repetier firmware dev2 Z stepper
hi, on ruramps4d 1.3 does not work Z stepper
my config
my config
#pragma once
This file is optimized for version 1.0.0dev
as you expect.
// The follwing variables are required early to decide on the right modules.
#define NUM_TOOLS 1
#define NUM_EXTRUDER 1
#define NUM_SERVOS 1 // Number of serves available
#define MOTHERBOARD 414 // 405
#define EEPROM_MODE 2
#define RFSERIAL Serial
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL 101
#define BLUETOOTH_BAUD 115200
#define JSON_OUTPUT 1
#define FEATURE_WATCHDOG 0
#define FEATURE_RETRACTION 1
#define NUM_AXES 6 // X,Y,Z and E for extruder A,B,C would be 5,6,7
// #define STEPPER_FREQUENCY 153000 // Maximum stepper frequency.
#define STEPPER_FREQUENCY 100000 // Maximum stepper frequency.
#define PREPARE_FREQUENCY 1000 // Update frequency for new blocks. Must be higher then PREPARE_FREQUENCY.
#define BLOCK_FREQUENCY 500 // Number of blocks with constant stepper rate per second.
#define VELOCITY_PROFILE 1 // 0 = linear, 1 = cubic, 2 = quintic velocity shape
#define Z_SPEED 150 // Z positioning speed
#define XY_SPEED 150 // XY positioning speed for normal operations
#define E_SPEED 2
#define A_SPEED 150
#define B_SPEED 150 // Extrusion speed
#define G0_FEEDRATE 0 // Speed for G0 moves. Independent from set F value! Set 0 to use F value.
#define MAX_ROOM_TEMPERATURE 25 // No heating below this temperature!
#define TEMPERATURE_CONTROL_RANGE 20 // Start with controlling if temperature is +/- this value to target temperature
#define HOST_RESCUE 1 // Enable host rescue help system
//#define DEBUG_RESCUE // Uncomment to add power loss entry in debug menu while printing
#define POWERLOSS_LEVEL 2 // How much time do we have on powerloss, 0 = no move, 1 = short just raise Z, 2 = long full park move
#define POWERLOSS_UP 5 // How much to move up if mode 1 is active
#define Z_PROBE_TYPE 2 // 0 = no z probe, 1 = default z probe, 2 = Nozzle as probe
#define Z_PROBE_BORDER 2 // Safety border to ensure position is allowed
#define Z_PROBE_TEMPERATURE 170 // Temperature for type 2
// 0 = Cartesian, 1 = CoreXYZ, 2 = delta, 3 = Dual X-Axis
#define PRINTER_TYPE 2
// steps to include as babysteps per 1/BLOCK_FREQUENCY seconds. Must be lower then STEPPER_FREQUENCY/BLOCK_FREQUENCY and be low enough to not loose steps.
#define BABYSTEPS_PER_BLOCK \
{ 10, 10, 10 }
// If all axis end stops are hardware based we can skip the time consuming tests each step
#define NO_SOFTWARE_AXIS_ENDSTOPS
// Normally only a delta has motor end stops required. Normally you trigger using axis endstops.
//#define NO_MOTOR_ENDSTOPS
#define FEATURE_CONTROLLER 0 // CONTROLLER_FELIX_DUE
// Use more memory to speedup display updates
#define DISPLAY_FULL_BUFFER 1
// Direction 1 or -1
// #define ENCODER_DIRECTION -1
// Encoder speed 0 = fastest, 1 or 2 = slowest - set so 1 click is one menu move
// Default is 2 if not set by controller. Us eonly to fix wrong setting
#define ENCODER_SPEED 1
/* Ratios for core xyz. First index denotes motor and second axis.
