kossel in z direction moves double than the z value of manuel control in repetier-host.
i can send 3 motors to home and x-y direction is also okay. 3 motors are in sync But in z direction nozzle moves double.
For instance i send 10 mm to z-direction in manuel control panel in repetier-host but it moves 20 mm.i use repetier-host v0.95f. It is HE3D DLT-180 Kit.
i hope someone help me about this problem. Thank you in advance.
