While homing Optical End stops are triggered but steppers motors do not stop
I notice that i was printing in mirrored image of my parts. I when it switched the wiring and the firmware to make sure the steppers moved in the correct direction.
After updating the firmware to this configure.h file http://pastebin.com/d5PQbcYu i connected with the Repetier host app and hit the home button for Y axis.
The table starts to travel towards the opti end stop and just keeps going after the end stop is triggered. I can see the endstop is triggered as the LED is off. Also yes I did a M119 with the flag out of the way and saw x:L y:L z:L and then triggered the opti with the flag manually. I ran M119 again and this time i see the the Y opti is triggered x:L y:H z:L.
So from what i can take the homing process is doing it correctly but is not taking the trigger from the opti as reaching the end.
Also i tested on X and got the same result. I scared to test my Z as it perficly aligned now and it will miss step when it bottoms out and mis align my two thread rods.
Any insight to this would be great.
