Toggle navigation
Categories
Discussions
About Us
Privacy Policy
Sign In
Home
Repetier-Host
General
how to reverse extruders
rockyrude
February 2021
in
General
I have flashed my davinci 2.0 with repetier. The only issue I have left is the extruders are reversed. Is there a setting I am missing?
Repetier
February 2021
Direction comes from this setting:
// set to false/true for normal / inverse direction
#define
EXT0_INVERSE false
so set it to opposite or rotate motor connector 180°.
rockyrude
March 2021
Is this setting in the configuration.h file? Do I set it to true?
Repetier
March 2021
Yes it is in configration.h and you set it to the opposite of what it now is.
rockyrude
March 2021
Thank you
rockyrude
March 2021
Can I just modify the value and compile/upload to my eeprom or do I need to clear the eeprom first?
Repetier
March 2021
You upload to flash, not eeprom. eeprom can stay and will normally with such small change. No problem here to be expected.
rockyrude
March 2021
I worded my question incorrectly, I am looking to reverse extruder 1 and 2.
RAyWB
March 2021
edited March 2021
so you mean to swap extruder1 and 2 ?
so extruder 1 shall be extruder 2 and extruder2 shall be extruder 1?
rockyrude
March 2021
Yes, the firmware has extruder 1 on the right. I need it to be on the left.
rockyrude
March 2021
Sorry,had it backwards, extruder 1 is on the left, need it on the right
Repetier
March 2021
So extruder 2 is now on the right? Just swap all config values between extruder 1 and 2.
If you do not care about numbering just position of second extruder give second extruder a negative x offset so extruder switch gets correct positions.
Sign In
or
Register
to comment.
