Can't start print with Sidewinder X1
Hi everybody,
I'm new to Repetier Server and already got my first problem.
I successfully configured my Anycubic I3 Mega with the server, but now I have probelms with my second printer.
I've uploaded the gcode to the server and try to start the print. The temperatures go up and nothing happens after that. There isn't any error message or hint what went wrong. It just heats up and that's it. Only message I get is HOTEND IS TOO COLD in the beginning!
The same gcode works without problems if I print it directly from the printer.
I have Marlin 2.0.5.3 firmware o the printer.
Thanks for your help.
Mesg:16:11:57.851: Dtr: true Rts: true
Mesg:16:11:57.856: Connection started
Mesg:16:11:57.856: Dtr: false Rts: false
Mesg:16:11:57.868: Dtr: true Rts: true
Recv:16:11:57.875: echo:Unknown command: ""
Recv:16:11:57.875: Response while unconnected:ok
Recv:16:11:57.886: ok
Send:16:11:57.886: N1 M110
Send:16:11:57.887: N3 M115
Send:16:11:57.887: N4 M220 S100
Send:16:11:57.887: N5 M221 S100
Send:16:11:57.887: N6 G92 E0
Send:16:11:57.887: N7 G90
Send:16:11:57.887: N8 M82
Recv:16:11:57.891: ok
Send:16:11:57.891: N9 G21
Send:16:11:57.891: @getip
Recv:16:11:57.903: FIRMWARE_NAME:Marlin 2.0.5.3 (GitHub) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:Sidewinder X1 EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
Recv:16:11:57.904: Cap:SERIAL_XON_XOFF:0
Recv:16:11:57.905: Cap:BINARY_FILE_TRANSFER:0
Recv:16:11:57.906: Cap:EEPROM:1
Recv:16:11:57.907: Cap:VOLUMETRIC:1
Recv:16:11:57.907: Cap:AUTOREPORT_TEMP:1
Recv:16:11:57.908: Cap:PROGRESS:0
Recv:16:11:57.908: Cap:PRINT_JOB:1
Recv:16:11:57.909: Cap:AUTOLEVEL:1
Recv:16:11:57.909: Cap:Z_PROBE:1
Recv:16:11:57.910: Cap:LEVELING_DATA:1
Recv:16:11:57.912: Cap:BUILD_PERCENT:0
Recv:16:11:57.912: Cap:SOFTWARE_POWER:0
Recv:16:11:57.913: Cap:TOGGLE_LIGHTS:0
Recv:16:11:57.914: Cap:CASE_LIGHT_BRIGHTNESS:0
Recv:16:11:57.916: Cap:EMERGENCY_PARSER:1
Recv:16:11:57.916: Cap:PROMPT_SUPPORT:0
Recv:16:11:57.917: Cap:AUTOREPORT_SD_STATUS:0
Recv:16:11:57.920: Cap:THERMAL_PROTECTION:1
Recv:16:11:57.921: Cap:MOTION_MODES:0
Recv:16:11:57.922: Cap:CHAMBER_TEMPERATURE:0
Recv:16:11:57.922: ok (3)
Send:16:11:57.922: M117 192.168.178.80:3344
Send:16:11:57.922: N11 M155 S1
Recv:16:11:57.923: X:0.00 Y:-5.00 Z:0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:11:57.933: ok (6)
Recv:16:11:59.653: echo:Bed Leveling ON
Recv:16:11:59.654: echo:Fade Height 2.00
Recv:16:11:59.655: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:11:59.657: ok
Recv:16:12:02.547: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:12:02.547: ok
Recv:16:12:04.551: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:12:04.551: ok
Recv:16:12:06.561: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:12:06.561: ok
Recv:16:12:08.571: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:12:08.571: ok
Recv:16:12:10.581: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:12:10.581: ok
Recv:16:12:12.591: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:12:12.591: ok
Send:16:12:12.875: @getip
Send:16:12:12.880: M117 192.168.178.80:3344
Recv:16:12:12.883: ok
Recv:16:12:14.601: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:12:14.601: ok
Recv:16:12:16.611: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:12:16.611: ok
Recv:16:12:18.621: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:12:18.621: ok
Recv:16:12:20.631: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:12:20.631: ok
Recv:16:12:22.641: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:12:22.641: ok
Recv:16:12:24.651: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:12:24.651: ok
Recv:16:12:26.661: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:12:26.661: ok
Recv:16:12:28.671: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:12:28.671: ok
Recv:16:12:30.681: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:12:30.681: ok
Recv:16:12:32.691: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:12:32.691: ok
Recv:16:12:34.701: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:12:34.701: ok
Recv:16:12:36.711: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:12:36.711: ok
Recv:16:12:38.721: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:12:38.721: ok
Recv:16:12:40.731: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:12:40.731: ok
Recv:16:12:42.741: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:12:42.742: ok
Recv:16:12:44.751: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:12:44.752: ok
Recv:16:12:46.761: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:12:46.761: ok
Recv:16:12:48.771: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:12:48.772: ok
