RepRap Discount smart controller with Melzi
I bought a cheap RepRap Discount smart controller, and I am in the process of trying to get it to work with my Melzi board. Of course, my board does not have all of the available pins the display expects, and I know I'll have to do some re-wiring. I assume that not using a card detect signal should not be a problem.
I used the web tool and selected the "Manual definition of display and keys parameter in uiconfig.h." I used the Arduino digital pin numbers to define the pins:
pins.h
#define SDSS               27 (SD card reader on the display)
uiconfig.h
#define UI_HAS_KEYS 1
#define BEEPER_PIN 10
#define UI_DISPLAY_ENABLE_PIN 16
#define UI_DISPLAY_RS_PIN 26
#define UI_DISPLAY_D4_PIN 11
UI_KEYS_INIT_CLICKENCODER_LOW(25,17);
UI_KEYS_INIT_BUTTON_LOW(28);
The problem is that when I try to build the firmware, I get a lot of warnings for redefined UI values and then the build stops with the below.
It looks like the compiled firmware is too big to fit on the micro controller. Is there something I can do to make it smaller? Would a different SPI library help? Also, should I be concerned about the warnings about the UI values being redefined? Any help would be appreciated.
Compiling libraries...
Compiling library "SPI"
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega1284p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_SANGUINO -DARDUINO_ARCH_AVR -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/Users/jackson/Documents/Arduino/hardware/Sanguino/avr/variants/sanguino -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src /Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src/SPI.cpp -o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/libraries/SPI/SPI.cpp.o
Compiling core...
Using precompiled core: /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_cache_824885/core/core_Sanguino_avr_sanguino_cpu_atmega1284p_51f02b7210b938436b779d1c032618e1.a
Linking everything together...
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega1284p -o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/Repetier.ino.elf /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/BedLeveling.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/Commands.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/Communication.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/Distortion.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/Drivers.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/Eeprom.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/Endstops.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/Extruder.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/HAL.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/Printer.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/Repetier.ino.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/SDCard.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/gcode.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/motion.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/ui.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/uilang.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/src/SdFat/FatLib/FatFile.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/src/SdFat/FatLib/FatFileLFN.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/src/SdFat/FatLib/FatFilePrint.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/src/SdFat/FatLib/FatFileSFN.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/src/SdFat/FatLib/FatVolume.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/src/SdFat/FatLib/FmtNumber.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/src/SdFat/FatLib/StdioStream.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/src/SdFat/FatLib/fstream.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/src/SdFat/FatLib/istream.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/src/SdFat/FatLib/ostream.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/src/SdFat/MinimumSerial.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/src/SdFat/SdCard/SdSpiCard.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/src/SdFat/SdCard/SdSpiCardEX.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/src/SdFat/SdCard/SdioCardEX.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/src/SdFat/SdCard/SdioTeensy.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/src/SdFat/SpiDriver/SdSpiESP8266.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/src/SdFat/SpiDriver/SdSpiSAM3X.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/src/SdFat/SpiDriver/SdSpiSTM32.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/sketch/src/SdFat/SpiDriver/SdSpiTeensy3.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/libraries/SPI/SPI.cpp.o /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/../arduino_cache_824885/core/core_Sanguino_avr_sanguino_cpu_atmega1284p_51f02b7210b938436b779d1c032618e1.a -L/var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043 -lm
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/../lib/gcc/avr/7.3.0/../../../../avr/bin/ld: /var/folders/78/kfp4frbd5tb2t7w27yj1grc80000gq/T/arduino_build_335043/Repetier.ino.elf section `.text' will not fit in region `text'
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/../lib/gcc/avr/7.3.0/../../../../avr/bin/ld: region `text' overflowed by 7334 bytes
collect2: error: ld returned 1 exit status
Using library SPI at version 1.0 in folder: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI
exit status 1
Error compiling for board Sanguino.
  • So far it does not complain about total size but text segment only. Make sure you have only selected one language. All languages is too much. Especially on melzi which is short of flash memory anyway. Hope you have at least the 128kb version.
  • Thank you for the reply. The board has a 1284P micro controller. I did select only one language. My configuration.h is included below. Any additional suggestions?
        MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
        along with Repetier-Firmware.  If not, see <http://www.gnu.org/licenses/>.
    #ifndef CONFIGURATION_H
    #define CONFIGURATION_H
       This file is optimized for version 1.0.3
       as you expect.
    #define NUM_EXTRUDER 1
    #define MOTHERBOARD 63
    #include "pins.h"
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN -1
    #define BOARD_FAN_SPEED 255
    #define BOARD_FAN_MIN_SPEED 0
    #define FAN_THERMO_PIN -1
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL  -1
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 0
    #define XAXIS_STEPS_PER_MM 100
    #define YAXIS_STEPS_PER_MM 100
    #define ZAXIS_STEPS_PER_MM 398.4064
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 94.737
    #define EXT0_TEMPSENSOR_TYPE 5
    #define EXT0_INVERSE 0
    #define EXT0_ENABLE_ON 0
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 50
    #define EXT0_HEAT_MANAGER 1
    #define EXT0_PREHEAT_TEMP 190
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_INTEGRAL_DRIVE_MIN 50
    #define EXT0_PID_PGAIN_OR_DEAD_TIME 14.5997
    #define EXT0_PID_I 1.0704
    #define EXT0_PID_D 49.7849
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 3
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0
    #define JAM_METHOD 1
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define PID_CONTROL_RANGE 20
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 160
    #define NUM_TEMPS_USERTHERMISTOR0 58
    #define USER_THERMISTORTABLE0 {{1,8},{2,16},{3,24},{3,32},{4,40},{5,48},{6,56},{7,64},{8,72},{9,80},{10,88},{10,96},{11,104},{12,112},{13,120},{14,128},{15,136},{16,144},{16,152},{17,160},{18,168},{19,176},{20,184},{21,192},{22,200},{23,208},{23,216},{24,224},{25,232},{26,240},{27,248},{28,256},{29,264},{29,272},{30,280},{31,288},{32,296},{33,304},{34,312},{35,320},{35,328},{36,336},{37,344},{38,352},{39,360},{40,368},{41,376},{41,384},{42,392},{43,400},{44,408},{45,416},{46,424},{47,432},{47,440},{48,448},{49,456},{50,464}}
    #define NUM_TEMPS_USERTHERMISTOR1 33
    #define USER_THERMISTORTABLE1 {{1,8},{2,16},{3,24},{3,32},{4,40},{5,48},{6,56},{7,64},{8,72},{9,80},{10,88},{10,96},{11,104},{12,112},{13,120},{14,128},{15,136},{16,144},{16,152},{17,160},{18,168},{19,176},{20,184},{21,192},{22,200},{23,208},{23,216},{24,224},{25,232},{26,240},{27,248},{28,256},{29,264}}
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 0
    #define COOLER_PWM_SPEED 0
    #define HAVE_HEATED_BED 1
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_SENSOR_TYPE 6
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   481.087
    #define HEATED_BED_PID_IGAIN   135.023
    #define HEATED_BED_PID_DGAIN 428.528
    #define MIN_EXTRUDER_TEMP 150
    #define MAXTEMP 275
    // ##                             Laser configuration                                      ##
    automatically disabled.