For each motor you can set the ratio of x,y,z position that adds
to the position. 0 = no contribution. */
// X motor = x + y
#define COREXYZ_X_X 1
#define COREXYZ_X_Y 1
#define COREXYZ_X_Z 0
// Y motor = x - y
#define COREXYZ_Y_X 1
#define COREXYZ_Y_Y -1
#define COREXYZ_Y_Z 0
// Z motor = z
#define COREXYZ_Z_X 0
#define COREXYZ_Z_Y 0
#define COREXYZ_Z_Z 1
// Special geometry definition if printer type is delta
/* =========== Parameter essential for delta calibration ===================
C, Y-Axis
| |___| Carriage horizontal offset
|_________ X-axis | \ |
/ \ | \ DELTA_DIAGONAL (length) Each move this Rod Height
/ \ \ is calculated
/ \ \ Carriage is at printer center! |
A B \_____/--------------------------------
|--| End effector horizontal offset (recommend set it to 0)
|----| DELTA_HORIZONTAL_RADIUS (Horizontal rod pivot to pivot measure)
Column angles are measured from X-axis counterclockwise
"Standard" positions: alpha_A = 210, alpha_B = 330, alpha_C = 90
#define DELTA_DIAGONAL 262.0f
#define DELTA_HORIZONTAL_RADIUS 110.0f
#define DELTA_PRINT_RADIUS 110.0f
#define DELTA_ANGLE_A 210.0f
#define DELTA_ANGLE_B 330.0f
#define DELTA_ANGLE_C 90.0f
#define DELTA_CORRECTION_A 0.0f
#define DELTA_CORRECTION_B 0.0f
#define DELTA_CORRECTION_C 0.0f
#define DELTA_RADIUS_CORRECTION_A 0.0f
#define DELTA_RADIUS_CORRECTION_B 0.0f
#define DELTA_RADIUS_CORRECTION_C 0.0f
#define DELTA_HOME_OFFSET_A 0.0f
#define DELTA_HOME_OFFSET_B 0.0f
#define DELTA_HOME_OFFSET_C 0.0f
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define FEATURE_AXISCOMP 1
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
// Next 7 lines are required to make the following work, do not change!
#include "boards/pins.h"
#undef IO_TARGET
#define IO_TARGET 4
#undef CONFIG_EXTERN
#define CONFIG_EXTERN extern
#include "drivers/drivers.h"
#include "io/redefine.h"
// Define ZProbe by referencing a endstop defined
CONFIG_VARIABLE_EQ(EndstopDriver, *ZProbe, &endstopZMin)
/** Axes are homed in order of priority (0..10) if homing direction is not 0. */
#define X_HOME_PRIORITY 0
#define Y_HOME_PRIORITY 1
#define Z_HOME_PRIORITY 2
#define A_HOME_PRIORITY 3
#define B_HOME_PRIORITY 4
// All fans in this list list become controllable with M106/M107
// by selecteing the fan number with P0..P<NUM_FANS-1>
#define NUM_FANS 1
#define FAN_LIST \
{ &Fan1PWM }
#define NUM_HEATED_BEDS 1
#define HEATED_BED_LIST \
{ &HeatedBed1 }
#define NUM_HEATED_CHAMBERS 0
#define HEATED_CHAMBER_LIST \
#define SERVO_LIST \
{ &Servo1 }
#define TOOLS \
{ &ToolExtruder1 }
// Heaters enumerate all heaters, so we can loop over them
// or call commands on a specific heater number.
// Suggested order: extruder heaters, heated beds, heated chambers, additional heaters
#define NUM_HEATERS 3
#define HEATERS \
{ &HeaterExtruder1, &HeaterExtruder2, &HeatedBed1 }
// Array to call motor related commands like microstepping/current if supported.
// Id's start at 0 and depend on position in this array.
#define NUM_MOTORS 6
#define MOTORS \
{ &XMotor, &YMotor, &ZMotor, &E1Motor, &AMotor, &BMotor }
#define MOTOR_NAMES \
{ PSTR("X"), PSTR("Y"), PSTR("Z"), PSTR("E0"), PSTR("A"), PSTR("B")}
// Some common settings for trinamic driver settings
Chopper timing is an array with
{toff, hend, hstrt}
See TMC datasheets for more details. There are some predefined values to get you started:
CHOPPER_TIMING_DEFAULT_12V = { 3, -1, 1 }
CHOPPER_TIMING_DEFAULT_19V = { 4, 1, 1 }
CHOPPER_TIMING_DEFAULT_24V = { 4, 2, 1 }
CHOPPER_TIMING_DEFAULT_36V = { 5, 2, 4 }
CHOPPER_TIMING_PRUSAMK3_24V = { 3, -2, 6 }
#define TMC_CHOPPER_TIMING CHOPPER_TIMING_DEFAULT_12V
// true = interpolate to 256 microsteps for smoother motion
#define TMC_INTERPOLATE true
// Current used when motor stands still
#define TMC_HOLD_MULTIPLIER 0.5
