Cant connect to the printer raspberrypi2
edited July 2020 in General
Hi! After boot an raspberry pi i has disconnected printer from repetier-server. In log connected i can see:
Mesg:21:55:01.329: Dtr: true Rts: true
Mesg:21:55:01.330: Connection closed by os.
Mesg:21:55:03.133: Dtr: true Rts: true
I add some logs into attacheed files.
Repeiter-server 0.94.1 on raspberrypi 2
If i reconnect the USB port it work or sometimes. Reboot not work.
pi@Repetier-Server:~ $ lsusb
Bus 001 Device 005: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter - it is the board i think.
  • What color does the bolt in main menu have? Closed by os means linux disconnected the printer and undervoltage is a frequent reason for the pi to do that and the bolt color indicates that you had or have undervoltage if color is orange or red. In that case you should use a better usb power unit and make sure it is NOT a charger - chargers are normally not stable enough.
  • edited July 2020
    You meant it? see pic
    If i change the USB cable it may be will work?
  • Oh. I can see that the motheboard is broken. It not work on my laptop too.
  • I change the motherboard on srk mini v1.1 (with fresh marlin firmware). And now i have reconnect after PID autotune. If i do the motherboard is disconnect. See logs.
  • Please use ping pong mode for the test so it is easier to see which action belong to which command for the test.
    also there is no option to attach files so no log to see. Copy the relevant part plus some lines before/after into the editor here.
  • edited July 2020
    Sorry. There is the log.
    https://pastebin.com/r28yGzCX
  • Seems to be private bin - it requires user and password.
  • edited July 2020
    Hm. It work fine for me.
    After PID autotune i can connect to the motherboard. It is bug from Marlin firmware may be?
    Mesg:14:34:20.584: Warning: Communication timeout - resetting communication buffer.
    Mesg:14:34:20.585: Connection status: Buffered:0, Manual Commands: 1, Job Commands: 0
    Mesg:14:34:20.585: Buffer used:0 Enforced free byte:0 lines stored:0
    Send:14:34:20.585: M117 192.168.89.133:3344
    Recv:14:34:20.587: ok
    Recv:14:34:20.851: T:21.00 /0.00 B:21.00 /0.00 @:0 B@:0
    Recv:14:34:21.850: T:21.00 /0.00 B:22.56 /0.00 @:0 B@:0
    Recv:14:34:22.850: T:21.00 /0.00 B:21.00 /0.00 @:0 B@:0
    Recv:14:34:23.850: T:21.00 /0.00 B:21.00 /0.00 @:0 B@:0
    Recv:14:34:24.800: Slow command added:M303 E-1 S80 C8
    Send:14:34:24.800: N11 M303 E-1 S80 C8
    Recv:14:34:24.805: PID Autotune start
    Recv:14:34:24.818: T:21.00 /0.00 B:21.00 /0.00 @:0 B@:127
    Recv:14:34:26.818: T:21.00 /0.00 B:21.25 /0.00 @:0 B@:127
    Recv:14:34:28.818: T:21.00 /0.00 B:21.00 /0.00 @:0 B@:127
    Recv:14:34:30.818: T:21.00 /0.00 B:21.00 /0.00 @:0 B@:127
    Recv:14:34:32.817: T:21.00 /0.00 B:21.00 /0.00 @:0 B@:127
    Recv:14:34:34.816: T:20.75 /0.00 B:25.62 /0.00 @:0 B@:127
    Recv:14:34:36.816: T:21.25 /0.00 B:27.94 /0.00 @:0 B@:127
    Recv:14:34:38.816: T:21.00 /0.00 B:32.41 /0.00 @:0 B@:127
    Recv:14:34:40.815: T:20.37 /0.00 B:32.44 /0.00 @:0 B@:127
    Recv:14:34:42.815: T:21.00 /0.00 B:32.72 /0.00 @:0 B@:127
    Recv:14:34:44.815: T:20.87 /0.00 B:33.41 /0.00 @:0 B@:127
    Recv:14:34:46.816: T:20.87 /0.00 B:33.97 /0.00 @:0 B@:127
    Recv:14:34:48.814: T:21.25 /0.00 B:34.91 /0.00 @:0 B@:127
    Recv:14:34:50.814: T:22.25 /0.00 B:35.60 /0.00 @:0 B@:127
    Recv:14:34:52.814: T:20.87 /0.00 B:37.59 /0.00 @:0 B@:127
    Recv:14:34:54.813: T:21.00 /0.00 B:40.13 /0.00 @:0 B@:127
    Mesg:14:34:55.370: Connection closed by os.
