Can't start print with Sidewinder X1
Hi everybody,
I'm new to Repetier Server and already got my first problem.
I successfully configured my Anycubic I3 Mega with the server, but now I have probelms with my second printer.
I've uploaded the gcode to the server and try to start the print. The temperatures go up and nothing happens after that. There isn't any error message or hint what went wrong. It just heats up and that's it. Only message I get is HOTEND IS TOO COLD in the beginning!
The same gcode works without problems if I print it directly from the printer.
I have Marlin 2.0.5.3 firmware o the printer.
Thanks for your help.
  • Would that block communication or go to error mode ignoring commands? You need to log and check what is happening there in log to see what happens. But we don‘t send different commands then you give us. At least we try not to. Would also be visible in log.
  • Ich habe gesehen, dass wir es ja mit einer deutschen Firma zu tun haben, also kann ich auch in Deutsch schreiben, was das alles einfacher machen sollte.
    Ich habe jetzt extra nochmals einen neuen Druck angeworfen, damit es ein sauberes Log gibt.
    Hier ist der Inhalt der Konsole während des Drucks:
    Mesg:16:11:57.851: Dtr: true Rts: true
    Mesg:16:11:57.856: Connection started
    Mesg:16:11:57.856: Dtr: false Rts: false
    Mesg:16:11:57.868: Dtr: true Rts: true
    Recv:16:11:57.875: echo:Unknown command: ""
    Recv:16:11:57.875: Response while unconnected:ok
    Recv:16:11:57.886: ok
    Send:16:11:57.886: N1 M110
    Send:16:11:57.887: N3 M115
    Send:16:11:57.887: N4 M220 S100
    Send:16:11:57.887: N5 M221 S100
    Send:16:11:57.887: N6 G92 E0
    Send:16:11:57.887: N7 G90
    Send:16:11:57.887: N8 M82
    Recv:16:11:57.891: ok
    Send:16:11:57.891: N9 G21
    Send:16:11:57.891: @getip
    Recv:16:11:57.903: FIRMWARE_NAME:Marlin 2.0.5.3 (GitHub) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:Sidewinder X1 EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
    Recv:16:11:57.904: Cap:SERIAL_XON_XOFF:0
    Recv:16:11:57.905: Cap:BINARY_FILE_TRANSFER:0
    Recv:16:11:57.906: Cap:EEPROM:1
    Recv:16:11:57.907: Cap:VOLUMETRIC:1
    Recv:16:11:57.907: Cap:AUTOREPORT_TEMP:1
    Recv:16:11:57.908: Cap:PROGRESS:0
    Recv:16:11:57.908: Cap:PRINT_JOB:1
    Recv:16:11:57.909: Cap:AUTOLEVEL:1
    Recv:16:11:57.909: Cap:Z_PROBE:1
    Recv:16:11:57.910: Cap:LEVELING_DATA:1
    Recv:16:11:57.912: Cap:BUILD_PERCENT:0
    Recv:16:11:57.912: Cap:SOFTWARE_POWER:0
    Recv:16:11:57.913: Cap:TOGGLE_LIGHTS:0
    Recv:16:11:57.914: Cap:CASE_LIGHT_BRIGHTNESS:0
    Recv:16:11:57.916: Cap:EMERGENCY_PARSER:1
    Recv:16:11:57.916: Cap:PROMPT_SUPPORT:0
    Recv:16:11:57.917: Cap:AUTOREPORT_SD_STATUS:0
    Recv:16:11:57.920: Cap:THERMAL_PROTECTION:1
    Recv:16:11:57.921: Cap:MOTION_MODES:0
    Recv:16:11:57.922: Cap:CHAMBER_TEMPERATURE:0
    Recv:16:11:57.922: ok (3)
    Send:16:11:57.922: M117 192.168.178.80:3344
    Send:16:11:57.922: N11 M155 S1
    Recv:16:11:57.923: X:0.00 Y:-5.00 Z:0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:11:57.933: ok (6)
    Recv:16:11:59.653: echo:Bed Leveling ON
    Recv:16:11:59.654: echo:Fade Height 2.00
    Recv:16:11:59.655: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:11:59.657: ok
    Recv:16:12:02.547: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:12:02.547: ok
    Recv:16:12:04.551: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:12:04.551: ok
    Recv:16:12:06.561: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:12:06.561: ok
    Recv:16:12:08.571: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:12:08.571: ok
    Recv:16:12:10.581: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:12:10.581: ok
    Recv:16:12:12.591: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:12:12.591: ok
    Send:16:12:12.875: @getip
    Send:16:12:12.880: M117 192.168.178.80:3344
    Recv:16:12:12.883: ok
    Recv:16:12:14.601: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:12:14.601: ok
    Recv:16:12:16.611: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:12:16.611: ok
    Recv:16:12:18.621: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:12:18.621: ok
    Recv:16:12:20.631: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:12:20.631: ok
    Recv:16:12:22.641: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:12:22.641: ok
    Recv:16:12:24.651: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:12:24.651: ok
    Recv:16:12:26.661: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:12:26.661: ok