// Reduce current on over temperature warnings by x milli ampere, 0 = disable
#define TMC_CURRENT_STEP_DOWN 50
// Define which data should be stored to eeprom
#define STORE_MOTOR_MICROSTEPPING 1
#define STORE_MOTOR_CURRENT 1
#define STORE_MOTOR_HYBRID_TRESHOLD 1
#define STORE_MOTOR_STEALTH 1
#define STORE_MOTOR_STALL_SENSITIVITY 1
#define X_HOME_DIR 1
#define Y_HOME_DIR 1
#define Z_HOME_DIR 1
#define B_HOME_DIR 1
#define A_HOME_DIR 1
#define X_MAX_LENGTH 220
#define Y_MAX_LENGTH 220
#define Z_MAX_LENGTH 225
#define A_MAX_LENGTH 10000000000
#define B_MAX_LENGTH 60
#define X_MIN_POS -110
#define Y_MIN_POS -110
#define Z_MIN_POS 0
#define A_MIN_POS -1000000
#define B_MIN_POS -100
#define BED_X_MIN X_MIN_POS
#define BED_X_MAX (X_MIN_POS + X_MAX_LENGTH)
#define BED_Y_MIN Y_MIN_POS
#define BED_Y_MAX (Y_MIN_POS + Y_MAX_LENGTH)
// Park position used when pausing from firmware side
#if PRINTER_TYPE == 2
#define PARK_POSITION_X (0)
#define PARK_POSITION_Y (70)
#define PARK_POSITION_X (X_MIN_POS)
#define PARK_POSITION_Y (Y_MIN_POS + Y_MAX_LENGTH)
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 600
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 600
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 600
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_A 600
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_B 600
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 600
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 600
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 600
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_A 600
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_B 600
#define XAXIS_STEPS_PER_MM 800
#define YAXIS_STEPS_PER_MM 800
#define ZAXIS_STEPS_PER_MM 800
#define AAXIS_STEPS_PER_MM 50
#define BAXIS_STEPS_PER_MM 50
#undef Y_MIN_PIN
#define Y_MIN_PIN -1
#undef X_MAX_PIN
#define X_MAX_PIN -1
#undef Y_MAX_PIN
#define Y_MAX_PIN ORIG_Y_MIN_PIN
#undef Z_MAX_PIN
#define Z_MAX_PIN -1
#define RETRACT_ON_PAUSE 2
#define PAUSE_END_COMMANDS ""
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 3
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define RETRACTION_UNDO_SPEED 25
#define FILAMENTCHANGE_X_POS 5
#define FILAMENTCHANGE_Y_POS 5
#define FILAMENTCHANGE_SHORTRETRACT 2.5
#define JAM_METHOD 1
#define JAM_ACTION 1
#define PID_CONTROL_RANGE 20
#define EXTRUDE_MAXLENGTH 160
#define SKIP_M190_IF_WITHIN 5
#define MIN_EXTRUDER_TEMP 150
#define DOOR_PIN -1
#define DOOR_PULLUP 1
#define DOOR_INVERTING 1
#define ENDSTOP_X_BACK_MOVE 3
#define ENDSTOP_Y_BACK_MOVE 3
#define ENDSTOP_Z_BACK_MOVE 3
#define ENDSTOP_A_BACK_MOVE 3
#define ENDSTOP_B_BACK_MOVE 3
#define ENDSTOP_X_RETEST_REDUCTION_FACTOR 2
#define ENDSTOP_Y_RETEST_REDUCTION_FACTOR 2
#define ENDSTOP_Z_RETEST_REDUCTION_FACTOR 2
#define ENDSTOP_B_RETEST_REDUCTION_FACTOR 2
#define ENDSTOP_A_RETEST_REDUCTION_FACTOR 2
#define ENDSTOP_X_BACK_ON_HOME 0.5
#define ENDSTOP_Y_BACK_ON_HOME 0.5
#define ENDSTOP_Z_BACK_ON_HOME 0.5
#define ENDSTOP_A_BACK_ON_HOME 0.5
#define ENDSTOP_B_BACK_ON_HOME 0.5
#define MOVE_X_WHEN_HOMED 0
#define MOVE_Y_WHEN_HOMED 0
#define MOVE_Z_WHEN_HOMED 0
#define PREVENT_Z_DISABLE_ON_STEPPER_TIMEOUT 1
// ## Movement settings ##
#define BABYSTEP_MULTIPLICATOR 64
// Delta settings
#define DELTA_HOME_ON_POWER 0
#define MAX_INACTIVE_TIME 1200L
#define MAX_FEEDRATE_X 250
#define MAX_FEEDRATE_Y 250
#define MAX_FEEDRATE_Z 250
#define MAX_FEEDRATE_A 250
#define MAX_FEEDRATE_B 250
#define HOMING_FEEDRATE_X 80
#define HOMING_FEEDRATE_Y 80
#define HOMING_FEEDRATE_Z 80
#define HOMING_FEEDRATE_A 80
#define HOMING_FEEDRATE_B 80
// Raise z before homing (1)
#define ZHOME_PRE_RAISE 1
// How much mm should z raise before homing
#define ZHOME_PRE_RAISE_DISTANCE 2
#define ZHOME_HEAT_ALL 0
// Height in mm after homing.