Recv:16:12:50.781: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:12:50.781: ok
Recv:16:12:52.791: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:12:52.792: ok
Recv:16:12:54.801: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:12:54.801: ok
Recv:16:12:56.811: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:12:56.812: ok
Recv:16:12:58.821: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:12:58.821: ok
Recv:16:13:00.831: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:13:00.832: ok
Recv:16:13:02.841: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:13:02.842: ok
Recv:16:13:04.851: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:13:04.852: ok
Recv:16:13:06.861: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:13:06.862: ok
Recv:16:13:08.871: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:13:08.872: ok
Recv:16:13:10.881: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:13:10.881: ok
Recv:16:13:12.891: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:13:12.891: ok
Recv:16:13:14.901: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:13:14.901: ok
Recv:16:13:16.911: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:13:16.912: ok
Recv:16:13:18.921: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:13:18.921: ok
Recv:16:13:20.935: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:13:20.935: ok
Recv:16:13:22.941: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:13:22.941: ok
Recv:16:13:24.951: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:13:24.952: ok
Recv:16:13:26.961: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:13:26.962: ok
Recv:16:13:28.971: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:13:28.972: ok
Recv:16:13:30.981: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:13:30.981: ok
Recv:16:13:32.992: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:13:32.992: ok
Recv:16:13:35.002: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:13:35.002: ok
Recv:16:13:37.012: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:13:37.012: ok
Recv:16:13:39.022: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:13:39.022: ok
Recv:16:13:41.032: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
Recv:16:13:41.032: ok
Send:16:13:41.476: N12 M73 P0 R118 Q0 S118
Recv:16:13:41.481: echo:Unknown command: "M73 P0 R118 Q0 S118"
Recv:16:13:41.481: ok
Send:16:13:41.512: N13 G90
Send:16:13:41.512: N14 M82
Send:16:13:41.512: N15 M106 S0
Send:16:13:41.512: N16 M140 S65
Recv:16:13:41.512: Slow command added:M190 S65
Send:16:13:41.512: N17 M190 S65
Send:16:13:41.512: N18 M104 S225 T0
Recv:16:13:41.519: ok (4)
Recv:16:13:41.519: Slow command added:M109 S225 T0
Send:16:13:41.519: N19 M109 S225 T0
Send:16:13:41.519: N20 G21 ;metric values
Send:16:13:41.519: N21 G90 ;absolute positioning
Send:16:13:41.520: N22 M82 ;set extruder to absolute mode
Recv:16:13:41.520: Slow command added:G28 ;Homing
Send:16:13:41.520: N23 G28 ;Homing
Recv:16:15:25.512: echo:busy: processing (52)
Recv:16:15:25.821: ok
Recv:16:15:25.821: echo:Hotend too cold
Recv:16:15:25.821: ok (2)
Send:16:15:25.821: M117 ETA 17:59:27 day 16
Send:16:15:25.821: N24 M420 S1 Z2 ;Mesh Bed Levelling laden
Recv:16:17:59.817: echo:busy: processing (77)
Recv:16:15:25.520: T:23.48 /0.00 B:66.82 /65.00 @:0 B@:75 W:0
Recv:16:15:25.829: T:22.42 /225.00 B:66.66 /65.00 @:0 B@:79 W:?
Recv:16:15:25.932: T:22.42 /225.00 B:66.66 /65.00 @:0 B@:79
Recv:16:15:26.829: T:22.38 /225.00 B:66.76 /65.00 @:127 B@:74 W:?
Recv:16:15:26.932: T:22.38 /225.00 B:66.76 /65.00 @:127 B@:74
Recv:16:15:27.821: echo:busy: processing
Recv:16:15:27.827: T:23.32 /225.00 B:67.14 /65.00 @:127 B@:62 W:?
Recv:16:15:27.932: T:23.32 /225.00 B:67.14 /65.00 @:127 B@:62
Recv:16:15:28.829: T:23.83 /225.00 B:67.14 /65.00 @:127 B@:59 W:?
Recv:16:15:28.932: T:23.83 /225.00 B:67.14 /65.00 @:127 B@:59
Mesg:16:20:41.903: Dtr: false Rts: false
Mesg:16:20:41.915: Dtr: true Rts: true
Recv:16:20:41.921: T:231.69 /225.00 B:65.10 /65.00 @:0 B@:15
Send:16:20:41.922: N25 M112
Recv:16:20:41.926: Response while unconnected:Error:Printer halted. kill() called!
Mesg:16:20:41.926: Firmware stopped! You can only send host and shell commands until you hit emergency stop or restart the printer. Eventually running print is stopped.
Recv:16:20:41.927: Error:Printer halted. kill() called!
Mesg:16:20:44.920: Firmware stopped! You can only send host and shell commands until you hit emergency stop or restart the printer.
Mesg:16:20:44.921: Firmware stopped! You can only send host and shell commands until you hit emergency stop or restart the printer.
Mesg:16:20:44.922: Firmware stopped! You can only send host and shell commands until you hit emergency stop or restart the printer.