    Recv:16:12:28.671: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:12:28.671: ok
    Recv:16:12:30.681: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:12:30.681: ok
    Recv:16:12:32.691: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:12:32.691: ok
    Recv:16:12:34.701: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:12:34.701: ok
    Recv:16:12:36.711: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:12:36.711: ok
    Recv:16:12:38.721: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:12:38.721: ok
    Recv:16:12:40.731: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:12:40.731: ok
    Recv:16:12:42.741: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:12:42.742: ok
    Recv:16:12:44.751: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:12:44.752: ok
    Recv:16:12:46.761: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:12:46.761: ok
    Recv:16:12:48.771: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:12:48.772: ok
    Recv:16:12:50.781: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:12:50.781: ok
    Recv:16:12:52.791: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:12:52.792: ok
    Recv:16:12:54.801: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:12:54.801: ok
    Recv:16:12:56.811: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:12:56.812: ok
    Recv:16:12:58.821: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:12:58.821: ok
    Recv:16:13:00.831: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:13:00.832: ok
    Recv:16:13:02.841: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:13:02.842: ok
    Recv:16:13:04.851: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:13:04.852: ok
    Recv:16:13:06.861: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:13:06.862: ok
    Recv:16:13:08.871: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:13:08.872: ok
    Recv:16:13:10.881: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:13:10.881: ok
    Recv:16:13:12.891: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:13:12.891: ok
    Recv:16:13:14.901: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:13:14.901: ok
    Recv:16:13:16.911: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:13:16.912: ok
    Recv:16:13:18.921: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:13:18.921: ok
    Recv:16:13:20.935: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:13:20.935: ok
    Recv:16:13:22.941: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:13:22.941: ok
    Recv:16:13:24.951: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:13:24.952: ok
    Recv:16:13:26.961: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:13:26.962: ok
    Recv:16:13:28.971: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:13:28.972: ok
    Recv:16:13:30.981: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:13:30.981: ok
    Recv:16:13:32.992: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:13:32.992: ok
    Recv:16:13:35.002: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:13:35.002: ok
    Recv:16:13:37.012: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:13:37.012: ok
    Recv:16:13:39.022: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:13:39.022: ok
    Recv:16:13:41.032: X:0.00 Y:-5.00 Z:-0.00 E:0.00 Count X:0 Y:-400 Z:0
    Recv:16:13:41.032: ok
    Send:16:13:41.476: N12 M73 P0 R118 Q0 S118
    Recv:16:13:41.481: echo:Unknown command: "M73 P0 R118 Q0 S118"
    Recv:16:13:41.481: ok
    Send:16:13:41.512: N13 G90
    Send:16:13:41.512: N14 M82
    Send:16:13:41.512: N15 M106 S0
    Send:16:13:41.512: N16 M140 S65
    Recv:16:13:41.512: Slow command added:M190 S65
    Send:16:13:41.512: N17 M190 S65
    Send:16:13:41.512: N18 M104 S225 T0
    Recv:16:13:41.519: ok (4)
    Recv:16:13:41.519: Slow command added:M109 S225 T0
    Send:16:13:41.519: N19 M109 S225 T0
    Send:16:13:41.519: N20 G21 ;metric values
    Send:16:13:41.519: N21 G90 ;absolute positioning
    Send:16:13:41.520: N22 M82 ;set extruder to absolute mode
    Recv:16:13:41.520: Slow command added:G28 ;Homing
    Send:16:13:41.520: N23 G28 ;Homing
    Recv:16:15:25.512: echo:busy: processing (52)
    Recv:16:15:25.821: ok
    Recv:16:15:25.821: echo:Hotend too cold
    Recv:16:15:25.821: ok (2)
    Send:16:15:25.821: M117 ETA 17:59:27 day 16
    Send:16:15:25.821: N24 M420 S1 Z2 ;Mesh Bed Levelling laden
    Recv:16:17:59.817: echo:busy: processing (77)
    Er wirft quasi den Fehler HOTEND TOO COLD aus, sobald das Bett mit dem Aufheizen fertig ist, und die Düse aufheizt.
