Raise z after home
How can I raise the z by 10mm after it homes?
As it is right now, everything homes x0, y0 and z0, i would like it to home to x0 y0 and z0 then raise the z off of the bed by 10 mm (so the nozzle does not just sit on the bed. I dont want to change the home position, i just want to raise the extruder off of the bed after it homes.
G1 Z10 F600
after G28 homing. In many firmwares you can configure this as well so that you define a homing position for Z then you can omit that but you need to compile a new firmware.
In next server release 0.94.4 you can also make all G28 get extended to add more commands so it happens then automatically.
