X/Y probe offset not used when bed leveling
I just rebuilt my carriage and put a BLTouch on the back. I've used BLTouch on my other printer and as far as I know it works great. On this printer, since it is in the rear of the carriage, it is set to 60 mm Y offset but when I tell it to probe starting at Y10 mm it puts the nozzle at Y 10mm instead of the prbe at Y 10mm. When it gets to the back of the bed and tries to probe Y 280 mm the BLTouch is 40 mm off the back of the bed. I've spent a long time searching the forums and cannot find anything that helps. Everything else on the printer works perfect!
Here is my config. Can someone help me please?
#define NUM_EXTRUDER 1
#define MOTHERBOARD 33
#include "pins.h"
#undef FAN_PIN
#define FAN_PIN 9
#undef FAN_BOARD_PIN
#define FAN_BOARD_PIN -1
#define BOARD_FAN_SPEED 255
#define BOARD_FAN_MIN_SPEED 0
#define FAN_THERMO_PIN -1
#undef X_MAX_PIN
#define X_MAX_PIN -1
#undef Y_MAX_PIN
#define Y_MAX_PIN -1
#undef Z_MAX_PIN
#define Z_MAX_PIN -1
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL -1
#define BLUETOOTH_BAUD 115200
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 0
#define XAXIS_STEPS_PER_MM 80
#define YAXIS_STEPS_PER_MM 80
#define ZAXIS_STEPS_PER_MM 400
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define RETRACT_ON_PAUSE 5
#define PAUSE_END_COMMANDS ""
#define SHARED_EXTRUDER_HEATER 1
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 416.98
#define EXT0_TEMPSENSOR_TYPE 14
#define EXT0_INVERSE 1
#define EXT0_ENABLE_ON 0
#define EXT0_MIRROR_STEPPER 0
#define EXT0_INVERSE2 0
#define EXT0_MAX_FEEDRATE 50
#define EXT0_HEAT_MANAGER 1
#define EXT0_PREHEAT_TEMP 185
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_PGAIN_OR_DEAD_TIME 19.87
#define EXT0_PID_I 2.35
#define EXT0_PID_D 42.00
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
#define FEATURE_RETRACTION 0
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 5
#define RETRACTION_LONG_LENGTH 8
#define RETRACTION_SPEED 10
#define RETRACTION_Z_LIFT 0
#define RETRACTION_UNDO_SPEED 15
#define JAM_METHOD 1
#define JAM_STEPS 220
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 1
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define HEATER_PWM_SPEED 0
#define COOLER_PWM_SPEED 0
#define HAVE_HEATED_BED 1
#define HEATED_BED_PREHEAT_TEMP 50
#define HEATED_BED_MAX_TEMP 60
#define SKIP_M190_IF_WITHIN 2
#define HEATED_BED_PID_PGAIN_OR_DEAD_TIME 329.73
#define HEATED_BED_PID_IGAIN 66.42
#define HEATED_BED_PID_DGAIN 409.23
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 250
#define ENDSTOP_PULLUP_Z2_MINMAX false
#define X2_MIN_PIN -1
#define X2_MAX_PIN -1
#define Y2_MIN_PIN -1
#define Y2_MAX_PIN -1
#define Z2_MINMAX_PIN -1
#define DOOR_PIN -1
#define DOOR_PULLUP 1
#define DOOR_INVERTING 0
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define ENDSTOP_X_BACK_ON_HOME 19
#define ENDSTOP_Y_BACK_ON_HOME 25
#define MOVE_X_WHEN_HOMED 0
#define MOVE_Y_WHEN_HOMED 0
#define MOVE_Z_WHEN_HOMED 0
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define PREVENT_Z_DISABLE_ON_STEPPER_TIMEOUT
#define INVERT_X_DIR 0
#define INVERT_X2_DIR 0
#define INVERT_Y_DIR 0
#define INVERT_Y2_DIR 0
#define INVERT_Z_DIR 1
#define INVERT_Z2_DIR 1
#define INVERT_Z3_DIR 0
#define INVERT_Z4_DIR 0
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define X_MAX_LENGTH 300
#define Y_MAX_LENGTH 300
#define Z_MAX_LENGTH 300
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define PARK_POSITION_X 10