    Mesg:14:34:56.371: Dtr: true Rts: true
    Mesg:14:34:56.372: Connection started
    Mesg:14:34:56.372: Dtr: false Rts: false
    Mesg:14:34:56.382: Dtr: true Rts: true
    Send:14:34:56.393: N12 M105
    Recv:14:34:56.815: T:23.28 /0.00 B:40.59 /0.00 @:0 B@:127
    Send:14:34:57.402: N13 M105
    Send:14:34:58.404: N14 M105
    Recv:14:34:58.813: :21.0 /0.00:42.81 /0.00@:0 B@:127
    Send:14:34:59.391: N1 M110
    Send:14:34:59.391: N2 M105
    Send:14:34:59.391: N3 M115
    Send:14:34:59.391: N4 M220 S100
    Recv:14:35:02.813: T:20.8 0:49 0.00 @:0 B@:12:100 /04.8 /0 @:0 B@:127
    Recv:14:35:04.813: T:21.00/0.00 B:50.9 @ @127
    Mesg:14:35:12.893: Dtr: true Rts: true
    Mesg:14:35:12.895: Connection started
    Mesg:14:35:12.895: Dtr: false Rts: false
    Mesg:14:35:12.906: Dtr: true Rts: true
    Send:14:35:12.917: N5 M105
    Send:14:35:13.920: N6 M105
    Recv:14:35:14.818: T:21.00 /0.00 B:52.79 /0.00 @:0 B@:127
    Send:14:35:14.929: N7 M105
    Send:14:35:15.910: N1 M110
    Send:14:35:15.910: N2 M105
    Send:14:35:15.910: N3 M115
    Send:14:35:15.910: N4 M220 S100
    Send:14:35:15.910: N5 M221 S100
    Recv:14:35:16.819: T:21.00 /0.00 B:53.92 /0.00 @:0 B@:127
    Recv:14:35:18.820: T:20.87 /0.00 B:54.90 /0.00 @:0 B@:127
    Recv:14:35:20.820: T:21.00 /0.00 B:56.84 /0.00 @:0 B@:127
    Recv:14:35:22.822: T:21.00 /0.00 B:57.84 /0.00 @:0 B@:127
    Mesg:14:35:24.515: Dtr: true Rts: true
    Mesg:14:35:24.516: Connection started
    Mesg:14:35:24.516: Dtr: false Rts: false
    Mesg:14:35:24.526: Dtr: true Rts: true
    Send:14:35:24.537: N6 M105
    Recv:14:35:24.822: T:21.00 /0.00 B:58.28 /0.00 @:0 B@:127
    Send:14:35:25.539: N7 M105
    Mesg:14:35:26.095: Connection closed by os.
    In syslog:
    Jul 23 22:13:16 Repetier-Server systemd[1]: systemd-timedated.service: Succeeded.
    Jul 23 22:13:47 Repetier-Server dbus-daemon[315]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.2021' (uid=0 pid=25918 comm="timedatectl ")
    Jul 23 22:13:47 Repetier-Server systemd[1]: Starting Time & Date Service...
    Jul 23 22:13:47 Repetier-Server dbus-daemon[315]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Jul 23 22:13:47 Repetier-Server systemd[1]: Started Time & Date Service.
    Jul 23 22:14:17 Repetier-Server systemd[1]: systemd-timedated.service: Succeeded.
    Jul 23 22:14:35 Repetier-Server kernel: [27702.314295] usb 1-1.1.2: reset full-speed USB device number 10 using dwc_otg
    Jul 23 22:14:35 Repetier-Server kernel: [27702.446057] cdc_acm 1-1.1.2:1.1: ttyACM0: USB ACM device
    Jul 23 22:14:49 Repetier-Server dbus-daemon[315]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.2025' (uid=0 pid=26029 comm="timedatectl ")
    Jul 23 22:14:49 Repetier-Server systemd[1]: Starting Time & Date Service...
    Jul 23 22:14:49 Repetier-Server dbus-daemon[315]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Jul 23 22:14:49 Repetier-Server systemd[1]: Started Time & Date Service.
    Jul 23 22:14:52 Repetier-Server ModemManager[325]: <info>  [device /sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.2] creating modem with plugin 'Generic' and '1' ports
    Jul 23 22:14:52 Repetier-Server ModemManager[325]: <warn>  Could not grab port (tty/ttyACM0): 'Cannot add port 'tty/ttyACM0', unhandled serial type'
    Jul 23 22:14:52 Repetier-Server ModemManager[325]: <warn>  Couldn't create modem for device '/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.2': Failed to find primary AT port
  • If you check the log you see that for the M117 you got a ok but the M303 started and but there are onky a few temperatures and never an ok so it was not finished or did you remove some lines here.
    then there was obviously a diesconnection - was that you or did the printer this on it‘s own.
    Then on reconnect i see no printer response and a new disconnect. So question again you or does something go wrong?
  • edited July 2020
    I can see that the printer have disconnect. I have not see the temperature. And i can not see Kp Ki and Kd for save to EEEProm.
  • I see you should remove modemmanager which interferes with serial.
    sudo apt remove modemmanager
  • Your syslog does not cover the time of the log so there is no connection visible also i saw that linux did reset the serial. Main question to solve here is if linux disconnectes due to power problems or if it is your firmware.
    Are you on 0.94.1? There you should see if you get undervoltage from time to time in the bolt icon. That would be a sign that linux does disconnect and you could e.g. disable powering the printer over usb to solve this as shown in our faq.
    Yes. I have 0.94.1 Power is Ok everytime. Now i do sudo apt remove modemmanager. It work more OK - i can see the Kp Ki and Kd but it has disconnect. Logs here: https://dropmefiles.com/kjWOx
