Temperatur extruder 2 steht fest auf 100° / Temperatur extruder 2 frozen
Hallo Miteinander
Bei repetier V 2.1.6 ist die Temperatur vom extruder 2 fest auf 100° eingefroren
Mit repetier V 090C klappt alles prima
Was kann das sein?
Was kann das sein?
M104 S100 T1
oder was schickt er? Kannst du im log sehen.
< 10:26:57.661 : OpenGL extensions:GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_blend_color GL_EXT_abgr GL_EXT_texture3D GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_SGIS_texture_edge_clamp GL_SGIS_generate_mipmap GL_EXT_draw_range_elements GL_SGIS_texture_lod GL_EXT_rescale_normal GL_EXT_packed_pixels GL_EXT_texture_edge_clamp GL_EXT_separate_specular_color GL_ARB_multitexture GL_ARB_map_buffer_alignment GL_ARB_conservative_depth GL_EXT_texture_env_combine GL_EXT_bgra GL_EXT_blend_func_separate GL_EXT_secondary_color GL_EXT_fog_coord GL_EXT_texture_env_add GL_ARB_texture_cube_map GL_ARB_transpose_matrix GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_texture_env_add GL_IBM_texture_mirrored_repeat GL_EXT_multi_draw_arrays GL_SUN_multi_draw_arrays GL_NV_blend_square GL_ARB_texture_compression GL_3DFX_texture_compression_FXT1 GL_EXT_texture_filter_anisotropic GL_ARB_texture_border_clamp GL_ARB_point_parameters GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_env_crossbar GL_EXT_texture_compression_s3tc GL_ARB_shadow GL_ARB_window_pos GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_ARB_vertex_program GL_EXT_texture_rectangle GL_ARB_fragment_program GL_EXT_stencil_two_side GL_ATI_separate_stencil GL_ARB_vertex_buffer_object GL_EXT_texture_lod_bias GL_ARB_occlusion_query GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_non_power_of_two GL_ARB_vertex_shader GL_NV_texgen_reflection GL_ARB_point_sprite GL_ARB_fragment_program_shadow GL_EXT_blend_equation_separate GL_ARB_depth_texture GL_ARB_texture_rectangle GL_ARB_draw_buffers GL_ARB_color_buffer_float GL_ARB_half_float_pixel GL_ARB_texture_float GL_ARB_pixel_buffer_object GL_EXT_framebuffer_object GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_occlusion_query2 GL_EXT_draw_buffers2 GL_WIN_swap_hint GL_EXT_texture_sRGB GL_ARB_multisample GL_EXT_packed_float GL_EXT_texture_shared_exponent GL_ARB_texture_rg GL_ARB_texture_compression_rgtc GL_NV_conditional_render GL_ARB_texture_swizzle GL_EXT_texture_swizzle GL_ARB_texture_gather GL_ARB_sync GL_ARB_framebuffer_sRGB GL_EXT_packed_depth_stencil GL_ARB_depth_buffer_float GL_EXT_transform_feedback GL_ARB_transform_feedback2 GL_ARB_draw_indirect GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_ARB_framebuffer_object GL_ARB_framebuffer_no_attachments GL_EXT_texture_array GL_EXT_texture_integer GL_ARB_map_buffer_range GL_ARB_texture_buffer_range GL_EXT_texture_buffer GL_EXT_texture_snorm GL_ARB_blend_func_extended GL_INTEL_performance_queries GL_INTEL_performance_query GL_ARB_copy_buffer GL_ARB_sampler_objects GL_NV_primitive_restart GL_ARB_seamless_cube_map GL_ARB_uniform_buffer_object GL_ARB_depth_clamp GL_ARB_vertex_array_bgra GL_ARB_shader_bit_encoding GL_ARB_draw_buffers_blend GL_ARB_geometry_shader4 GL_EXT_geometry_shader4 GL_ARB_texture_query_lod GL_ARB_explicit_attrib_location GL_ARB_draw_elements_base_vertex GL_ARB_instanced_arrays GL_ARB_base_instance GL_ARB_fragment_coord_conventions GL_EXT_gpu_program_parameters GL_ARB_texture_buffer_object_rgb32 GL_ARB_compatibility GL_ARB_texture_rgb10_a2ui GL_ARB_texture_multisample GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_timer_query GL_ARB_tessellation_shader GL_ARB_vertex_array_object GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_texture_cube_map_array GL_EXT_gpu_shader4 GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_shader_subroutine GL_ARB_transform_feedback3 GL_ARB_get_program_binary GL_ARB_separate_shader_objects GL_ARB_shader_precision GL_ARB_vertex_attrib_64bit GL_ARB_viewport_array GL_ARB_transform_feedback_instanced GL_ARB_compressed_texture_pixel_storage GL_ARB_shader_atomic_counters GL_ARB_shading_language_packing GL_ARB_shading_language_420pack GL_ARB_texture_storage GL_EXT_texture_storage GL_ARB_vertex_attrib_binding GL_ARB_multi_draw_indirect GL_ARB_program_interface_query GL_ARB_texture_storage_multisample GL_ARB_buffer_storage GL_ARB_debug_output GL_KHR_debug GL_ARB_arrays_of_arrays GL_INTEL_map_texture GL_ARB_texture_compression_bptc GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_robustness GL_EXT_texture_sRGB_decode GL_KHR_blend_equation_advanced GL_EXT_shader_integer_mix GL_ARB_stencil_texturing
< 10:26:57.661 : OpenGL renderer:Intel(R) HD Graphics 4000
< 10:26:57.661 : Using fast VBOs for rendering is possible
> 10:27:42.753 : start
> 10:27:42.753 : echo:Marlin 1.0.0 RC2
