Autotuned Extruder Consistently Under Temp
Hi! I’ve bought various parts for a homemade 3D printer, and I’m running into a problem with either the PID tuning, the extruder, or motherboard. When I autotune the PID in Repetier-Host (using m303 e0 s###) and upload the updated values using repetier-firmware on arduino, the actual temperature is consistently 2-3°C under the target temperature. This has happened when I tuned it to 240°, 235°, and 230°C.
I am using a Melzi v2.0 board from an old Tronxy X1 (with custom repetier firmware) with a MOSFET for the extruder, but before I had the MOSFET the same problem was occurring.
I’m using the MkIII extruder, or whatever extruder the Anet A8 uses if I got the model name wrong.
Is this an issue that can be fixed with manual PID tuning (which I have sort of tried), switching to bang bang, or do I have to get a new motherboard, or what?
when that is lower then what you need for your temperature you will get exactly your effect as well. Should be editable in eeprom so just check what it is set and increase it and see if it improves.
