strange infinite lines extending off model
This happens when I slice a model in cura externally sometimes and import the gcode into repetier. It doesnt happen in printrun or any other gcode software I've tried except repetier. It also doesnt happen in all models, it seems like maybe it happens a lot when a model isnt watertight, but this one is, definitely I triple checked it was fine and it still had the lines. It also doesnt happen on the same model when i slice it internally. I'm using "arc welder" in cura to optimize the gcode maybe that's why?
Not sure what's going on, but it's unprintable in repetier becuase of this it shows the estimated time will be 8 hours so I assume it will actually try to print these lines.
repetier 2.1.6
ok i found it... its on layer 12. g3 x35.685 x37.693 i-108705.468 j-58650.253 e11.34829
Why would only repetier read it that way and pronterface its fine?
I guess I can just delete it?