> 10:27:42.753 : echo: Last Updated: 2013-5-22 | Author: mathijs
> 10:27:42.753 : echo: Free Memory: 5521 PlannerBufferBytes: 1232
> 10:27:42.753 : echo:Using Default settings:
< 10:27:43.253 : N1 M110 *2
< 10:27:43.253 : N2 M115 *4
< 10:27:43.253 : N3 M111 S6 *68
< 10:27:43.753 : N4 M105 *3
< 10:27:43.784 : N5 M111 S6 *66
< 10:27:43.784 : N6 M80 *61
< 10:27:43.800 : N7 M80 *60
> 10:27:52.815 : start
> 10:27:52.815 : echo:Marlin 1.0.0 RC2
> 10:27:52.815 : echo: Last Updated: 2013-5-22 | Author: mathijs
> 10:27:52.815 : echo: Free Memory: 5521 PlannerBufferBytes: 1232
> 10:27:52.815 : echo:Using Default settings:
< 10:27:52.815 : N1 M110 *2
< 10:27:52.815 : N2 M115 *4
< 10:27:52.831 : N3 M111 S6 *68
> 10:27:53.065 : ok
> 10:27:53.065 : ok
< 10:27:53.065 : N4 M111 S6 *67
< 10:27:53.065 : N5 M80 *62
> 10:27:53.081 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:http://www.mendel-parts.com PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:2
> 10:27:53.097 : ok
> 10:27:53.097 : ok
> 10:27:53.097 : ok
> 10:27:53.097 : ok
< 10:27:53.097 : N6 M105 *1
< 10:27:53.097 : N7 M220 S100 *70
< 10:27:53.097 : N8 M221 S100 *72
> 10:27:53.097 : ok T:17.1 /0.0 B:16.7 /0.0 @:0
> 10:27:53.253 : ok
> 10:27:53.253 : ok
< 10:27:53.253 : N9 M111 S6 *78
> 10:27:53.268 : ok
< 10:27:53.346 : N1 M110 *2
< 10:27:53.346 : N2 M115 *4
< 10:27:53.346 : N3 M111 S6 *68
> 10:27:53.346 : ok
> 10:27:53.346 : ok
< 10:27:53.346 : N4 M111 S6 *67
< 10:27:53.362 : N5 M80 *62
> 10:27:53.378 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:http://www.mendel-parts.com PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:2
> 10:27:53.378 : ok
> 10:27:53.378 : ok
> 10:27:53.378 : ok
> 10:27:53.378 : ok
< 10:27:53.378 : N6 M220 S100 *71
< 10:27:53.378 : N7 M221 S100 *71
< 10:27:53.378 : N8 M111 S6 *79
> 10:27:53.393 : ok
> 10:27:53.393 : ok
> 10:27:53.393 : ok
< 10:27:55.628 : N9 M105 *14
> 10:27:55.628 : ok T:17.1 /0.0 B:16.6 /0.0 @:0
< 10:27:58.690 : N10 M105 *54
> 10:27:58.706 : ok T:17.1 /0.0 B:16.7 /0.0 @:0
< 10:28:01.753 : N11 M105 *55
> 10:28:01.753 : ok T:17.3 /0.0 B:16.6 /0.0 @:0
< 10:28:04.768 : N12 M105 *52
> 10:28:04.784 : ok T:17.2 /0.0 B:16.6 /0.0 @:0
< 10:28:07.830 : N13 M105 *53
> 10:28:07.830 : ok T:17.2 /0.0 B:16.6 /0.0 @:0
< 10:28:10.893 : N14 M105 *50
> 10:28:10.908 : ok T:17.1 /0.0 B:16.7 /0.0 @:0
< 10:28:11.033 : N15 M104 T1 S100 *53
> 10:28:11.033 : ok
< 10:28:13.955 : N16 M105 *48
> 10:28:13.955 : ok T:17.1 /0.0 B:16.6 /0.0 @:0
< 10:28:17.018 : N17 M105 *49
> 10:28:17.018 : ok T:17.1 /0.0 B:16.7 /0.0 @:0
< 10:28:19.393 : N18 T1 *34
> 10:28:19.408 : echo:Active Extruder: 1
> 10:28:19.408 : ok
< 10:28:20.080 : N19 M105 *63
> 10:28:20.096 : ok T:20.0 /100.0 B:16.6 /0.0 @:127
< 10:28:23.143 : N20 M105 *53
> 10:28:23.143 : ok T:23.7 /100.0 B:16.7 /0.0 @:127
< 10:28:26.205 : N21 M105 *52
> 10:28:26.221 : ok T:28.2 /100.0 B:16.6 /0.0 @:127
< 10:28:29.267 : N22 M105 *55
> 10:28:29.267 : ok T:34.5 /100.0 B:16.6 /0.0 @:127
< 10:28:32.330 : N23 M105 *54
> 10:28:32.330 : ok T:41.0 /100.0 B:16.6 /0.0 @:127
< 10:28:35.392 : N24 M105 *49
> 10:28:35.408 : ok T:48.5 /100.0 B:16.6 /0.0 @:127
< 10:28:38.455 : N25 M105 *48
> 10:28:38.455 : ok T:56.8 /100.0 B:16.6 /0.0 @:127
< 10:28:41.517 : N26 M105 *51
> 10:28:41.533 : ok T:65.2 /100.0 B:16.6 /0.0 @:127
< 10:28:44.579 : N27 M105 *50
> 10:28:44.579 : ok T:73.9 /100.0 B:16.6 /0.0 @:127
< 10:28:47.642 : N28 M105 *61
> 10:28:47.642 : ok T:83.3 /100.0 B:16.6 /0.0 @:127
< 10:28:50.704 : N29 M105 *60
> 10:28:50.720 : ok T:92.1 /100.0 B:16.6 /0.0 @:0
< 10:28:53.767 : N30 M105 *52
> 10:28:53.767 : ok T:101.3 /100.0 B:16.7 /0.0 @:0
< 10:28:56.845 : N31 M105 *53
> 10:28:56.860 : ok T:109.1 /100.0 B:16.6 /0.0 @:0
< 10:28:59.891 : N32 M105 *54
> 10:28:59.891 : ok T:115.6 /100.0 B:16.6 /0.0 @:0
< 10:29:02.954 : N33 M105 *55
> 10:29:02.954 : ok T:120.9 /100.0 B:16.7 /0.0 @:0
< 10:29:06.016 : N34 M105 *48
> 10:29:06.032 : ok T:124.6 /100.0 B:16.7 /0.0 @:0
< 10:29:09.079 : N35 M105 *49
> 10:29:09.079 : ok T:127.3 /100.0 B:16.6 /0.0 @:0
< 10:29:12.141 : N36 M105 *50
> 10:29:12.157 : ok T:129.2 /100.0 B:16.7 /0.0 @:0
< 10:29:15.203 : N37 M105 *51
> 10:29:15.203 : ok T:130.4 /100.0 B:16.7 /0.0 @:0
< 10:29:18.297 : N38 M105 *60
> 10:29:18.297 : ok T:131.0 /100.0 B:16.7 /0.0 @:0
< 10:29:21.360 : N39 M105 *61
> 10:29:21.375 : ok T:131.3 /100.0 B:16.7 /0.0 @:0
< 10:29:24.422 : N40 M105 *51
> 10:29:24.422 : ok T:131.1 /100.0 B:16.6 /0.0 @:0
< 10:29:27.482 : N41 M105 *50
> 10:29:27.482 : ok T:130.8 /100.0 B:16.6 /0.0 @:0
< 10:29:30.544 : N42 M105 *49
> 10:29:30.560 : ok T:130.3 /100.0 B:16.6 /0.0 @:0
< 10:29:33.607 : N43 M105 *48
> 10:29:33.607 : ok T:129.7 /100.0 B:16.6 /0.0 @:0
< 10:29:36.669 : N44 M105 *55
> 10:29:36.685 : ok T:129.1 /100.0 B:16.6 /0.0 @:0
