Drive_System Openbuilds Mini Mill
Hello All,
Finished building the Openbuilds Mini Mill. Converting to 3d printer.
Is the Cartesian setting appropriate for drive_system?
As far as I can tell this is appropriate for 3 motor non-delta systems whereas the z+xy/y+xz are for 2 motor systems.
Any help appreciated.
Thanks,
Matt
  • If you mean with z+xy that x and y share one belt and are driven by 2 motors and the mixture controls x/y motion then cartesian is wrong. Cartesian is when each motor controls 1 axis. That system would be core xy in the config tool.
  • Thanks for your response. The minimill has 3 motors, one for each axis.
  • Ok then it is a classic cartesian system.