    Dann heizt er bis zur gewünschten Temperatur und nichts passiert mehr.
    Wenn ich auf STOP drücke, bleibt die Temperatur oben, ohne das er den Heizvorgang unterbricht. Ich kann dann nur den Drucker aus- und wieder einschalten, da er nicht mehr auf die Konsole reagiert.
    Hier ein Auszug aus dem Drucklog (ich habe die Processing Infos rausgeworfen um es überschaulicher zu halten:
    Recv:16:15:25.520:  T:23.48 /0.00 B:66.82 /65.00 @:0 B@:75 W:0
    Recv:16:15:25.829:  T:22.42 /225.00 B:66.66 /65.00 @:0 B@:79 W:?
    Recv:16:15:25.932:  T:22.42 /225.00 B:66.66 /65.00 @:0 B@:79
    Recv:16:15:26.829:  T:22.38 /225.00 B:66.76 /65.00 @:127 B@:74 W:?
    Recv:16:15:26.932:  T:22.38 /225.00 B:66.76 /65.00 @:127 B@:74
    Recv:16:15:27.821: echo:busy: processing
    Recv:16:15:27.827:  T:23.32 /225.00 B:67.14 /65.00 @:127 B@:62 W:?
    Recv:16:15:27.932:  T:23.32 /225.00 B:67.14 /65.00 @:127 B@:62
    Recv:16:15:28.829:  T:23.83 /225.00 B:67.14 /65.00 @:127 B@:59 W:?
    Recv:16:15:28.932:  T:23.83 /225.00 B:67.14 /65.00 @:127 B@:59
    Mesg:16:20:41.903: Dtr: false Rts: false
    Mesg:16:20:41.915: Dtr: true Rts: true
    Recv:16:20:41.921:  T:231.69 /225.00 B:65.10 /65.00 @:0 B@:15
    Send:16:20:41.922: N25 M112
    Recv:16:20:41.926: Response while unconnected:Error:Printer halted. kill() called!
    Mesg:16:20:41.926: Firmware stopped! You can only send host and shell commands until you hit emergency stop or restart the printer. Eventually running print is stopped.
    Recv:16:20:41.927: Error:Printer halted. kill() called!
    Mesg:16:20:44.920: Firmware stopped! You can only send host and shell commands until you hit emergency stop or restart the printer.
    Mesg:16:20:44.921: Firmware stopped! You can only send host and shell commands until you hit emergency stop or restart the printer.
    Mesg:16:20:44.922: Firmware stopped! You can only send host and shell commands until you hit emergency stop or restart the printer.
    Send:16:20:44.922: @getip
    Mesg:16:20:44.927: Firmware stopped! You can only send host and shell commands until you hit emergency stop or restart the printer.
    Mesg:16:20:48.203: Firmware stopped! You can only send host and shell commands until you hit emergency stop or restart the printer.
