Move the non current Extruder on Toolchange
I have an Dual X axis Printer and try to extrude some Filament with the non current Extruder.
It ist possible to add the some code that enables the inactive extruder to extrude a few mm before it is moved to start position?
G1 E10 for Example is only working for the current Extruder.
How it is possible to move the non current Extruder.
  • It is not possible to move inactive extruders, so you have to make it active first, then you can move it. If you want to extruder at park position you should enable lazy positioning. Then only the first moving extrusion move (contains E plus a coordinate) will move it. Pure extrusions should happen at park position.
