I can't set my bed temp in Repetier Host any higher than 90?
My firmware is set to Max Bed Temp of 110 and I set Default Bed Temp in Printer Settings to 100, but I cant set it in Manual Contol any higher than 90
  • Check Printer Settings->Extruder->Max bed temperature
  • I've changed Printer Settings->Extruder->Max bed temperature to 120 for an ABS print.  However, when it gets past 90C, I get an error on the LCD screen of the printer saying MAX BED TEMPERATURE.  Is that a setting in the firmware of the printer?
  • Does not sound like Repetier-Firmware but yes, I guess it comes from firmware. Host does not write this.