Send:16:20:44.922: @getip
Mesg:16:20:44.927: Firmware stopped! You can only send host and shell commands until you hit emergency stop or restart the printer.
Mesg:16:20:48.203: Firmware stopped! You can only send host and shell commands until you hit emergency stop or restart the printer.
Du kannst noch mit
M111 S7
echo vn der Firmware aktivieren, dann siehst du was die Firmware denkt bekommen zu haben.
was du ab 16:20 gemacht hast hat denke ich nichts damit zu tun - sieht jedenfalls wie ein emergency reset aus.
Send: 8:40:58.971: N13 G90
Send: 8:40:58.972: N14 M73 P0 R16 Q0 S16
Send: 8:40:58.972: N15 M82
Send: 8:40:58.972: N16 M106 S0
Send: 8:40:58.973: N17 M140 S65
Recv: 8:40:58.975: echo:DEBUG:ECHO,INFO,ERRORS
Recv: 8:40:58.975: ok
Recv: 8:40:58.975: Slow command added:M190 S65
Send: 8:40:58.976: N18 M190 S65
Recv: 8:40:58.976: echo:N13 G90*34
Recv: 8:40:58.977: ok
Recv: 8:40:58.978: echo:N14 M73 P0 R16 Q0 S16*34
Recv: 8:40:58.979: echo:Unknown command: "M73 P0 R16 Q0 S16"
Recv: 8:40:58.980: ok
Send: 8:40:58.980: N19 M104 S225 T0
Recv: 8:40:58.980: Slow command added:M109 S225 T0
Send: 8:40:58.980: N20 M109 S225 T0
Recv: 8:40:58.980: echo:N15 M82*45
Recv: 8:40:58.981: ok
Send: 8:40:58.981: N21 G21 ;metric values
Recv: 8:40:58.982: echo:N16 M106 S0*80
Recv: 8:40:58.982: ok
Recv: 8:40:58.983: echo:N17 M140 S65*96
Send: 8:40:58.983: N22 G90 ;absolute positioning
Recv: 8:40:58.984: ok
Recv: 8:40:58.984: echo:N18 M190 S65*98
Send: 8:40:58.985: N23 M82 ;set extruder to absolute mode
Recv: 8:40:58.985: Slow command added:G28 ;Homing
Send: 8:40:58.985: N24 G28 ;Homing
Recv: 8:42:44.981: echo:busy: processing
Recv: 8:42:44.990: T:22.77 /0.00 B:65.81 /65.00 @:0 B@:100 W:3
Recv: 8:42:45.459: T:23.05 /0.00 B:65.93 /65.00 @:0 B@:98
Recv: 8:42:45.989: T:23.87 /0.00 B:66.10 /65.00 @:0 B@:94 W:2
Recv: 8:42:46.459: T:24.02 /0.00 B:66.27 /65.00 @:0 B@:90
Recv: 8:42:46.981: echo:busy: processing
Recv: 8:42:46.990: T:24.53 /0.00 B:66.39 /65.00 @:0 B@:87 W:1
Recv: 8:42:47.459: T:24.84 /0.00 B:66.55 /65.00 @:0 B@:83
Recv: 8:42:47.989: T:22.62 /0.00 B:66.21 /65.00 @:0 B@:92 W:0
Recv: 8:42:48.459: T:23.52 /0.00 B:66.78 /65.00 @:0 B@:76
Recv: 8:42:48.971: ok
Recv: 8:42:48.971: echo:Hotend too cold
Recv: 8:42:48.972: ok
Send: 8:42:48.972: M117 ETA 08:44:12 day 17
Recv: 8:42:48.973: echo:N19 M104 S225 T0*28
Recv: 8:42:48.973: ok
Send: 8:42:48.973: N25 M420 S1 Z2 ;Mesh Bed Levelling laden
Recv: 8:42:48.975: echo:N20 M109 S225 T0*27
Mesg: 8:47:54.257: Connection closed by os.
Und danach schließst linux die Verbindung - oder wurde der Drucker da getrennt?
Normal müssten ja weiter temperaturmeldungen kommen aber alles was noch kommt ist ein Verbindungsabbruch weil das Gerät nicht mehr da ist. Sieht serverseitig richtig aus nur das die Firmware plötzlich dicht zu machen scheint. Da kann ich leider nicht viel zu sagen. So was hatte ich nich nicht.
Das ist jetzt natürlich sehr unglücklich, wenn es nicht funktioniert. Ich bin von Octoprint zu Repetier gewechselt, weil ich alles über einen Knoten bedienen wollte. Jetzt habe ich quasi das Geld dafür ausgegeben, dass ich wie vorher mit Octoprint nur einen Drucker steuern kann.
Have you been able to find a fix for the issue?
I'm facing the very same problem than you, and since I don't want to go back to Octoprint which has serial/usb disconnections w/ the sidewinder x1 due to low buffer, particularly when print speed is fast like +120mm/s, even when compiling a firmware (1.1.9 or latest 2.0.x) with increased buffers available on thingiverse.
That's why the fact that repetier does not use ping/pong protocol could be a great fix for my use-case.
Thanks.
