Repetier Firmware with FYSETC_6
I have a 3D printer and wish to setup with a Fysetc_6 Board.  It has a troublesome Ramps 1.4 and wish to do away with it.
the printer has dual extruders and wish some pointers.  The printer I built and configured myself with Ramps and know some way around the matter but any help appreciated to avoid digging ...
  • No experience with that board, but use old config, change board and double check all pins if they match the connection with the new board. That is how you replace boards with similar boards. If there is also some hardware change like motor drivers you may need to change these parameter es well like steps per mm if microsteps differ.
