Dual Parking extruder
Good day to all of you.
I have a problem with my extruder setup and even after a week i cant solve it.
i have a parking dual extruder basically the same as this:
https://www.thingiverse.com/thing:2201859
ive put in X offset for
E0=-27
E1=27
Probe x=0 y=-20
I have set xmin is -27 in general settings
i have these switch scripts in firmware:
E0 select: G1 X-27.000 F3000 \n M42 P4 S255
E0 deselect: G1 X-27.00 F3000 \n M42 P4 S0
E1 select : G1 X262.000 F3000 \n M42 P5 S255
E1 deselect: G1 X262.000 F3000 \n M42 P5 S0
But no matter what combination of offsets or positions on the script i put there i cant seem to find a working solution.
When i switch the extruders, the E0 is either left 27mm from endstop, then pushed to 0 when the E1 arrives, but then when E1 is selected the select head stops at 27mm frrom endstop and doesnt reach the extruder, or it breaks completely.
Iam pretty inexperienced in this, could i please have your advice what the correct configuration would be? Iam 100% sure the problem is on my side.
E0=-27
E1=27
Probe x=0 y=-20
G1 X130 F3000
after the M42 then you do not hit them and it should work I guess.
thank you for the reply!
This firmware is amazing. And the configurator is so helpful!