#define PARK_POSITION_Y 5
#define PARK_POSITION_Z_RAISE 5
#define DISTORTION_LIMIT_TO 2
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 190
#define DISTORTION_YMAX 190
// ## Movement settings ##
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_HOME_ON_POWER 0
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 100
#define MAX_FEEDRATE_Y 100
#define MAX_FEEDRATE_Z 3
#define HOMING_FEEDRATE_X 80
#define HOMING_FEEDRATE_Y 80
#define HOMING_FEEDRATE_Z 3
#define HOMING_ORDER HOME_ORDER_XYTZ
#define ZHOME_PRE_RAISE 2
#define ZHOME_PRE_RAISE_DISTANCE 5
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 150
#define ZHOME_Y_POS 150
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define ALLOW_QUADSTEPPING 1
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 150
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 150
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 50
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 150
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 150
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 50
#define MAX_JERK 8
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define DUAL_X_RESOLUTION 0
#define FEATURE_TWO_ZSTEPPER 1
#define USE_ADVANCE 0
#define BAUDRATE 115200
#define ENABLE_POWER_ON_STARTUP 0
#define POWER_INVERTING 0
#define AUTOMATIC_POWERUP 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 1
#undef PS_ON_PIN
#define PS_ON_PIN -1
#define JSON_OUTPUT 0
/* ======== Servos =======
Control the servos with
#define FEATURE_SERVO 1
#define SERVO0_PIN 11
#define SERVO1_PIN 6
#define SERVO2_PIN 5
#define SERVO3_PIN 4
#define SERVO0_NEUTRAL_POS -1
#define SERVO1_NEUTRAL_POS -1
#define SERVO2_NEUTRAL_POS -1
#define SERVO3_NEUTRAL_POS -1
#define UI_SERVO_CONTROL 0
#define MAX_FAN_PWM 255
#define FEATURE_WATCHDOG 1
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 0
#define FEATURE_Z_PROBE 1
#define EXTRUDER_IS_Z_PROBE 1
#define Z_PROBE_BED_DISTANCE 0
#define Z_PROBE_PULLUP 1
#define Z_PROBE_ON_HIGH 1
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 60
#define Z_PROBE_SPEED 5
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_SWITCHING_DISTANCE 5
#define Z_PROBE_REPETITIONS 2
#define Z_PROBE_USE_MEDIAN 0
#define Z_PROBE_HEIGHT 0.20
#define Z_PROBE_DELAY 0
#define Z_PROBE_START_SCRIPT "M340 P0 S650"
#define Z_PROBE_FINISHED_SCRIPT "M340 P0 S1475"
#define FEATURE_AUTOLEVEL 1
#define FEATURE_SOFTWARE_LEVELING 1
#define Z_PROBE_X1 10
#define Z_PROBE_Y1 10
#define Z_PROBE_X2 290
#define Z_PROBE_Y2 10
#define Z_PROBE_X3 10
#define Z_PROBE_Y3 230
#define BED_LEVELING_METHOD 1
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#define SDSUPPORT 1
#undef SDCARDDETECT
#define SDCARDDETECT -1
#undef SDCARDDETECTINVERTED
#define SD_RUN_ON_STOP ""
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define FEATURE_CONTROLLER 11
#define ADC_KEYPAD_PIN -1
#define LANGUAGE_EN_ACTIVE 1
#define LANGUAGE_DE_ACTIVE 0
#define LANGUAGE_NL_ACTIVE 0
#define LANGUAGE_PT_ACTIVE 0
#define LANGUAGE_IT_ACTIVE 0
#define LANGUAGE_ES_ACTIVE 0
#define LANGUAGE_FI_ACTIVE 0
#define LANGUAGE_SE_ACTIVE 0
#define LANGUAGE_FR_ACTIVE 0
#define LANGUAGE_CZ_ACTIVE 0
#define LANGUAGE_PL_ACTIVE 0
#define LANGUAGE_TR_ACTIVE 0
#define UI_PRINTER_NAME "AM8"
#define UI_PRINTER_COMPANY ""
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 2
#define UI_REVERSE_ENCODER 0
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 0
