Squarish Circles
I have a 3d printer I built which is all metal with no backlash. Recently upgraded the x and y axis with mechaduino closed loop And reflashed the firmware to siut. The printer runs ok but circles are oval and oblong. Now I checked the axis movement with a dial test indicator and found that I have a 0.5 backlash in both axis... this was not the case before I fitted the mechaduinos. When I put the new Repetier firmware, i think that I Enabled Backlash... i am at a loss what is going on... any clues? Maybe because I gave backlash enabled?
But the question is if that is really all worth the costs. If you are not printing very hard to print material that warps up constantly (main problem for lost steps) a print normally succeeds when it stays connected to bed.
