Autoleveling P1, P2 and P3 position - Out of bed measures
Hello!
I have a delta printer with 1.0.4dev. I'm using a 3DTouch v3.0 and everytime that I do a bed autolevel, I get some measures out of the bed...
I'm using n*n (with N = 5) measures and defined the following positions:
  • P1 -100 -100
  • P2  100 -100
  • P3 -100  100
My bed is circular and has a radius of ~350mm.
At some point, the measures start to go outside of the bed and I have to manually cancel it. It starts to measure height for values ~-150.
Q.1 = Any idea of what i'm doing wrong?
Another strange thing, if i select only 3 points as the Bed Measuring Method, the measurements are not aligned with the picture, it will not follow the order P1, P2 and P3, but yes a different order.
Q.2 = Is this also normal?
Thank you!
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    along with Repetier-Firmware.  If not, see <http://www.gnu.org/licenses/>.
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
   This file is optimized for version 1.0.3dev
   as you expect.
#define NUM_EXTRUDER 1
#define MOTHERBOARD 33
#include "pins.h"
#define HOST_RESCUE 1
#undef FAN_BOARD_PIN
#define FAN_BOARD_PIN -1
#define BOARD_FAN_SPEED 255
#define BOARD_FAN_MIN_SPEED 0
#define FAN_THERMO_PIN -1
//#define EXTERNALSERIAL  use Arduino serial library instead of build in. Requires more ram, has only 63 byte input buffer.
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL  -1
#define BLUETOOTH_BAUD  115200
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 3
#define XAXIS_STEPS_PER_MM 200
#define YAXIS_STEPS_PER_MM 200
#define ZAXIS_STEPS_PER_MM 200
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define DECOUPLING_TEST_MAX_HOLD_VARIANCE 40
#define RETRACT_ON_PAUSE 2
#define PAUSE_END_COMMANDS ""
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 234
#define EXT0_INVERSE 1
#define EXT0_ENABLE_ON 0
#define EXT0_MIRROR_STEPPER 0
#define EXT0_INVERSE2 0
#define EXT0_MAX_FEEDRATE 1500
#define EXT0_HEAT_MANAGER 3
#define EXT0_PREHEAT_TEMP 190
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 3
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define FILAMENTCHANGE_Z_ADD  2
#define JAM_METHOD 1
#define JAM_STEPS 220
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 1
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define TEMP_GAIN 0
#define HEATER_PWM_SPEED 0
#define COOLER_PWM_SPEED 0
#define HAVE_HEATED_BED 1
#define HEATED_BED_PREHEAT_TEMP 60
#define HEATED_BED_MAX_TEMP 100
#define SKIP_M190_IF_WITHIN 3
#define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
#define HEATED_BED_PID_IGAIN   33
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 275
#define MIN_DEFECT_TEMPERATURE -40
// ##                             Laser configuration                                      ##
automatically disabled.
#define SUPPORT_LASER 0
#define LASER_PIN -1
#define LASER_ON_HIGH 1
#define LASER_WARMUP_TIME 0
#define LASER_PWM_MAX 255
#define LASER_WATT 2
// ##                              CNC configuration                                       ##
#define SUPPORT_CNC 0
#define CNC_WAIT_ON_DISABLE 0
#define CNC_ENABLE_PIN -1
#define CNC_ENABLE_WITH 1
#define CNC_DIRECTION_PIN -1
#define CNC_DIRECTION_CW 1
#define CNC_PWM_MAX 255
#define CNC_RPM_MAX 8000
#define CNC_SAFE_Z 150
#define ENDSTOP_PULLUP_Y_MAX false
#define ENDSTOP_PULLUP_Z_MAX false
#define X2_MIN_PIN -1
#define X2_MAX_PIN -1
#define Y2_MIN_PIN -1
#define Y2_MAX_PIN -1
#define Z2_MINMAX_PIN -1
#define DOOR_PIN -1
#define DOOR_PULLUP 1
#define DOOR_INVERTING 0
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define MOVE_X_WHEN_HOMED 0
#define MOVE_Y_WHEN_HOMED 0
#define MOVE_Z_WHEN_HOMED 0
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 0
#define INVERT_X2_DIR 0
