Z- probe transform your Cartesian in a Delta on 0.92.3
i'm tring all night to work with autolevel enabled with my cartesian but after g32 s2 it moves like a delta ( Z up 10 = X n Y move ), if u disable autolevel u have the control again ...
15:06:45.978 : Z-probe:50.00 X:0.00 Y:0.00
15:07:01.571 : Z-probe:45.51 X:450.00 Y:300.00
15:07:16.478 : Z-probe:48.70 X:900.00 Y:600.00
15:07:20.868 : Transformation matrix: 0.832050 0.554700 0.000000 0.000000 0.000000 -1.000000 -0.554700 0.832050 0.000000
15:07:21.649 : Info:Autoleveling enabled
15:07:21.649 : X:1081.67 Y:838860.81 Z:0.000 E:0.0000   <------ WFT?
  • ok the iusse is that i try to misure 3 points in a diagonal if u do this printer don't work ...but i need to find the flexion of XY axes so i need a min of 9 points ... 4 corners the 4 middles and the center =(
  • You need to measure 3 points near each column. Only with 3 points a plane can be defined exactly.
    The host has a bed height map feature to measure a grid and show you the different heights so you can better calibrate the printer. Also we have a distortion correction to correct based on grid measurements.
