Advice on setup of small print farm
I just wanted to get some advice on setting up a small print farm and any particular suggestions for improvements.
I need to setup 7 printers (6x Ender 3 V2's + 1x Ender 3 Pro).
Currently, I have 1x Ender 3 V2 and 1x Ender 3 Pro connected to my Raspberry Pi 3B+ which is running Repetier Server.
I am thinking about connecting 3 printers to the first raspberry pi and 4 printers to a second raspberry pi. Both pi's will have a wired ethernet connection to a network switch which will, in turn, be connected to a tp-link powerline kit.
1. Would this work / be okay to have 3/4 printers per raspberry pi?
2. How many pro licences would I need?
Many thanks
Many thanks
Every pi needs one license so 2 in total leaving 3 free licenses.
How do I actually setup the second raspberry pi.
At the moment there are 4 printers connected and working well with raspberry pi #1 (via serial/path/). It is connected to a network switch using an ethernet cable.
Do I just plugin raspberry pi #2 to the network switch the same way and connect a printer to it and it will appear in repetier-server.local when setting up a new printer or do I need to do something else?
Currently running free version but want to understand the steps better so I can do it in a few days.
On the new raspberry pi I cannot find the printer when I try and add it. I have tried changing the USB and restarting the pi & network switch. Any ideas?
No, unfortunately I don't see /dev/serial/by-path or by-id. So far all I have done is downloaded the raspberry pi image and used BalenaEtcher to put it on the sd card. I have then inserted the SD card into the second raspberry pi. I have connected the raspberry pi to the network switch and can access it locally. I have then renamed the servername.
After disconnecting:
So the now missing Bus 001 Device 003: ID 2c99:0002 is the prusa printer. That way you can check any usb device to be connected.
I can confirm that the printers are now set up on the second pi and everything is working perfectly as it should do!