#define CASE_LIGHTS_PIN -1
#define UI_SET_MAX_HEATED_BED_TEMP 80
#define UI_SET_MIN_EXTRUDER_TEMP 150
#define UI_SET_MAX_EXTRUDER_TEMP 250
#define NUM_MOTOR_DRIVERS 0
Z-probe offset x [mm] = 0
i would have thought trying to probe at Y 10 would be an illegal position as you are trying to get the nozzle to go to
y-50
I understand that y-50 would be illegal if I do not allow y to go below zero. But why when I tell it to probe a 7x7 grid, y max being 280, does it send the probe 40 mm off the back of the bed instead of probing at Y 280?
Deploy logic is not the smartest in V1 firmware. It must succeed at the point you do it or it will fail. V2 does move here to apply it correctly. But it won't run on 8 bit controller for the moment.
This is the log after G30 while the probe is at X 0 Y 60:
Z-probe:1.567 X:0.00 Y:0.00
I tried auto leveling and instead of the nozzle going to Y -25 for the probe to check Y 35 where I would expect, the nozzle went to Y 95 and the probe went to Y 155. So it is using the offset now, but the opposite direction than I want. I set the offset according to the image in the firmware setup web site with Y 60 being 60 mm behind the nozzle. I have also tried with the offset being Y -60. Both had the exact same result with the bed going forward instead of back.
So I hope your conditions are met with this. Z_HOME_DIR < 0 && Z_PROBE_PIN == Z_MIN_PIN && FEATURE_Z_PROBE
startProbing activates the offset. If this is not possible is writes into log:
If you don't see it it sets offsets like:
so nothing that takes only absolute value of offset.
G30 reports 0/0 as position which is strange.
Please try
G1 X100 Y100 Z20 F6000
G30
and see if it activates and in which direction. Ignore any homing behaviour. Paste log with commands and output and describe it it moves. Offset 60 or -60 should make it behave differently. I used 100/100 because there all moves are possible. Always testing at edges where problems can occur is not helpful analysing the offsets problem.
Also check log when you send G28 to see for any messages there.
This is all for version 1.0.4 or newer. So hope you use a recent version.
I'll keep you posted. Thanks!
Here is me new configuration.h file. Can you identify why my offset is backward?
You can see in my config above that all of these are true.
G1 X100 Y100 Z20 F6000 sends the nozzle tip to X100 Y100 and Z20. G30 just deploys the probe and "homes" Z. No offsets are taken into account.
This is what I get after running your commands above...
which means that the nozzle is the probe and you should not apply any offset. Set it to 0 and it should work.
Now when I do G32 it puts the nozzle where it wants to probe then moves the bed so the probe is where it needs to be then it fails. Here are the logs.
The only problem I have now is when I use G32 the probe is deploying before it is in position. It moves the nozzle to X 20 Y 20, deploys the probe, lowers the nozzle to the bed then it moves to the 60 mm offset position. Then it fails because the probe was already deployed before it was ready to probe.
What I expect to happen is the nozzle goes to X 20 Y 20 then it moves 60 mm forward to account for the offset then it deploys the probe then it lowers the gantry to start probing. This is definitely not happening.
How do I get it to deploy the probe and lower the gantry only after the bed moves to the offset position and is ready to probe?