< 10:29:39.731 : N45 M105 *54
> 10:29:39.731 : ok T:128.3 /100.0 B:16.8 /0.0 @:0
< 10:29:42.794 : N46 M105 *53
> 10:29:42.794 : ok T:127.5 /100.0 B:16.6 /0.0 @:0
< 10:29:45.856 : N47 M105 *52
> 10:29:45.872 : ok T:126.7 /100.0 B:16.8 /0.0 @:0
< 10:29:48.919 : N48 M105 *59
> 10:29:48.919 : ok T:125.8 /100.0 B:16.6 /0.0 @:0
< 10:29:51.981 : N49 M105 *58
> 10:29:51.997 : ok T:124.8 /100.0 B:16.6 /0.0 @:0
< 10:29:55.043 : N50 M105 *50
> 10:29:55.043 : ok T:124.0 /100.0 B:16.6 /0.0 @:0
< 10:29:58.105 : N51 M105 *51
> 10:29:58.105 : ok T:123.1 /100.0 B:16.6 /0.0 @:0
< 10:30:00.257 : N52 M104 T0 S0 *54
< 10:30:00.257 : N53 M104 T1 S0 *54
< 10:30:00.257 : N54 M140 S0 *116
> 10:30:00.273 : ok
> 10:30:00.273 : ok
> 10:30:00.273 : ok
< 10:30:01.163 : N55 M105 *55
> 10:30:01.163 : ok T:122.2 /0.0 B:16.7 /0.0 @:0
< 10:30:04.226 : N56 M105 *52
> 10:30:04.241 : ok T:121.3 /0.0 B:16.7 /0.0 @:0
< 10:33:56.880 : OpenGL extensions:GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_blend_color GL_EXT_abgr GL_EXT_texture3D GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_SGIS_texture_edge_clamp GL_SGIS_generate_mipmap GL_EXT_draw_range_elements GL_SGIS_texture_lod GL_EXT_rescale_normal GL_EXT_packed_pixels GL_EXT_texture_edge_clamp GL_EXT_separate_specular_color GL_ARB_multitexture GL_ARB_map_buffer_alignment GL_ARB_conservative_depth GL_EXT_texture_env_combine GL_EXT_bgra GL_EXT_blend_func_separate GL_EXT_secondary_color GL_EXT_fog_coord GL_EXT_texture_env_add GL_ARB_texture_cube_map GL_ARB_transpose_matrix GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_texture_env_add GL_IBM_texture_mirrored_repeat GL_EXT_multi_draw_arrays GL_SUN_multi_draw_arrays GL_NV_blend_square GL_ARB_texture_compression GL_3DFX_texture_compression_FXT1 GL_EXT_texture_filter_anisotropic GL_ARB_texture_border_clamp GL_ARB_point_parameters GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_env_crossbar GL_EXT_texture_compression_s3tc GL_ARB_shadow GL_ARB_window_pos GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_ARB_vertex_program GL_EXT_texture_rectangle GL_ARB_fragment_program GL_EXT_stencil_two_side GL_ATI_separate_stencil GL_ARB_vertex_buffer_object GL_EXT_texture_lod_bias GL_ARB_occlusion_query GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_non_power_of_two GL_ARB_vertex_shader GL_NV_texgen_reflection GL_ARB_point_sprite GL_ARB_fragment_program_shadow GL_EXT_blend_equation_separate GL_ARB_depth_texture GL_ARB_texture_rectangle GL_ARB_draw_buffers GL_ARB_color_buffer_float GL_ARB_half_float_pixel GL_ARB_texture_float GL_ARB_pixel_buffer_object GL_EXT_framebuffer_object GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_occlusion_query2 GL_EXT_draw_buffers2 GL_WIN_swap_hint GL_EXT_texture_sRGB GL_ARB_multisample GL_EXT_packed_float GL_EXT_texture_shared_exponent GL_ARB_texture_rg GL_ARB_texture_compression_rgtc GL_NV_conditional_render GL_ARB_texture_swizzle GL_EXT_texture_swizzle GL_ARB_texture_gather GL_ARB_sync GL_ARB_framebuffer_sRGB GL_EXT_packed_depth_stencil GL_ARB_depth_buffer_float GL_EXT_transform_feedback GL_ARB_transform_feedback2 GL_ARB_draw_indirect GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_ARB_framebuffer_object GL_ARB_framebuffer_no_attachments GL_EXT_texture_array GL_EXT_texture_integer GL_ARB_map_buffer_range GL_ARB_texture_buffer_range GL_EXT_texture_buffer GL_EXT_texture_snorm GL_ARB_blend_func_extended GL_INTEL_performance_queries GL_INTEL_performance_query GL_ARB_copy_buffer GL_ARB_sampler_objects GL_NV_primitive_restart GL_ARB_seamless_cube_map GL_ARB_uniform_buffer_object GL_ARB_depth_clamp GL_ARB_vertex_array_bgra GL_ARB_shader_bit_encoding GL_ARB_draw_buffers_blend GL_ARB_geometry_shader4 GL_EXT_geometry_shader4 GL_ARB_texture_query_lod GL_ARB_explicit_attrib_location GL_ARB_draw_elements_base_vertex GL_ARB_instanced_arrays GL_ARB_base_instance GL_ARB_fragment_coord_conventions GL_EXT_gpu_program_parameters GL_ARB_texture_buffer_object_rgb32 GL_ARB_compatibility GL_ARB_texture_rgb10_a2ui GL_ARB_texture_multisample GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_timer_query GL_ARB_tessellation_shader GL_ARB_vertex_array_object GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_texture_cube_map_array GL_EXT_gpu_shader4 GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_shader_subroutine GL_ARB_transform_feedback3 GL_ARB_get_program_binary GL_ARB_separate_shader_objects GL_ARB_shader_precision GL_ARB_vertex_attrib_64bit GL_ARB_viewport_array GL_ARB_transform_feedback_instanced GL_ARB_compressed_texture_pixel_storage GL_ARB_shader_atomic_counters GL_ARB_shading_language_packing GL_ARB_shading_language_420pack GL_ARB_texture_storage GL_EXT_texture_storage GL_ARB_vertex_attrib_binding GL_ARB_multi_draw_indirect GL_ARB_program_interface_query GL_ARB_texture_storage_multisample GL_ARB_buffer_storage GL_ARB_debug_output GL_KHR_debug GL_ARB_arrays_of_arrays GL_INTEL_map_texture GL_ARB_texture_compression_bptc GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_robustness GL_EXT_texture_sRGB_decode GL_KHR_blend_equation_advanced GL_EXT_shader_integer_mix GL_ARB_stencil_texturing
