Extruder overhoots while heating up
Hi there,
I updated the firmware on my Boxzy printer to add a heating bed in the setup.
While the heating bed is working, now the extruder temperature overshoots everytime when heating up. When (manually) setting the heater to 200°C, it gets up to approx. 250°C, but target temperature can be reached if extruder is deactivated earlier.
Playing with the parameters (in PID control / Dead time control) doesn't change anything.
So I'm able to print, but it makes me a bit nervous.
Here you can see the overshoot and the temperature swinging further on:
Unfortunately, I havn't the the old firmware settings and Boxzy do not reply either.
Do you have any ideas how to calibrate without knowing the exact extruder facts?Thanks in advance!
Kai
Kai
Have you tried M303 to get a proposal for PID values? Which firmware does it use?
If you see the output you clearly see that the I part is not working correctly making it so unstable. You should see that it builds an average pwm value. So why does I not accumulate? Too small or did you contrain it so it is not allowed to raise?
Firmware is 1.0.4
Kai
