceiveMessage(): timeout
    avrdude: stk500v2_getsync(): timeout communicating with programmer
    An error occurred while uploading the sketch