< 10:33:56.880 : OpenGL renderer:Intel(R) HD Graphics 4000
< 10:33:56.880 : Using fast VBOs for rendering is possible
< 10:34:07.036 : Printer reset detected - initializing
> 10:34:07.036 : start
> 10:34:07.036 : echo:Marlin 1.0.0 RC2
> 10:34:07.036 : echo: Last Updated: 2013-5-22 | Author: mathijs
> 10:34:07.036 : echo: Free Memory: 5521 PlannerBufferBytes: 1232
> 10:34:07.036 : echo:Using Default settings:
< 10:34:07.473 : N1 M110*34
< 10:34:07.473 : N2 M115*36
< 10:34:07.473 : N3 M105*36
< 10:34:07.473 : N4 M114*35
< 10:34:07.473 : N5 M111 S6*98
> 10:34:07.473 : ok
< 10:34:07.473 : N6 T0*60
> 10:34:07.520 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:http://www.mendel-parts.com PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:2
> 10:34:07.520 : ok
< 10:34:07.520 : N7 M80*28
> 10:34:07.629 : ok T:23.7 /0.0 B:16.7 /0.0 @:0
> 10:34:07.629 : X:0.00Y:0.00Z:0.00E:0.00 Count X:0.00Y:0.00Z:0.00
> 10:34:07.629 : ok
> 10:34:07.629 : ok
< 10:34:07.629 : N8 M220 S100*105
< 10:34:07.629 : N9 M221 S100*105
> 10:34:07.629 : echo:Active Extruder: 0
> 10:34:07.629 : ok
> 10:34:07.629 : ok
< 10:34:07.629 : N10 M111 S6*86
< 10:34:07.629 : N11 T0*10
> 10:34:07.645 : ok
> 10:34:07.645 : ok
> 10:34:07.645 : ok
> 10:34:07.645 : echo:Active Extruder: 0
> 10:34:07.645 : ok
< 10:34:10.317 : N12 M105*20
> 10:34:10.333 : ok T:23.7 /0.0 B:16.8 /0.0 @:0
< 10:34:13.379 : N13 M105*21
> 10:34:13.379 : ok T:23.7 /0.0 B:16.8 /0.0 @:0
< 10:34:16.473 : N14 M105*18
> 10:34:16.473 : ok T:23.7 /0.0 B:16.8 /0.0 @:0
< 10:34:19.535 : N15 M105*19
> 10:34:19.551 : ok T:23.7 /0.0 B:16.8 /0.0 @:0
< 10:34:22.598 : N16 M105*16
> 10:34:22.598 : ok T:23.6 /0.0 B:16.8 /0.0 @:0
< 10:34:25.660 : N17 M105*17
> 10:34:25.676 : ok T:23.7 /0.0 B:16.8 /0.0 @:0
< 10:34:28.723 : N18 M105*30
> 10:34:28.723 : ok T:23.7 /0.0 B:16.8 /0.0 @:0
< 10:34:31.785 : N19 M105*31
> 10:34:31.785 : ok T:23.7 /0.0 B:16.7 /0.0 @:0
< 10:34:34.847 : N20 M105*21
> 10:34:34.863 : ok T:23.7 /0.0 B:16.8 /0.0 @:0
< 10:34:37.910 : N21 M105*20
> 10:34:37.910 : ok T:23.6 /0.0 B:16.7 /0.0 @:0
< 10:34:39.379 : N22 M104 T1 S100*17
> 10:34:39.379 : ok
< 10:34:40.972 : N23 M105*22
> 10:34:40.988 : ok T:23.7 /0.0 B:16.6 /0.0 @:0
< 10:34:44.035 : N24 M105*17
> 10:34:44.035 : ok T:23.7 /0.0 B:16.8 /0.0 @:0
< 10:34:47.097 : N25 M105*16
> 10:34:47.097 : ok T:23.6 /0.0 B:16.8 /0.0 @:0
< 10:34:50.159 : N26 M105*19
> 10:34:50.175 : ok T:23.7 /0.0 B:16.7 /0.0 @:0
< 10:34:53.222 : N27 M105*18
> 10:34:53.222 : ok T:23.7 /0.0 B:16.7 /0.0 @:0
< 10:34:56.284 : N28 M105*29
> 10:34:56.300 : ok T:23.7 /0.0 B:16.7 /0.0 @:0
< 10:34:59.347 : N29 M105*28
> 10:34:59.347 : ok T:23.7 /0.0 B:16.7 /0.0 @:0
< 10:35:02.409 : N30 M105*20
> 10:35:02.409 : ok T:23.7 /0.0 B:16.7 /0.0 @:0
Wie man sieht gibt Marlin hier nur für einen Extruder eine Temperatur zurück. Sicher das Marlin 2 Extruder einkompiliert hat? Wenn dann als mixed extuder oder ähnlichem so das es nur ein Heizelement gibt - dann einfach Ausgabe der 2. Temperatur ignorieren - es kann ohnehin nur für Extruder 1 eine gesetzt werden.
< 20:43:53.986 : OpenGL extensions:GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_blend_color GL_EXT_abgr GL_EXT_texture3D GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_SGIS_texture_edge_clamp GL_SGIS_generate_mipmap GL_EXT_draw_range_elements GL_SGIS_texture_lod GL_EXT_rescale_normal GL_EXT_packed_pixels GL_EXT_texture_edge_clamp GL_EXT_separate_specular_color GL_ARB_multitexture GL_ARB_map_buffer_alignment GL_ARB_conservative_depth GL_EXT_texture_env_combine GL_EXT_bgra GL_EXT_blend_func_separate GL_EXT_secondary_color GL_EXT_fog_coord GL_EXT_texture_env_add GL_ARB_texture_cube_map GL_ARB_transpose_matrix GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_texture_env_add GL_IBM_texture_mirrored_repeat GL_EXT_multi_draw_arrays GL_SUN_multi_draw_arrays GL_NV_blend_square GL_ARB_texture_compression GL_3DFX_texture_compression_FXT1 GL_EXT_texture_filter_anisotropic GL_ARB_texture_border_clamp GL_ARB_point_parameters GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_env_crossbar GL_EXT_texture_compression_s3tc GL_ARB_shadow GL_ARB_window_pos GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_ARB_vertex_program GL_EXT_texture_rectangle GL_ARB_fragment_program GL_EXT_stencil_two_side GL_ATI_separate_stencil GL_ARB_vertex_buffer_object GL_EXT_texture_lod_bias