  • Also die Meldung kommt klar von der Firmware und das Hotend ist ja kalt, aber du hast ja gesendet er soll es aufheizen und warten. Da mavht die Firmware was falsch. Wenn wir annhemen das er das warten auf die Extrudertemperatur ignoriert - kann es sein das Homing nur mit heißem extruder klappt und die Meldung daher kommt? Manche Drucker brauchen das ja wirklich so.
    Du kannst noch mit
    M111 S7
    echo vn der Firmware aktivieren, dann siehst du was die Firmware denkt bekommen zu haben.
    was du ab 16:20 gemacht hast hat denke ich nichts damit zu tun - sieht jedenfalls wie ein emergency reset aus.
  • Falls es wirklich die Firmware sein sollte, wie kommt es dann, dass der gleiche Code funktioniert, wenn ich ihn per USB direkt am Drucker ausführe? Sollte er dann nicht das gleiche Problem haben?
  • Eigentlich ja. Darum ja der Test mit dem echo um zu sehen was wirklich ankommt in der Firmware.
  • Hier das Log mit M111 S7 aktiviert:
    Send: 8:40:58.971: N12 M111 S7
    Send: 8:40:58.971: N13 G90
    Send: 8:40:58.972: N14 M73 P0 R16 Q0 S16
    Send: 8:40:58.972: N15 M82
    Send: 8:40:58.972: N16 M106 S0
    Send: 8:40:58.973: N17 M140 S65
    Recv: 8:40:58.975: echo:DEBUG:ECHO,INFO,ERRORS
    Recv: 8:40:58.975: ok
    Recv: 8:40:58.975: Slow command added:M190 S65
    Send: 8:40:58.976: N18 M190 S65
    Recv: 8:40:58.976: echo:N13 G90*34
    Recv: 8:40:58.977: ok
    Recv: 8:40:58.978: echo:N14 M73 P0 R16 Q0 S16*34
    Recv: 8:40:58.979: echo:Unknown command: "M73 P0 R16 Q0 S16"
    Recv: 8:40:58.980: ok
    Send: 8:40:58.980: N19 M104 S225 T0
    Recv: 8:40:58.980: Slow command added:M109 S225 T0
    Send: 8:40:58.980: N20 M109 S225 T0
    Recv: 8:40:58.980: echo:N15 M82*45
    Recv: 8:40:58.981: ok
    Send: 8:40:58.981: N21 G21 ;metric values
    Recv: 8:40:58.982: echo:N16 M106 S0*80
    Recv: 8:40:58.982: ok
    Recv: 8:40:58.983: echo:N17 M140 S65*96
    Send: 8:40:58.983: N22 G90 ;absolute positioning
    Recv: 8:40:58.984: ok
    Recv: 8:40:58.984: echo:N18 M190 S65*98
    Send: 8:40:58.985: N23 M82 ;set extruder to absolute mode
    Recv: 8:40:58.985: Slow command added:G28 ;Homing
    Send: 8:40:58.985: N24 G28 ;Homing
    Recv: 8:42:44.981: echo:busy: processing
    Recv: 8:42:44.990:  T:22.77 /0.00 B:65.81 /65.00 @:0 B@:100 W:3
    Recv: 8:42:45.459:  T:23.05 /0.00 B:65.93 /65.00 @:0 B@:98
    Recv: 8:42:45.989:  T:23.87 /0.00 B:66.10 /65.00 @:0 B@:94 W:2
    Recv: 8:42:46.459:  T:24.02 /0.00 B:66.27 /65.00 @:0 B@:90
    Recv: 8:42:46.981: echo:busy: processing
    Recv: 8:42:46.990:  T:24.53 /0.00 B:66.39 /65.00 @:0 B@:87 W:1
    Recv: 8:42:47.459:  T:24.84 /0.00 B:66.55 /65.00 @:0 B@:83
    Recv: 8:42:47.989:  T:22.62 /0.00 B:66.21 /65.00 @:0 B@:92 W:0
    Recv: 8:42:48.459:  T:23.52 /0.00 B:66.78 /65.00 @:0 B@:76
    Recv: 8:42:48.971: ok
    Recv: 8:42:48.971: echo:Hotend too cold
    Recv: 8:42:48.972: ok
    Send: 8:42:48.972: M117 ETA 08:44:12 day 17
    Recv: 8:42:48.973: echo:N19 M104 S225 T0*28
    Recv: 8:42:48.973: ok
    Send: 8:42:48.973: N25 M420 S1 Z2 ;Mesh Bed Levelling laden
    Recv: 8:42:48.975: echo:N20 M109 S225 T0*27
    Mesg: 8:47:54.257: Connection closed by os.
