Repetier-Host 1.0.6 / Linux
I'm running Repetier-Host 1.0.6 on Ubuntu. When I explore the EEPROM contents (Alt + E) everything works as expected for the first time after the application started. The second time, it crashes when I try to manipulate a value.
Output in the console:
System.ObjectDisposedException: The object was used after being disposed.
  at System.Windows.Forms.Control.CreateHandle () [0x00000] in <filename unknown>:0
  at System.Windows.Forms.TextBoxBase.CreateHandle () [0x00000] in <filename unknown>:0
  at System.Windows.Forms.Control.CreateControl () [0x00000] in <filename unknown>:0
  at System.Windows.Forms.Control.SetVisibleCore (Boolean value) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.Control.set_Visible (Boolean value) [0x00000] in <filename unknown>:0
  at (wrapper remoting-invoke-with-check) System.Windows.Forms.Control:set_Visible (bool)
  at System.Windows.Forms.DataGridView.BeginEdit (Boolean selectAll) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.DataGridView.SetCurrentCellAddressCore (Int32 columnIndex, Int32 rowIndex, Boolean setAnchorCellAddress, Boolean validateCurrentCell, Boolean throughMouseClick) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.DataGridView.OnMouseDown (System.Windows.Forms.MouseEventArgs e) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.Control.WmLButtonDown (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.Control.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.DataGridView.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.Control+ControlWindowTarget.OnMessage (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.Control+ControlNativeWindow.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.NativeWindow.WndProc (IntPtr hWnd, Msg msg, IntPtr wParam, IntPtr lParam) [0x00000] in <filename unknown>:0
System.ArgumentOutOfRangeException: Index is less than 0 or more than or equal to the list count.
Parameter name: index
0
  at System.Collections.ArrayList.ThrowNewArgumentOutOfRangeException (System.String name, System.Object actual, System.String message) [0x00000] in <filename unknown>:0
  at System.Collections.ArrayList.get_Item (Int32 index) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.DataGridViewRowCollection.SharedRow (Int32 rowIndex) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.DataGridView.GetRowInternal (Int32 rowIndex) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.DataGridView.GetCellInternal (Int32 colIndex, Int32 rowIndex) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.DataGridView.OnCellLeave (System.Windows.Forms.DataGridViewCellEventArgs e) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.DataGridView.MoveCurrentCell (Int32 x, Int32 y, Boolean select, Boolean isControl, Boolean isShift, Boolean scroll) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.DataGridView.OnColumnCollectionChanged (System.Object sender, System.ComponentModel.CollectionChangeEventArgs e) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.DataGridViewColumnCollection.OnCollectionChanged (System.ComponentModel.CollectionChangeEventArgs e) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.DataGridViewColumnCollection.Clear () [0x00000] in <filename unknown>:0
  at System.Windows.Forms.DataGridView.Dispose (Boolean disposing) [0x00000] in <filename unknown>:0
  at System.ComponentModel.Component.Dispose () [0x00000] in <filename unknown>:0
  at (wrapper remoting-invoke-with-check) System.ComponentModel.Component:Dispose ()
  at System.Windows.Forms.Control.Dispose (Boolean disposing) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.ContainerControl.Dispose (Boolean disposing) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.Form.Dispose (Boolean disposing) [0x00000] in <filename unknown>:0
  at RRFirmwares.eeprom.EEPROMRepetier.Dispose (Boolean disposing) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.Form.WmClose (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.Form.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
  • A known mono bug. Next release does not use a table for viewing it any more, so it will then also work with mono as often as you want.
