Best settings tweaks to create a better top layer.
in CuraEngine
What's the best way to make the top layer smooth? Mine is a little rough compared to the first layer on the bottom (obviously I know but I thought I might be able to tweak a setting to achieve a smoother top layer).
For top layer you must check extrusion width (use just nozzle width or close) and use a low speed. That should give best quality.
After that, clicking the "Configuration" button in the slicer tab brings up the SuperSlicer interface. Set up all your settings in there to use as the defaults then when you slice in Repetier-Host it will use those settings.
The setting I was after was called IRONING. It's located in the following place shown in the image below...
Where do I indicate the extrusion width?
And the speed for the last layer? I only see a speed for the first layer.