Here are the logs:
Use a opaque rular you put at different positions and use a light from behind to see the gaps.
In case it is not that flat as you think you can use G33 distortion map to correct for it. Also not that bed shape can change between hot and cold so do measurements in state you run the print. With bltouch this is possible while inductive gets disturbed by bed heater normally.
I just spent a few hours testing and adjusting my bed and it is definitely not flat but it is always the front left that does not stick even if I raise the front left of the bed higher. I had to drop the left stepper down a click during the print to get it to stick, but once it got past the low corner I raised it back up a click and it's printing.
Also I did some adjustments to my Z steppers. I lowered the current because they were getting quite warm then I put a belt and gears across the top to keep both steppers in sync. I think one was not moving as much as the other all the time.
Thanks for all your help. I do not like using a raft for certain projects so printing evenly is a must for some.
Here is what I did:
This made the print level across the entire bed, but had the below issues.
When I first loaded that firmware it moved the X axis really slow for a bit then it started working fine again but after doing a G33 and storing to EEPROM it stuttered really bad in any direction. I reduced the count from 5 to 4 thinking maybe it was too much for my boards memory. No joy.
I then tried this:
#define FEATURE_AUTOLEVEL 0
This did the exact same thing. I even tried G33 without writing to EEPROM thinking EEPROM was overloaded.
I disabled distortion correction and enabled auto bed level and it works fine except it no longer prints level, but all movements are smooth.
What might be a problem is if you have bigger corrections, then z speed might limit motion speed. So you should check if G33 ha sit's values set correctly. All should swing around 0 and have a maximum value of maybe +/-0.1mm. Especially since you fade out within 0.5mm of z motion.
To check values send G33 L0 and see the stored heights. To get them around 0 you normally rung G32 S2 and and G33 with same z probe height.
If I just do G33 all areas of the bed print perfect on the first layer, but I get stuttering when the nozzle is traveling (not actually printing). If I slow the print to 40 mm/s max travel speed then the stuttering is not as rough, but it still does it.
If I do G32 S0 followed by G33, the stuttering goes away but the z offset has to be adjusted to get the nozzle closer to the bed and the left side of the bed does not print as close as the right but the front left did not even stick all the way.
Once I noticed the z offset needed adjusting I changed it from 0.25 to 0.45 and did G32 S0 followed by G33 again and it seemed to be much better but way to close.
Every time I adjust the z height I recalibrate with G32 S0 then G33. It's still not as good as just G33, but it is improving. I'm still working on getting the corners all the same height. For some reason the front left is always lower.
After doing this many times, the bottom left corner is still not sticking well. But it is closer than it ever has been. I even raised the bottom left corner closer to the nozzle then ran G32 S0 and G33 again and it does the same thing.
Again, if I only do G33 and not G32 S0 the first layer is perfect but it stutters.
Last tip for the "bad" area. You can modify G33 values manually. G33 L0 lists the commands to reset that leveling. But if you replace there a z for a position that one will be used then. So narrow areas that stick bad a bit manually. Make sure to use latest dev version - some time ago I fixed a bug with leveling not exactly returning to old position in some cases. Might be the reason for having a bad edge. Or reason is that that part is a bit more flexible or adhesion is worse...
I increased z speed to 10 mm/s and it does not help at all. I would have to manually edit my gcode to slow x/y movement to 40 mm/s on layers below 1mm. Even then it pauses every 10mm but the jerk of it starting back up is not as bad.
I tried to do all my G32 and G33 with a cold bed incase the plastic needle in my BLtouch is being affected by the heat. I know the bed changes with heat, but for testing purposes I don't mind. It seems to be better (but not perfect) so I assume the BLTouch can't handle 60 degree beds.
I will try editing the map to account for the low areas and let you know.
Here are my measurements. Which way do I need to go to get the front left a bit closer?
This is my G32 S0:
11:16:05.542: G33 X10.00 Y10.00 Z0.195
