Repetier Host CuraEngine Slice Bug found
in Bug Reports
first of all I love Repetier Host for many years
Good work!!!
Now I found a bug for Repetier Host slicing with cura engine. It is adding not existing layers/material.
Following steps:
1. Placement of part
2. mirroring part
3. copy this mirrored part
4. Slice via CuraEngine
-> first part looks good as expected. In print preview the copied part has e.g. additional weird single layers in a hole which are not corresponds to the original object.
I can't upload images (screenshots) here but I can send it via mail if you need it.
Repetier Host Version 2.1.6.
-Timo
Following steps:
2. mirroring part
-Timo
If you first copy and the mirror everything seems to be ok. Have added it on todo for update.
