Toggle navigation
Categories
Discussions
About Us
Privacy Policy
Sign In
Home
Repetier-Host
Questions & Answers
z step setting
jwb
July 2020
in
Questions & Answers
Cnc machine setting are off on z steps. Cut was to be 11mm but only cut less then 2 mm. How do I make the adjustment. also when I manually move the z steps I hve the same problem
Repetier
July 2020
You mean moving one mm in hist does not move cnc 1mm? In that case your steps per mm in cnc firmware are most likely defined wrong.
jwb
July 2020
jwb
July 2020
under It’s Config>Firmware EEPROM Configuration. change z res.
Sign In
or
Register
to comment.