GL_ARB_occlusion_query GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_non_power_of_two GL_ARB_vertex_shader GL_NV_texgen_reflection GL_ARB_point_sprite GL_ARB_fragment_program_shadow GL_EXT_blend_equation_separate GL_ARB_depth_texture GL_ARB_texture_rectangle GL_ARB_draw_buffers GL_ARB_color_buffer_float GL_ARB_half_float_pixel GL_ARB_texture_float GL_ARB_pixel_buffer_object GL_EXT_framebuffer_object GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_occlusion_query2 GL_EXT_draw_buffers2 GL_WIN_swap_hint GL_EXT_texture_sRGB GL_ARB_multisample GL_EXT_packed_float GL_EXT_texture_shared_exponent GL_ARB_texture_rg GL_ARB_texture_compression_rgtc GL_NV_conditional_render GL_ARB_texture_swizzle GL_EXT_texture_swizzle GL_ARB_texture_gather GL_ARB_sync GL_ARB_framebuffer_sRGB GL_EXT_packed_depth_stencil GL_ARB_depth_buffer_float GL_EXT_transform_feedback GL_ARB_transform_feedback2 GL_ARB_draw_indirect GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_ARB_framebuffer_object GL_ARB_framebuffer_no_attachments GL_EXT_texture_array GL_EXT_texture_integer GL_ARB_map_buffer_range GL_ARB_texture_buffer_range GL_EXT_texture_buffer GL_EXT_texture_snorm GL_ARB_blend_func_extended GL_INTEL_performance_queries GL_INTEL_performance_query GL_ARB_copy_buffer GL_ARB_sampler_objects GL_NV_primitive_restart GL_ARB_seamless_cube_map GL_ARB_uniform_buffer_object GL_ARB_depth_clamp GL_ARB_vertex_array_bgra GL_ARB_shader_bit_encoding GL_ARB_draw_buffers_blend GL_ARB_geometry_shader4 GL_EXT_geometry_shader4 GL_ARB_texture_query_lod GL_ARB_explicit_attrib_location GL_ARB_draw_elements_base_vertex GL_ARB_instanced_arrays GL_ARB_base_instance GL_ARB_fragment_coord_conventions GL_EXT_gpu_program_parameters GL_ARB_texture_buffer_object_rgb32 GL_ARB_compatibility GL_ARB_texture_rgb10_a2ui GL_ARB_texture_multisample GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_timer_query GL_ARB_tessellation_shader GL_ARB_vertex_array_object GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_texture_cube_map_array GL_EXT_gpu_shader4 GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_shader_subroutine GL_ARB_transform_feedback3 GL_ARB_get_program_binary GL_ARB_separate_shader_objects GL_ARB_shader_precision GL_ARB_vertex_attrib_64bit GL_ARB_viewport_array GL_ARB_transform_feedback_instanced GL_ARB_compressed_texture_pixel_storage GL_ARB_shader_atomic_counters GL_ARB_shading_language_packing GL_ARB_shading_language_420pack GL_ARB_texture_storage GL_EXT_texture_storage GL_ARB_vertex_attrib_binding GL_ARB_multi_draw_indirect GL_ARB_program_interface_query GL_ARB_texture_storage_multisample GL_ARB_buffer_storage GL_ARB_debug_output GL_KHR_debug GL_ARB_arrays_of_arrays GL_INTEL_map_texture GL_ARB_texture_compression_bptc GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_robustness GL_EXT_texture_sRGB_decode GL_KHR_blend_equation_advanced GL_EXT_shader_integer_mix GL_ARB_stencil_texturing
< 20:43:53.986 : OpenGL renderer:Intel(R) HD Graphics 4000
< 20:43:53.986 : Using fast VBOs for rendering is possible
> 20:44:23.159 : start
> 20:44:23.159 : echo:Marlin 1.0.0 RC2
> 20:44:23.159 : echo: Last Updated: 2013-5-22 | Author: mathijs
> 20:44:23.159 : echo: Free Memory: 5521 PlannerBufferBytes: 1232
> 20:44:23.159 : echo:Using Default settings:
< 20:44:23.706 : N1 M110 *2
< 20:44:23.706 : N2 M115 *4
< 20:44:23.706 : N3 M111 S6 *68
< 20:44:24.190 : N4 M105 *3
< 20:44:24.315 : N5 M111 S6 *66
< 20:44:24.331 : N6 M80 *61
< 20:44:24.331 : N7 M80 *60
> 20:44:33.346 : start
> 20:44:33.346 : echo:Marlin 1.0.0 RC2
< 20:44:33.346 : N1 M110 *2
< 20:44:33.346 : N2 M115 *4
< 20:44:33.346 : N3 M111 S6 *68
> 20:44:33.362 : echo: Last Updated: 2013-5-22 | Author: mathijs
> 20:44:33.362 : echo: Free Memory: 5521 PlannerBufferBytes: 1232
> 20:44:33.362 : echo:Using Default settings:
> 20:44:33.596 : ok
> 20:44:33.596 : ok
< 20:44:33.596 : N4 M111 S6 *67
< 20:44:33.612 : N5 M80 *62
> 20:44:33.627 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:http://www.mendel-parts.com PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:2
> 20:44:33.659 : ok
> 20:44:33.659 : ok
> 20:44:33.659 : ok
> 20:44:33.659 : ok
< 20:44:33.659 : N6 M105 *1
< 20:44:33.659 : N7 M220 S100 *70
< 20:44:33.659 : N8 M221 S100 *72
> 20:44:33.674 : ok T:17.0 /0.0 B:16.8 /0.0 @:0
> 20:44:33.706 : ok
> 20:44:33.706 : ok
< 20:44:33.706 : N9 M111 S6 *78
> 20:44:33.721 : ok
< 20:44:33.846 : N1 M110 *2
< 20:44:33.846 : N2 M115 *4
< 20:44:33.846 : N3 M111 S6 *68
> 20:44:33.862 : ok
> 20:44:33.862 : ok
> 20:44:33.862 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:http://www.mendel-parts.com PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:2
< 20:44:33.862 : N4 M111 S6 *67
> 20:44:33.877 : ok
