Show ADC values
how can i output ADC values ​​to repeater host in repetier firmware dev 2?
  • We do not really assume ADC as input for temperatures, so we have no option to show them.
    Assuming you are using IO_TEMPERATURE_TABLE to convert them to temperatures you can add a output in
    float IOTemperatureTable::interpolateNTC(int value, fast8_t num, const short* temptable) {
    where value is the computed analog value. This is a smoothed value according to your analog conversion rules. But you can output it
    Com::printFLN(PSTR("TempRaw:"), static_cast<int32_t>(value));
    You see then in console a lot of outputs depending on timing in temperature handling.