    #define SUPPORT_LASER 0
    #define LASER_PIN -1
    #define LASER_ON_HIGH 1
    #define LASER_WARMUP_TIME 0
    #define LASER_PWM_MAX 255
    #define LASER_WATT 2
    // ##                              CNC configuration                                       ##
    #define SUPPORT_CNC 0
    #define CNC_WAIT_ON_DISABLE 0
    #define CNC_ENABLE_PIN -1
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    #define CNC_PWM_MAX 255
    #define CNC_RPM_MAX 8000
    #define CNC_SAFE_Z 150
    #define X2_MIN_PIN -1
    #define X2_MAX_PIN -1
    #define Y2_MIN_PIN -1
    #define Y2_MAX_PIN -1
    #define Z2_MINMAX_PIN -1
    #define DOOR_PIN -1
    #define DOOR_PULLUP 1
    #define DOOR_INVERTING 1
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 2
    #define MOVE_X_WHEN_HOMED 0
    #define MOVE_Y_WHEN_HOMED 0
    #define MOVE_Z_WHEN_HOMED 0
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 1
    #define INVERT_X_DIR 0
    #define INVERT_X2_DIR 0
    #define INVERT_Y_DIR 0
    #define INVERT_Y2_DIR 0
    #define INVERT_Z_DIR 1
    #define INVERT_Z2_DIR 0
    #define INVERT_Z3_DIR 0
    #define INVERT_Z4_DIR 0
    #define X_HOME_DIR -1
    #define Y_HOME_DIR -1
    #define Z_HOME_DIR -1
    #define X_MAX_LENGTH 245
    #define Y_MAX_LENGTH 220
    #define Z_MAX_LENGTH 220
    #define X_MIN_POS -8
    #define Y_MIN_POS 0
    #define Z_MIN_POS -1.8
    #define PARK_POSITION_X 0
    #define PARK_POSITION_Y 0
    #define DISTORTION_LIMIT_TO 2
    #define DISTORTION_XMIN 10
    #define DISTORTION_YMIN 10
    #define DISTORTION_XMAX 190
    #define DISTORTION_YMAX 190
    // ##                           Movement settings                                          ##
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_HOME_ON_POWER 0
    #define MAX_INACTIVE_TIME 0L
    #define MAX_FEEDRATE_X 400
    #define MAX_FEEDRATE_Y 400
    #define MAX_FEEDRATE_Z 4
    #define HOMING_FEEDRATE_X 100
    #define HOMING_FEEDRATE_Y 100
    #define HOMING_FEEDRATE_Z 2
    #define HOMING_ORDER HOME_ORDER_XYZ
    #define ZHOME_PRE_RAISE 0
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 999999
    #define ZHOME_Y_POS 999999
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 0
    #define DIRECTION_DELAY 0
    #define ALLOW_QUADSTEPPING 1
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 400
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 400
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 400
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 400
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 400
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 400
    #define MAX_JERK 20
    #define MAX_ZJERK 0.3
    #define MOVE_CACHE_LOW 10
    #define DUAL_X_AXIS 0
    #define DUAL_X_RESOLUTION 0
    #define X2_STEP_PIN   ORIG_E1_STEP_PIN
    #define X2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Y2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Y2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Z2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z3_STEP_PIN   ORIG_E2_STEP_PIN
    #define Z3_DIR_PIN    ORIG_E2_DIR_PIN
    #define Z4_STEP_PIN   ORIG_E3_STEP_PIN
    #define Z4_DIR_PIN    ORIG_E3_DIR_PIN
    #define USE_ADVANCE 0
    #define BAUDRATE 115200
    #define ENABLE_POWER_ON_STARTUP 0
    #define POWER_INVERTING 0
    #define AUTOMATIC_POWERUP 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 2
    #undef PS_ON_PIN
    #define PS_ON_PIN -1
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
    #define FEATURE_SERVO 0
    #define SERVO0_PIN 11
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define UI_SERVO_CONTROL 0
    #define MAX_FAN_PWM 255
            #define FEATURE_WATCHDOG 1
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 1
    #define FEATURE_Z_PROBE 0
    #define EXTRUDER_IS_Z_PROBE 0
    #define Z_PROBE_PIN -1
    #define Z_PROBE_PULLUP 0
    #define Z_PROBE_ON_HIGH 0
    #define Z_PROBE_X_OFFSET 0
    #define Z_PROBE_Y_OFFSET 0
    #define Z_PROBE_SPEED 2
