Repetier Server with Marlin asking for resets
Reptier Server 0.94.3 .
Core XY, Marlin 2.0
when doing a G28 home function, I get the following error as soon as the endstop is triggered and the carriage moves to perfroem a bump.
Core XY, Marlin 2.0
Send:16:02:23.932: N8 M119
Recv:16:02:24.488: Reporting endstop status
Recv:16:02:24.488: x_min: open
Recv:16:02:24.488: y_min: open
Recv:16:02:24.489: z_min: TRIGGERED
Recv:16:02:24.489: filament: TRIGGERED
Send:16:02:34.013: N9 G28
Mesg:16:02:38.978: Firmware stopped! You can only send host and shell commands until you hit emergency stop or restart the printer. Eventually running print is stopped.
Recv:16:02:38.978: Error:Printer halted. kill() called!
Does the printer have power? I can imagine that since z min is triggered it expects it to untigger and trigger again and if that does not happen it goes into error state. Would happen if you send the command before the printer has main power and when only powered over usb.
More information just incase anyone else runs into the issue, Z is BL Touch, was going from sensorless back to mechanical enstops on Marlin 2.0 on a BTT SKR 1.4 Turbo.
Looking forward to if you guys release new Repetier firmware that supports the BTT 32 bit boards so I can go back to using repetier firmware.
Thanks again and love your products.
-Brett