> 20:44:33.877 : ok
< 20:44:33.877 : N5 M80 *62
< 20:44:33.877 : N6 M220 S100 *71
> 20:44:33.877 : ok
> 20:44:33.877 : ok
> 20:44:33.877 : ok
< 20:44:33.877 : N7 M221 S100 *71
< 20:44:33.877 : N8 M111 S6 *79
> 20:44:33.893 : ok
> 20:44:33.893 : ok
< 20:44:36.034 : N9 M104 S150 *72
< 20:44:36.049 : N10 M105 *54
> 20:44:36.049 : ok
> 20:44:36.065 : ok T:16.9 /150.0 B:16.8 /0.0 @:0
< 20:44:39.096 : N11 M105 *55
> 20:44:39.096 : ok T:17.1 /150.0 B:16.9 /0.0 @:127
< 20:44:39.643 : N12 T1 *40
> 20:44:39.658 : echo:Active Extruder: 1
> 20:44:39.658 : ok
< 20:44:42.158 : N13 M105 *53
> 20:44:42.158 : ok T:16.8 /0.0 B:16.9 /0.0 @:0
< 20:44:45.221 : N14 M105 *50
> 20:44:45.221 : ok T:16.9 /0.0 B:16.8 /0.0 @:0
< 20:44:47.330 : N15 M104 S120 *114
> 20:44:47.346 : ok
< 20:44:48.283 : N16 M105 *48
> 20:44:48.283 : ok T:16.8 /120.0 B:16.8 /0.0 @:127
< 20:44:51.346 : N17 M105 *49
> 20:44:51.361 : ok T:17.0 /120.0 B:16.8 /0.0 @:127
< 20:44:54.408 : N18 M105 *62
> 20:44:54.408 : ok T:18.0 /120.0 B:16.8 /0.0 @:127
< 20:44:57.471 : N19 M105 *63
> 20:44:57.486 : ok T:20.5 /120.0 B:16.8 /0.0 @:127
< 20:45:00.533 : N20 M105 *53
> 20:45:00.533 : ok T:24.9 /120.0 B:16.9 /0.0 @:127
< 20:45:03.595 : N21 M105 *52
> 20:45:03.595 : ok T:29.9 /120.0 B:16.9 /0.0 @:127
< 20:45:06.658 : N22 M105 *55
> 20:45:06.673 : ok T:36.5 /120.0 B:16.8 /0.0 @:127
< 20:45:09.720 : N23 M105 *54
> 20:45:09.720 : ok T:43.4 /120.0 B:16.8 /0.0 @:127
< 20:45:12.783 : N24 M105 *49
> 20:45:12.798 : ok T:51.2 /120.0 B:16.8 /0.0 @:127
< 20:45:15.845 : N25 M105 *48
> 20:45:15.845 : ok T:59.8 /120.0 B:16.9 /0.0 @:127
< 20:45:18.907 : N26 M105 *51
> 20:45:18.907 : ok T:68.3 /120.0 B:17.0 /0.0 @:127
< 20:45:21.970 : N27 M105 *50
> 20:45:21.985 : ok T:77.1 /120.0 B:17.0 /0.0 @:127
< 20:45:22.970 : N28 T0 *32
> 20:45:22.970 : echo:Active Extruder: 0
> 20:45:22.970 : ok
< 20:45:25.032 : N29 M105 *60
> 20:45:25.032 : ok T:118.6 /150.0 B:16.9 /0.0 @:127
< 20:45:28.095 : N30 M105 *52
> 20:45:28.110 : ok T:126.6 /150.0 B:16.9 /0.0 @:127
< 20:45:31.157 : N31 M105 *53
> 20:45:31.157 : ok T:134.8 /150.0 B:16.9 /0.0 @:127
< 20:45:34.219 : N32 M105 *54
> 20:45:34.219 : ok T:142.5 /150.0 B:17.0 /0.0 @:0
< 20:45:37.282 : N33 M105 *55
> 20:45:37.297 : ok T:149.8 /150.0 B:16.9 /0.0 @:0
< 20:45:40.344 : N34 M105 *48
> 20:45:40.344 : ok T:156.2 /150.0 B:17.1 /0.0 @:0
< 20:45:43.266 : N35 T1 *45
> 20:45:43.282 : echo:Active Extruder: 1
> 20:45:43.282 : ok
< 20:45:43.407 : N36 M105 *50
> 20:45:43.422 : ok T:134.4 /120.0 B:17.1 /0.0 @:0
< 20:45:46.469 : N37 M105 *51
> 20:45:46.469 : ok T:139.1 /120.0 B:17.1 /0.0 @:0
< 20:45:49.531 : N38 M105 *60
> 20:45:49.531 : ok T:142.8 /120.0 B:17.0 /0.0 @:0
< 20:45:52.594 : N39 M105 *61
> 20:45:52.610 : ok T:145.2 /120.0 B:16.8 /0.0 @:0
< 20:45:55.656 : N40 M105 *51
> 20:45:55.656 : ok T:147.1 /120.0 B:17.1 /0.0 @:0
< 20:45:58.719 : N41 M105 *50
> 20:45:58.734 : ok T:148.2 /120.0 B:17.0 /0.0 @:0
< 20:46:01.781 : N42 M105 *49
> 20:46:01.781 : ok T:148.9 /120.0 B:17.0 /0.0 @:0
< 20:46:04.844 : N43 M105 *48
> 20:46:04.844 : ok T:149.2 /120.0 B:17.0 /0.0 @:0
< 20:46:07.906 : N44 M105 *55
> 20:46:07.922 : ok T:149.0 /120.0 B:17.0 /0.0 @:0
< 20:46:10.968 : N45 M105 *54
> 20:46:10.968 : ok T:148.8 /120.0 B:17.1 /0.0 @:0
< 20:46:14.031 : N46 M105 *53
> 20:46:14.046 : ok T:148.2 /120.0 B:17.0 /0.0 @:0
< 20:46:16.593 : N47 T0 *41
> 20:46:16.609 : echo:Active Extruder: 0
> 20:46:16.609 : ok
< 20:46:17.093 : N48 M105 *59
> 20:46:17.093 : ok T:164.2 /150.0 B:16.9 /0.0 @:0
< 20:46:20.156 : N49 M105 *58
> 20:46:20.156 : ok T:162.9 /150.0 B:17.1 /0.0 @:0
< 20:46:23.218 : N50 M105 *50
> 20:46:23.234 : ok T:161.4 /150.0 B:17.0 /0.0 @:0
< 20:46:26.280 : N51 M105 *51
> 20:46:26.280 : ok T:160.0 /150.0 B:17.1 /0.0 @:0
< 20:46:29.343 : N52 M105 *48
> 20:46:29.358 : ok T:158.7 /150.0 B:17.0 /0.0 @:0
< 20:46:32.405 : N53 M105 *49
> 20:46:32.405 : ok T:157.2 /150.0 B:17.1 /0.0 @:0
< 20:46:35.468 : N54 M105 *54
> 20:46:35.468 : ok T:155.9 /150.0 B:17.0 /0.0 @:0
< 20:46:38.530 : N55 M105 *55
> 20:46:38.546 : ok T:154.5 /150.0 B:17.0 /0.0 @:0
< 20:46:38.921 : N56 T1 *40
> 20:46:38.921 : echo:Active Extruder: 1
> 20:46:38.921 : ok
< 20:46:41.592 : N57 M105 *53
> 20:46:41.592 : ok T:139.8 /120.0 B:17.1 /0.0 @:0
< 20:46:44.655 : N58 M105 *58
> 20:46:44.671 : ok T:138.8 /120.0 B:17.0 /0.0 @:0
< 20:46:47.717 : N59 M105 *59
> 20:46:47.717 : ok T:137.7 /120.0 B:17.0 /0.0 @:0
< 20:46:50.780 : N60 M105 *49
> 20:46:50.780 : ok T:136.6 /120.0 B:17.1 /0.0 @:0
< 20:46:53.842 : N61 M105 *48
> 20:46:53.858 : ok T:135.6 /120.0 B:17.1 /0.0 @:0
< 20:46:56.905 : N62 M105 *51
> 20:46:56.905 : ok T:134.5 /120.0 B:17.0 /0.0 @:0
< 20:46:59.967 : N63 M105 *50
> 20:46:59.983 : ok T:133.6 /120.0 B:17.0 /0.0 @:0
< 20:47:03.029 : N64 M105 *53
