Extruder temperature stability problems
On my Prusa MK3 i3 with MMU2 lately I have problems of temperature instability on the extruder, believing hardware problem I have changed the temperature probe the problem still occurs, if I use the printer without connection to Repetier, then with SD Card, everything works regularly.
To use the MMU2 I set the 5 extruders as per your instructions, so the number 1 is equal to 2 \ 3 \ 4 \ 5.
The strange thing is that the problem occurs randomly, especially if I use temperatures over 215 ° C
The software is updated to the latest version
Advice ???
Thank you
