Repetier Host output Transformation matrix
Good morning
Transformation matrix: 1.000000 0.000000 0.000000 0.000000 1.000000 0.000000 0.000000 0.000000 1.000000
I have not found documentation of how to interpret the values reported in this string.
Can you explain them?
Where can I find documentation about it?
Because with only 1 diagonally nothing changes ?
In order not to change anything, shouldn't they all be zero ?
When you run G32 the output is more easy to understand. There you see parameter a, b and c as equation for Z correction depending on x,y. I think it is Zcorr = a * x + b * y + c