#define ZHOME_HEIGHT 10
// Home Z at a fixed xy position (1)
#define FIXED_Z_HOME_POSITION 1
#define ZHOME_X_POS 140
#define ZHOME_Y_POS 45
// Raise extruders before switching tools. Used to prevent touching objects while switching.
#define RAISE_Z_ON_TOOLCHANGE 2
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define MAX_JERK 5
#define MAX_ZJERK 0.3
#define MAX_AJERK 5
#define MAX_BJERK 5
#define PRINTLINE_CACHE_SIZE 32
#define MOVE_CACHE_LOW 10
#define BAUDRATE 115200
#define POWER_INVERTING 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#undef PS_ON_PIN
#define PS_ON_PIN -1
#define Z_PROBE_COATING 0
#define Z_PROBE_Z_OFFSET_MODE 1
#define UI_BED_COATING 1
#define EXTRUDER_IS_Z_PROBE 1
#define Z_PROBE_DISABLE_HEATERS 1
#define Z_PROBE_BED_DISTANCE 3
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 2
// How often should we test a position 1 .. x. Averages result over all tests.
#define Z_PROBE_REPETITIONS 1
// 0 = use average, 1 = use middle value after ordering z
#define Z_PROBE_USE_MEDIAN 1
// Nozzle distance to bed when z probe triggers
#define Z_PROBE_HEIGHT -0.15
// Delay in ms before we go down again. For BLTouch so signal can disable
#define Z_PROBE_DELAY 0
#define Z_PROBE_REQUIRES_HEATING 1
// How to correct rotated beds
// 0 = Software side by rotating coordinates
// 1 = Move bed physically using 2 motors
#define LEVELING_CORRECTOR 0
// Bed fixture coordinates for motor leveling
#define LC_P1_X 55
#define LC_P1_Y 130
#define LC_P2_X 137
#define LC_P2_Y 45
#define LC_P3_X 137
#define LC_P3_Y 210
#define LC_P2_MOTOR AL1Motor
#define LC_P3_MOTOR AL2Motor
#define LC_STEPS_PER_MM 3382
#define LC_Z_SPEED 0.2
// > 0 will move bed down and wait for removal (heater removed) and will pause another LC_WAIT_BED_REMOVE seconds
#define LC_WAIT_BED_REMOVE 2
// Uncomment to limit correction per autoleveling iteration. Value is the max. correction in mm
// #define LIMIT_MOTORIZED_CORRECTION 0.5
// Leveling method
// 0 = none, 3 = 3 points, 1 = grid, 2 = 4 point symmetric
#define LEVELING_METHOD 2
#define L_P1_X 60
#define L_P1_Y 130
#define L_P2_X 137
#define L_P2_Y 45
#define L_P3_X 137
#define L_P3_Y 210
#define MAX_GRID_SIZE 5 // Maximum grid size allocation in memory, imported grid can be smaller
#define ENABLE_BUMP_CORRECTION 1 // CPU intensive, so only activate if required
#define BUMP_CORRECTION_START_DEGRADE 0.5 // Until this height we correct 100%
#define BUMP_CORRECTION_END_HEIGHT 2 // From this height on we do no correction
#define BUMP_LIMIT_TO 0 // Maximum allowed correction up/down, <= 0 off.
#define SDSUPPORT 1
#undef SDCARDDETECT
#define SDCARDDETECT ORIG_SDCARDDETECT
#define SD_RUN_ON_STOP ""
#define ARC_SUPPORT 0
#define UI_PRINTER_NAME "Testsetup"
#define UI_PRINTER_COMPANY "Repetier"
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 2
#define UI_REVERSE_ENCODER 0
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_MIN_REPEAT 50
#define CASE_LIGHTS_PIN 25
#define UI_START_SCREEN_DELAY 2000
//#define CUSTOM_EVENTS
are the pin definitions for z motor. Is it same driver type than x and y motor? Does Z block before first move or after first z move? What happens - nothing, sound on z motor (steps/acceleration wrong), wrong direction?
Also make sure pins from A and B motor are not the one used for Z.
Otherwise what happens if you change pins between x and z motor? Does z then move and x is blocked? Just as test if driver and socket are working correctly.
