Trouble with Logitech c920
I just installed the software on my raspberry pi 4. It is connected through Ethernet. I can’t seem to get the USB plugged C920 to work. It doesn’t pop up. I tried MPJ and it wasn’t able to pull it from
GitHub. Just said not found. Any advice? I go
Into settings and nothing comes up even when I select add new webcam still nothing.
I also verified that camera was turned on through ssh interface. Says 1 supported but none found. It’s plugged into my USB 3.0 port on the PI
In ssh you see video devices with
ls /dev/v4l/by-id/
If it changes after plugging it in you know the device and that it is supported (should be have several logitechs working)
