Colido Compact Extruder Head Temperature
My extruder head won't heat up.  It worked the last time I used it.  Everything else seem
  • Is colido using repetier-firmware? Check console log for error messages when you heat. Extruder often suffer a cable break sooner or later from all the moves so that would be one possible reason.
  • Okay.  Will do. Thank you.