    #define Z_PROBE_XY_SPEED 150
    #define Z_PROBE_REPETITIONS 1
    #define Z_PROBE_USE_MEDIAN 0
    #define Z_PROBE_HEIGHT 40
    #define Z_PROBE_DELAY 0
    #define FEATURE_AUTOLEVEL 0
    #define Z_PROBE_X1 20
    #define Z_PROBE_Y1 20
    #define Z_PROBE_X2 160
    #define Z_PROBE_Y2 20
    #define Z_PROBE_X3 20
    #define Z_PROBE_Y3 160
    #define BED_LEVELING_METHOD 0
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 0
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #define SDSUPPORT 1
    #undef SDCARDDETECT
    #define SDCARDDETECT -1
    #undef SDCARDDETECTINVERTED
    #endif
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_CONTROLLER 11
    #define ADC_KEYPAD_PIN 1
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 0
    #define LANGUAGE_NL_ACTIVE 0
    #define LANGUAGE_PT_ACTIVE 0
    #define LANGUAGE_IT_ACTIVE 0
    #define LANGUAGE_ES_ACTIVE 0
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 0
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 0
    #define LANGUAGE_TR_ACTIVE 0
    #define UI_PRINTER_NAME "P802E"
    #define UI_PRINTER_COMPANY "TronXY"
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 1
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 0
    #define CASE_LIGHTS_PIN -1
    #define UI_HEAD "E:%ec/%Ec\002 B:%eb/%Eb\002"
    #define UI_SET_MIN_EXTRUDER_TEMP   170
    #define UI_SET_MAX_EXTRUDER_TEMP   260
    #define NUM_MOTOR_DRIVERS 0
    #undef USER_THERMISTORTABLE0
    #define USER_THERMISTORTABLE0 {\
    {56,300*8},{59,295*8},{64,290*8},{70,285*8},{76,280*8},{82,275*8},{89,270*8},{98,265*8},\
    {108,260*8},{118,255*8},{128,250*8},{145,245*8},{156,240*8},{168,235*8},{187,230*8},{208,225*8},\
    {227,220*8},{248,215*8},{272,210*8},{301,205*8},{336,200*8},{370,195*8},{400,190*8},{450,185*8},\
    {492,180*8},{552,175*8},{615,170*8},{690,165*8},{750,160*8},{830,155*8},{920,150*8},{1010,145*8},\
    {1118,140*8},{1215,135*8},{1330,130*8},{1460,125*8},{1594,120*8},{1752,115*8},{1900,110*8},{2040,105*8},\
    {2200,100*8},{2350,95*8},{2516,90*8},{2671,85*8},{2831,80*8},{2975,75*8},{3115,70*8},{3251,65*8},\
    {3375,60*8},{3480,55*8},{3580,50*8},{3660,45*8},{3740,40*8},{3869,30*8},{3912,25*8},{3948,20*8},\
    {4077,-20*8},{4094,-55*8}}
    #undef USER_THERMISTORTABLE1
    #define USER_THERMISTORTABLE1 {\
    {56,300*8},{187,250*8},{615,190*8},{690,185*8},{750,180*8},{830,175*8},{920,170*8},{1010,165*8},\
    {1118,160*8},{1215,155*8},{1330,145*8},{1460,140*8},{1594,135*8},{1752,130*8},{1900,125*8},{2040,120*8},\
    {2200,115*8},{2350,110*8},{2516,105*8},{2671,98*8},{2831,92*8},{2975,85*8},{3115,76*8},{3251,72*8},\
    {3480,62*8},{3580,52*8},{3660,46*8},{3740,40*8},{3869,30*8},{3912,25*8},{3948,20*8},{4077,-20*8},\
    {4094,-55*8}}
    #endif
  • I see only one language, so it might be the total length including code. It is normally more then 128kb. Try disabling eeprom setting EEPROM_MODE 0. That should reduce length enough to make it fit. If it then fits you need to decide which features you can miss so firmware fits on board. Things requiring enough memory are:
    - eeprom
    - sd card
    - display
    - eeprom
    - sd card
    - display
    Yes, when I disable either eeprom, or sd card the firmware compiles. I didn't try to disable the display because that defeats the purpose. I was able to load the firmware on my board and the display seems to work fine, but I had to assign the beeper to pin 27, as that pin also has an LED attached, so it is not suitable for for any of the other IO functions.
    If I do decide to use the firmware with eeprom disabled how do I set all of the default values? Is there any other way to free up the necessary memory?
  • Without eeprom the values from configuration.h are always used.
    You can disable small features you do not need. arc support gives you 1-2kb. You could reduce temperature table sizes you do not need. With some luck that gives you the 7kb extra.
  • Thank you for the info. Your firmware has given me a much needed diversion.
