Toggle navigation
Categories
Discussions
About Us
Privacy Policy
Sign In
Home
Repetier-Firmware
Download Firmware V2 for RUMBA32
karl_ranseier
September 2020
in
Repetier-Firmware
I might be stupid, but I cannot find a download for the repetier firmware V2. Where do I get it?
Repetier
September 2020
It is in the dev2 branch of our github repository:
https://github.com/repetier/Repetier-Firmware/tree/dev2
Also register our documentation for it here:
https://docfirmwarev2.repetier.com/config/introduction/
karl_ranseier
September 2020
Thanks! I ordered Rumba32 because of a broken Rumba. I am a bit nervous about how long it will take to make it print again.
Repetier
September 2020
Good luck. If you use TMC drivers check board for the known bug in one driver pin configuration. It is documented at least in the rumba32 issue list.
karl_ranseier
September 2020
Thanks for that advice. I already noted that issue. My drivers are a bit bigger than the others and do not fit. Anyway I can configure the drivers using USB, therefore the misconfigured pins don't matter.
Sign In
or
Register
to comment.