> 20:47:03.029 : ok T:132.7 /120.0 B:17.1 /0.0 @:0
< 20:47:06.092 : N65 M105 *52
> 20:47:06.092 : ok T:131.7 /120.0 B:17.0 /0.0 @:0
< 20:47:09.154 : N66 M105 *55
> 20:47:09.170 : ok T:130.7 /120.0 B:17.1 /0.0 @:0
< 20:47:11.029 : N67 T0 *43
> 20:47:11.029 : echo:Active Extruder: 0
> 20:47:11.029 : ok
< 20:47:12.217 : N68 M105 *57
> 20:47:12.217 : ok T:145.1 /150.0 B:17.1 /0.0 @:26
< 20:47:15.279 : N69 M105 *56
> 20:47:15.295 : ok T:145.3 /150.0 B:17.1 /0.0 @:26
< 20:47:18.341 : N70 M105 *48
> 20:47:18.341 : ok T:145.6 /150.0 B:17.1 /0.0 @:25
< 20:47:20.425 : N71 M104 T0 S0 *55
< 20:47:20.425 : N72 M104 T1 S0 *53
< 20:47:20.425 : N73 M140 S0 *113
> 20:47:20.425 : ok
> 20:47:20.441 : ok
> 20:47:20.441 : ok
< 20:47:21.347 : N74 M105 *52
> 20:47:21.363 : ok T:145.9 /0.0 B:17.0 /0.0 @:0
< 20:47:24.410 : N75 M105 *53
> 20:47:24.410 : ok T:146.3 /0.0 B:17.1 /0.0 @:0
< 20:47:27.472 : N76 M105 *54
> 20:47:27.488 : ok T:146.4 /0.0 B:17.1 /0.0 @:0
< 20:47:30.534 : N77 M105 *55
> 20:47:30.534 : ok T:146.4 /0.0 B:17.0 /0.0 @:0
< 20:47:33.597 : N78 M105 *56
> 20:47:33.597 : ok T:145.9 /0.0 B:17.1 /0.0 @:0
< 20:48:01.096 : OpenGL extensions:GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_blend_color GL_EXT_abgr GL_EXT_texture3D GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_SGIS_texture_edge_clamp GL_SGIS_generate_mipmap GL_EXT_draw_range_elements GL_SGIS_texture_lod GL_EXT_rescale_normal GL_EXT_packed_pixels GL_EXT_texture_edge_clamp GL_EXT_separate_specular_color GL_ARB_multitexture GL_ARB_map_buffer_alignment GL_ARB_conservative_depth GL_EXT_texture_env_combine GL_EXT_bgra GL_EXT_blend_func_separate GL_EXT_secondary_color GL_EXT_fog_coord GL_EXT_texture_env_add GL_ARB_texture_cube_map GL_ARB_transpose_matrix GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_texture_env_add GL_IBM_texture_mirrored_repeat GL_EXT_multi_draw_arrays GL_SUN_multi_draw_arrays GL_NV_blend_square GL_ARB_texture_compression GL_3DFX_texture_compression_FXT1 GL_EXT_texture_filter_anisotropic GL_ARB_texture_border_clamp GL_ARB_point_parameters GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_env_crossbar GL_EXT_texture_compression_s3tc GL_ARB_shadow GL_ARB_window_pos GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_ARB_vertex_program GL_EXT_texture_rectangle GL_ARB_fragment_program GL_EXT_stencil_two_side GL_ATI_separate_stencil GL_ARB_vertex_buffer_object GL_EXT_texture_lod_bias GL_ARB_occlusion_query GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_non_power_of_two GL_ARB_vertex_shader GL_NV_texgen_reflection GL_ARB_point_sprite GL_ARB_fragment_program_shadow GL_EXT_blend_equation_separate GL_ARB_depth_texture GL_ARB_texture_rectangle GL_ARB_draw_buffers GL_ARB_color_buffer_float GL_ARB_half_float_pixel GL_ARB_texture_float GL_ARB_pixel_buffer_object GL_EXT_framebuffer_object GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_occlusion_query2 GL_EXT_draw_buffers2 GL_WIN_swap_hint GL_EXT_texture_sRGB GL_ARB_multisample GL_EXT_packed_float GL_EXT_texture_shared_exponent GL_ARB_texture_rg GL_ARB_texture_compression_rgtc GL_NV_conditional_render GL_ARB_texture_swizzle GL_EXT_texture_swizzle GL_ARB_texture_gather GL_ARB_sync GL_ARB_framebuffer_sRGB GL_EXT_packed_depth_stencil GL_ARB_depth_buffer_float GL_EXT_transform_feedback GL_ARB_transform_feedback2 GL_ARB_draw_indirect GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_ARB_framebuffer_object GL_ARB_framebuffer_no_attachments GL_EXT_texture_array GL_EXT_texture_integer GL_ARB_map_buffer_range GL_ARB_texture_buffer_range GL_EXT_texture_buffer GL_EXT_texture_snorm GL_ARB_blend_func_extended GL_INTEL_performance_queries GL_INTEL_performance_query GL_ARB_copy_buffer GL_ARB_sampler_objects GL_NV_primitive_restart GL_ARB_seamless_cube_map GL_ARB_uniform_buffer_object GL_ARB_depth_clamp GL_ARB_vertex_array_bgra GL_ARB_shader_bit_encoding GL_ARB_draw_buffers_blend GL_ARB_geometry_shader4 GL_EXT_geometry_shader4 GL_ARB_texture_query_lod GL_ARB_explicit_attrib_location GL_ARB_draw_elements_base_vertex GL_ARB_instanced_arrays GL_ARB_base_instance GL_ARB_fragment_coord_conventions GL_EXT_gpu_program_parameters GL_ARB_texture_buffer_object_rgb32 GL_ARB_compatibility GL_ARB_texture_rgb10_a2ui GL_ARB_texture_multisample GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_timer_query GL_ARB_tessellation_shader GL_ARB_vertex_array_object GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_texture_cube_map_array GL_EXT_gpu_shader4 GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_shader_subroutine GL_ARB_transform_feedback3 GL_ARB_get_program_binary GL_ARB_separate_shader_objects GL_ARB_shader_precision GL_ARB_vertex_attrib_64bit GL_ARB_viewport_array GL_ARB_transform_feedback_instanced GL_ARB_compressed_texture_pixel_storage GL_ARB_shader_atomic_counters GL_ARB_shading_language_packing GL_ARB_shading_language_420pack GL_ARB_texture_storage GL_EXT_texture_storage GL_ARB_vertex_attrib_binding GL_ARB_multi_draw_indirect GL_ARB_program_interface_query GL_ARB_texture_storage_multisample GL_ARB_buffer_storage GL_ARB_debug_output GL_KHR_debug GL_ARB_arrays_of_arrays GL_INTEL_map_texture GL_ARB_texture_compression_bptc GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_robustness GL_EXT_texture_sRGB_decode GL_KHR_blend_equation_advanced GL_EXT_shader_integer_mix GL_ARB_stencil_texturing
