Everything seems to be working. Until I hit print.
Im sure this has been resolved somewhere, if so link me over. I am running a Ramps 1.4 board with arduino mega in windows 8. The extruder motor isnt working yet but lets solve one problem at a time. I have set up Repetier Host/ firmware V1.0.6 and all of the manual control are working i can move the X axis Y axis and Z axis manually (no endstops so the home buttons don't work) I can enter G92 code to set the zero position, then manually enter G1 codes to move the extruder to the correct place, then G1 X0 Y0 Z0 moves everything back correctly. However, when I load a STL slice it, edit the G28 commands out of the Gcode (no endstops) then press print. The host says printing but nothing happens. so I think "well maybe the hot end needs to be active and heated up" so I turn off dryrun turn the extruder on, it heats up I can see the temperature, Still printing but nothing is happening. FYI I can manually heat up the extruder as well.
Alex
