Option to add custom macros
I think it would be a great feature if you could add custom macros that can be "launched" directly from the display without the need to use a hosting software.
This way, you could implement something like "load/unload filament", then the extruder extrudes the exact amount of filament that´s needed to fill the extruder from the hobbed bolt to the hotend tip at a high feed rate. Especially for bowden extruders this feature could be great. You could also tell the printer to move to a specific position before loading begins.
You could add a tab "macros" in the display menu for fast access. The macros could be written in your configurator simply as a series of G-Codes.
Would it be possible to add this feature?