< 20:48:01.096 : OpenGL renderer:Intel(R) HD Graphics 4000
< 20:48:01.096 : Using fast VBOs for rendering is possible
< 20:48:37.783 : Printer reset detected - initializing
> 20:48:37.799 : start
> 20:48:37.799 : echo:Marlin 1.0.0 RC2
> 20:48:37.799 : echo: Last Updated: 2013-5-22 | Author: mathijs
> 20:48:37.799 : echo: Free Memory: 5521 PlannerBufferBytes: 1232
> 20:48:37.799 : echo:Using Default settings:
< 20:48:37.955 : N1 M110*34
< 20:48:37.955 : N2 M115*36
< 20:48:37.955 : N3 M105*36
< 20:48:37.955 : N4 M114*35
< 20:48:37.955 : N5 M111 S6*98
> 20:48:38.033 : ok
< 20:48:38.033 : N6 T0*60
> 20:48:38.064 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:http://www.mendel-parts.com PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:2
> 20:48:38.064 : ok
< 20:48:38.064 : N7 M80*28
> 20:48:38.096 : ok T:124.0 /0.0 B:17.1 /0.0 @:0
> 20:48:38.096 : X:0.00Y:0.00Z:0.00E:0.00 Count X:0.00Y:0.00Z:0.00
> 20:48:38.096 : ok
> 20:48:38.096 : ok
< 20:48:38.127 : N8 M220 S100*105
> 20:48:38.127 : echo:Active Extruder: 0
< 20:48:38.127 : N9 M221 S100*105
> 20:48:38.127 : ok
> 20:48:38.127 : ok
< 20:48:38.127 : N10 M111 S6*86
< 20:48:38.127 : N11 T0*10
> 20:48:38.142 : ok
> 20:48:38.142 : ok
> 20:48:38.142 : ok
> 20:48:38.142 : echo:Active Extruder: 0
> 20:48:38.142 : ok
< 20:48:40.986 : N12 M105*20
> 20:48:41.002 : ok T:123.2 /0.0 B:17.1 /0.0 @:0
< 20:48:44.049 : N13 M105*21
> 20:48:44.049 : ok T:122.3 /0.0 B:17.2 /0.0 @:0
< 20:48:47.111 : N14 M105*18
> 20:48:47.127 : ok T:121.5 /0.0 B:17.0 /0.0 @:0
< 20:48:50.173 : N15 M105*19
> 20:48:50.173 : ok T:120.6 /0.0 B:17.1 /0.0 @:0
< 20:48:53.236 : N16 M105*16
> 20:48:53.236 : ok T:119.7 /0.0 B:17.1 /0.0 @:0
< 20:48:56.298 : N17 M105*17
> 20:48:56.314 : ok T:118.6 /0.0 B:17.1 /0.0 @:0
< 20:48:59.361 : N18 M105*30
> 20:48:59.361 : ok T:117.6 /0.0 B:17.1 /0.0 @:0
< 20:49:02.423 : N19 M105*31
> 20:49:02.439 : ok T:116.5 /0.0 B:17.2 /0.0 @:0
< 20:49:05.485 : N20 M105*21
> 20:49:05.501 : ok T:115.4 /0.0 B:17.1 /0.0 @:0
< 20:49:07.938 : N21 M104 T0 S150*22
> 20:49:07.938 : ok
< 20:49:08.548 : N22 M105*23
> 20:49:08.548 : ok T:114.4 /150.0 B:17.1 /0.0 @:127
< 20:49:09.923 : N23 M104 T1 S120*18
> 20:49:09.923 : ok
< 20:49:11.610 : N24 M105*17
> 20:49:11.626 : ok T:113.6 /150.0 B:17.0 /0.0 @:127
< 20:49:14.673 : N25 M105*16
> 20:49:14.673 : ok T:114.0 /150.0 B:17.1 /0.0 @:127
< 20:49:17.735 : N26 M105*19
> 20:49:17.751 : ok T:115.9 /150.0 B:17.1 /0.0 @:127
< 20:49:20.797 : N27 M105*18
> 20:49:20.797 : ok T:119.5 /150.0 B:17.0 /0.0 @:127
< 20:49:23.860 : N28 M105*29
> 20:49:23.860 : ok T:124.0 /150.0 B:17.1 /0.0 @:127
< 20:49:26.922 : N29 M105*28
> 20:49:26.938 : ok T:129.4 /150.0 B:17.1 /0.0 @:127
< 20:49:29.985 : N30 M105*20
> 20:49:29.985 : ok T:135.6 /150.0 B:17.1 /0.0 @:127
< 20:49:33.047 : N31 M105*21
> 20:49:33.063 : ok T:142.2 /150.0 B:17.1 /0.0 @:0
< 20:49:36.110 : N32 M105*22
> 20:49:36.110 : ok T:148.8 /150.0 B:17.1 /0.0 @:0
< 20:49:39.172 : N33 M105*23
> 20:49:39.250 : ok T:154.1 /150.0 B:17.2 /0.0 @:0
< 20:49:42.234 : N34 M105*16
> 20:49:42.250 : ok T:158.2 /150.0 B:17.3 /0.0 @:0
< 20:49:45.297 : N35 M105*17
> 20:49:45.297 : ok T:161.2 /150.0 B:17.1 /0.0 @:0
< 20:49:48.359 : N36 M105*18
> 20:49:48.375 : ok T:163.1 /150.0 B:17.1 /0.0 @:0
< 20:49:51.422 : N37 M105*19
> 20:49:51.422 : ok T:164.2 /150.0 B:17.1 /0.0 @:0
< 20:49:54.484 : N38 M105*28
> 20:49:54.484 : ok T:164.5 /150.0 B:17.1 /0.0 @:0
< 20:49:57.130 : N39 M104 T0 S0*27
< 20:49:57.130 : N40 M140 S0*81
> 20:49:57.145 : ok
> 20:49:57.145 : ok
Das Problem ist das die Firmware nur das als Temperatur liefert:
da ist nur die Temperatur für den Aktiven Extruder enthalten und genau so wird es behandelt im Host. Der inaktive wird nicht aktualisiert.
ABER
Ich habe ja den zweiten und nur diesen im manuellen Menü ausgewählt. Und er heizt jedoch wird dieser nicht aktualisiert obwohl die Daten ja geliefert werden. Das Programm sollte diese Daten interpretieren und beim zweiten extruder den istwert darstellen. (Die uraltversion) kann das. Also merken welcher als letztes aktiviert wird und dazu die Daten anzeigen.
Könnt ihr das wieder reinprogrammieren?
Danke
