extruder direction reversed
On my davinci 2.0, if I want to unload filament I need to use the load function. Likewise to load I need to used unload. I believe this is relating to printing issues I am having. How do I correct this. I am using the latest firmware.
  • Is extrusion working in correct direction? If not rotate motor connector 180° or change invert direction setting in configuration.h for that extruder.
