Homing not working as expected (does not stop)
edited September 2020 in Motor Control
Using Rumba32 and repetier dev2 I have the following Problem:
I move somewhere in the center of my bed. Using M119 I get something like
endstops hit: x_min:L y_max:L z_max:H
Which ist correct, because z is at maximum and hits the end stop.
When I move by hand to the x-axis min hard stop I get
endstops hit: x_min:H y_max:L z_max:H
makes sense.
When I press homing while position is somewhere in the center, it moves correctly towards x-axis min, but it does not stop. I cannot read the endstop value by M119, because during homing the communication seems to be blocked (makes sense).
I press either reset or wait till it stops the homing without result. Using M119 I get the result
For noise supression I added some capacitors parallel to the switch.
Am I doing something wrong? The endstops for x, y and z are the same type. So I do not understand, why this homing does not work.
Every movement is done using repetier server.
My main configuration of the endtsops is the following:
configuration.h
// ################ Endstop configuration #####################
#define DOOR_PIN -1
#define DOOR_PULLUP 1
#define DOOR_INVERTING 1
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 5
#define ENDSTOP_X_RETEST_REDUCTION_FACTOR 5
#define ENDSTOP_Y_RETEST_REDUCTION_FACTOR 5
#define ENDSTOP_Z_RETEST_REDUCTION_FACTOR 5
#define ENDSTOP_X_BACK_ON_HOME 0
#define ENDSTOP_Y_BACK_ON_HOME 0
#define ENDSTOP_Z_BACK_ON_HOME 0
#define ALWAYS_CHECK_ENDSTOPS 1
#define MOVE_X_WHEN_HOMED 0
#define MOVE_Y_WHEN_HOMED 0
#define MOVE_Z_WHEN_HOMED 0
configuration_io.h
// Define your endstops inputs
IO_INPUT_INVERTED_PULLUP(IOEndstopXMin, ORIG_X_MIN_PIN)
// IO_INPUT_INVERTED(IOEndstopXMin, ORIG_X_MIN_PIN)
IO_INPUT_INVERTED_PULLUP(IOEndstopYMax, ORIG_Y_MAX_PIN)
IO_INPUT_INVERTED_PULLUP(IOEndstopZMax, ORIG_Z_MAX_PIN)
ENDSTOP_SWITCH_HW(endstopXMin, IOEndstopXMin, X_AXIS, true)
ENDSTOP_NONE(endstopXMax)
ENDSTOP_NONE(endstopYMin)
ENDSTOP_SWITCH_HW(endstopYMax, IOEndstopYMax, Y_AXIS, true)
ENDSTOP_SWITCH_HW(endstopZMax, IOEndstopZMax, Z_AXIS, true)
ENDSTOP_NONE(endstopZMin)
  • edited September 2020
    ENDSTOP_SWITCH_HW(endstopXMin, IOEndstopXMin, X_AXIS, false)
    should do the trick.
    false  = homing to min , true =homing to max
    so as z is homing to max it´s working correct. if y is homing to min also change to false
    Thanks, I read that manual, but obviously too fast. I did not expect the need of entering two times the direction:
    Here:
    #define X_HOME_DIR -1
    And here:
    It might make sense to translate "X_HOME_DIR" to false/true using some code, what I am yet not able to do.
    Now it stops, moves back as expected, than looks again for the endstop. So far so good.
    But than it tries to move to a position smaller than the endstop, hitting the end of my printer.
  • Looks like the endstop is defined as 0 mm.
    If I set "x-axis distance after homing" to 0 it does not move.
    "x-axis min position" is set to -65mm. Therefore I thought I need to set "x-axis distance after homing"to -65mm.
    Where do I set the position of the endstop?
  • Distance after homing is just to get away from the endstop so it is not triggered any more. It is independent of the position so think of it as a relative distance.
    min/max positions are defined by this
    #define X_MAX_LENGTH 420
    #define Y_MAX_LENGTH 420
    #define Z_MAX_LENGTH 595.596
    #define X_MIN_POS -210
    #define Y_MIN_POS -210
    #define Z_MIN_POS 0
    just put your value sthere.
    Ok, handling it as a relative position change explains it. And you are right, a distance is alway relative... damn math/physics definitions. I like them, but sometimes I don't expect others to use them in the correct way. I apologize for this.