    Ich weiß nicht woher der M73 Befehl am Anfang kommt? Ist das vom Repetier Server? In meinem Startcode steht er nicht drin. Wenn ich das Log richtig verstehe, dann macht er quasi bis zum Fehler alles richtig. Aber warum wirft er das HOTEND TOO COLD direkt nach dem Aufzeizen des Bettes aus, wenn da kein Befehl erfolgt irgendwas zu tun? Der Befehl zum Aufheizen der Nozzle kommt ja erst danach. Und warum macht er dann nicht mehr weiter?
  • Also das M73 kommt von uns und wird nicht von allen Marlin versionen unterstützt, das ist ok, Wird auch nur einmal gesendet dann weiß der server das er den nicht kennt. Die Fehlermeldung kommt noch bevor er den M104 Befehl bearbeitet hat oder direkt beim setzen. Weiß nicht ob echo vor oder nach ausführen kommt.
    Und danach schließst linux die Verbindung - oder wurde der Drucker da getrennt?
    Normal müssten ja weiter temperaturmeldungen kommen aber alles was noch kommt ist ein Verbindungsabbruch weil das Gerät nicht mehr da ist. Sieht serverseitig richtig aus nur das die Firmware plötzlich dicht zu machen scheint. Da kann ich leider nicht viel zu sagen. So was hatte ich nich nicht.
  • Die ganzen Temperaturmeldungen habe ich rausgeworfen, damit das Logfile nicht so lang wird.
    Man kann dort nur sehen, wie die Temperaturen wie gewünscht ansteigen und mehr auch nicht.
    Nach der vorletzten Zeile habe ich versucht über den STOP Knopf die Heizphase zu beenden, was aber nicht mehr funktioniert. Also mußte ich den Drucker wieder am Powerknopf ausschalten.
    Das ist jetzt natürlich sehr unglücklich, wenn es nicht funktioniert. Ich bin von Octoprint zu Repetier gewechselt, weil ich alles über einen Knoten bedienen wollte. Jetzt habe ich quasi das Geld dafür ausgegeben, dass ich wie vorher mit Octoprint nur einen Drucker steuern kann. :'(
  • So wie du das beschreibst führt er das M109 also aus und wartet auf die Zieltemperatur. Schafft er es sie zu erreichen? Hört sich ja erst einmal gut an. M109 blockiert firmware bis sie zufrieden mit der Zieltemperatur ist, danach macht sie weiter. Hört sich also an als ob die cold meldung ignoriert werden kann. Je nach Komfiguration muss die Temperatur für eine weile Stabil in einem Korridor liegen. Das ist aber firmware intern da hab ich keine Kontrolle drüber. Hört sich für mich also bisher gut an da du ja jetzt sagst das du den reset ausgeführt hast und temperaturen ansteigen. Sobald marlin also M109 beendet und mit ok bestätigt sollte es weiter gehen. Server klappt ja eigentlich mit Marlin problemlos.
  • Vielleicht zeigst du mal wie es weiter geht mit wait/busy oder was auch immer noch danach kommt.
  • Hello @copperfield74
    Have you been able to find a fix for the issue?
    I'm facing the very same problem than you, and since I don't want to go back to Octoprint which has serial/usb disconnections w/ the sidewinder x1 due to low buffer, particularly when print speed is fast like +120mm/s, even when compiling a firmware (1.1.9 or latest 2.0.x) with increased buffers available on thingiverse.
    That's why the fact that repetier does not use ping/pong protocol could be a great fix for my use-case.
    Thanks.
