BL touch doen't stop (RAMPs 1.6)
Hi guys !
I need your help today about mu BL touch configuration. I watched and read a lot of tutorial about it, but I can’t find the solution for my problem.
When I’m using it, the BL touch can be triggered but won’t stop the Z axis movement, so it can crash into the bed. I have tried a lot of things, but as I’m not good at programming you might see something I didn’t see.
So first, I am using a BL touch, a RAMPs 1.6 and Repetier (and I only used the Repetier Firmware tool)
The BL touch is connected on the Zmin (black and white wires) and on the digital pin 11 and on the 5V and GND of AUX-1 (the one on the SERVOS don’t work because my VCC - 5V doesn’t work, it turns the RAMPs off)
When I turn on the printer the BL touch is running (going up, down then up) and stay like this waiting for instructions.
When I use the command:
-          Probe start script : M340 P0 S700
-          Probe finished script M340 P0 S700
Everything work, the probe goes up or down, depending on the command.
But when I want to use G28 or G29 or just going down controlling directly Z axis, and then the BL touch touch the bed, the probe is triggered but doesn’t stop the movement.
Can someone help me please? I really don’t know what to do.
Here is the configuration:
  • edited March 2021
    #define Z_PROBE_Z_OFFSET 3
    #define UI_BED_COATING 1
    #define FEATURE_Z_PROBE 1
    #define EXTRUDER_IS_Z_PROBE 0
    #define Z_PROBE_PULLUP 0
    #define Z_PROBE_ON_HIGH 1
    #define Z_PROBE_X_OFFSET 0
    #define Z_PROBE_Y_OFFSET 0
    #define Z_PROBE_SPEED 1
    #define Z_PROBE_XY_SPEED 150
    #define Z_PROBE_SWITCHING_DISTANCE 4
    #define Z_PROBE_REPETITIONS 2
    #define Z_PROBE_USE_MEDIAN 0
    #define Z_PROBE_HEIGHT 2
    #define Z_PROBE_DELAY 0
    #define Z_PROBE_START_SCRIPT "M340 P0 S700"
    #define Z_PROBE_FINISHED_SCRIPT "M340 P0 S1500"
    #define FEATURE_AUTOLEVEL 1
    #define Z_PROBE_X1 280
    #define Z_PROBE_Y1 65
    #define Z_PROBE_X2 280
    #define Z_PROBE_Y2 285
    #define Z_PROBE_X3 20
    #define Z_PROBE_Y3 65
    #define BED_LEVELING_METHOD 1
    #define BED_LEVELING_GRID_SIZE 4
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 0
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #define SDSUPPORT 1
    #undef SDCARDDETECT
    #define SDCARDDETECT -1
    #undef SDCARDDETECTINVERTED
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_CONTROLLER 11
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 0
    #define LANGUAGE_NL_ACTIVE 0
    #define LANGUAGE_PT_ACTIVE 0
    #define LANGUAGE_IT_ACTIVE 0
    #define LANGUAGE_ES_ACTIVE 0
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 1
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 0
    #define LANGUAGE_TR_ACTIVE 0
    #define LANGUAGE_RU_ACTIVE 0
    #define UI_PRINTER_NAME "Galney Printer"
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 1
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 0
    #define CASE_LIGHTS_PIN -1
    #define UI_SET_MIN_EXTRUDER_TEMP   170
    #define UI_SET_MAX_EXTRUDER_TEMP   260
    #define NUM_MOTOR_DRIVERS 0
  •  Z min pin must be also set to same pin a z probe.
    Homing settings should include temperature (which you set 0) so you can define a probing position. Select on like 100, 100 so you have no problems activating probe.
    You should raise z before z homing so bl touch is not triggered on activation. Then it goes in alarm mode and you get problems.
    should be 1
    bltouch does not need more and repeating is difficult here.
    M119 should show z probe low.
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 0
    Just don't start with coating when there is no need to. You already measure surface and that is what you need.
    Test if G30 works. Then you can try homing z. With explained settings it should work.
