PrusaSlicer 2.2.0 new Filament Overrides on multi extruder
Repetier-Host 2.1.6 + PrusaSlicer 2.2.0
'filament_retract_length = nil' should be 'filament_retract_length = nil,2' on slic3r_settings.ini
http://www.mot.net.tw/temp/SNAG-0002.png
  • What do you want to show with the image? grid is not supported for override at the moment.
    Regarding filament_retract_length I see the problem. It did not see it is a filament attribute as it is newer then when I created it. Also saw that the new condition language is not understood to reduce filaments to selection. So some more work for me making it work again.
  • Sorry for wrong image url. The correct url is http://www.mot.net.tw/temp/SNAG-0002.png
  • Ok. Already figured that out. Should work in next release.
  • Thanks. All options in Filament Settings should be multiple values in slic3r_settings.ini.
    Is there any date for next release?
  • I hope to make it in september.
