Extruder is not pulling as much filament as it should.
Hello!
I have problem with my printer . I'm using it for about 1.5 year and extruder stopped pulling filament, for example when I want to extrude 100mm of filament it only pulls about 16mm. Electronic of E axis is set at 847. I Can't find any solution to this problem, maybe you will be able to help. Thanks.
  • Sounds like the steps per mm are not correct. Maybe the microstep switch has changed? Also in host the flow control can change it but that gets set to 100% normally meaning no change.