#define INVERT_Y_DIR 0
#define INVERT_Y2_DIR 0
#define INVERT_Z_DIR 0
#define INVERT_Z2_DIR 0
#define INVERT_Z3_DIR 0
#define INVERT_Z4_DIR 0
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR 1
#define X_MAX_LENGTH 200
#define Y_MAX_LENGTH 200
#define Z_MAX_LENGTH 314.2
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define PARK_POSITION_X 0
#define PARK_POSITION_Y 0
#define DISTORTION_LIMIT_TO 2
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 190
#define DISTORTION_YMAX 190
// ##                           Movement settings                                          ##
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_DIAGONAL_ROD 473 // mm
#define DELTA_ALPHA_A 210
#define DELTA_ALPHA_B 330
#define DELTA_ALPHA_C 90
#define DELTA_MAX_RADIUS 160
#define ROD_RADIUS 228
#define PRINTER_RADIUS 228
#define DELTA_HOME_ON_POWER 0
#define STEP_COUNTER
#define DELTA_FLOOR_SAFETY_MARGIN_MM 15
//#define SOFTWARE_LEVELING
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 200
#define MAX_FEEDRATE_Y 200
#define MAX_FEEDRATE_Z 200
#define HOMING_FEEDRATE_X 40
#define HOMING_FEEDRATE_Y 40
#define HOMING_FEEDRATE_Z 40
#define ZHOME_PRE_RAISE 0
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define ALLOW_QUADSTEPPING 1
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 100
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 100
#define MAX_JERK 20
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define DUAL_X_RESOLUTION 0
#define X2_STEP_PIN   ORIG_E1_STEP_PIN
#define X2_DIR_PIN    ORIG_E1_DIR_PIN
#define Y2_STEP_PIN   ORIG_E1_STEP_PIN
#define Y2_DIR_PIN    ORIG_E1_DIR_PIN
#define Z2_STEP_PIN   ORIG_E1_STEP_PIN
#define Z2_DIR_PIN    ORIG_E1_DIR_PIN
#define Z3_STEP_PIN   ORIG_E2_STEP_PIN
#define Z3_DIR_PIN    ORIG_E2_DIR_PIN
#define Z4_STEP_PIN   ORIG_E3_STEP_PIN
#define Z4_DIR_PIN    ORIG_E3_DIR_PIN
#define USE_ADVANCE 0
#define BAUDRATE 250000
#define POWER_INVERTING 0
#define AUTOMATIC_POWERUP 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 2
#undef PS_ON_PIN
#define JSON_OUTPUT 0
/* ======== Servos =======
Control the servos with
M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
#define FEATURE_SERVO 1
#define SERVO0_PIN 6
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define SERVO0_NEUTRAL_POS  -1
#define SERVO1_NEUTRAL_POS  -1
#define SERVO2_NEUTRAL_POS  -1
#define SERVO3_NEUTRAL_POS  -1
#define UI_SERVO_CONTROL 1
#define FAN_KICKSTART_TIME  200
#define MAX_FAN_PWM 127
        #define FEATURE_WATCHDOG 0
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 0
#define FEATURE_Z_PROBE 1
#define EXTRUDER_IS_Z_PROBE 0
#define Z_PROBE_BED_DISTANCE 20
#define Z_PROBE_PULLUP 1
#define Z_PROBE_ON_HIGH 1
#define Z_PROBE_X_OFFSET -34
#define Z_PROBE_Y_OFFSET -6
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 80
#define Z_PROBE_SWITCHING_DISTANCE 7
#define Z_PROBE_REPETITIONS 3
#define Z_PROBE_USE_MEDIAN 0
#define Z_PROBE_HEIGHT 3.3
#define Z_PROBE_DELAY 0
#define Z_PROBE_START_SCRIPT "M340 P0 S700"
#define Z_PROBE_FINISHED_SCRIPT "M340 P0 S1500"
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 -100
#define Z_PROBE_Y1 -100
#define Z_PROBE_X2 100
#define Z_PROBE_Y2 -100
#define Z_PROBE_X3 -100
#define Z_PROBE_Y3 100
#define BED_LEVELING_METHOD 1
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#ifndef SDSUPPORT  // Some boards have sd support on board. These define the values already in pins.h
#define SDSUPPORT 1
#undef SDCARDDETECT
#define SDCARDDETECT -1
#undef SDCARDDETECTINVERTED
#endif
#define SD_RUN_ON_STOP ""
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define FEATURE_CONTROLLER 2
#define ADC_KEYPAD_PIN -1
#define LANGUAGE_EN_ACTIVE 1
#define LANGUAGE_DE_ACTIVE 0
#define LANGUAGE_NL_ACTIVE 0
#define LANGUAGE_PT_ACTIVE 0
#define LANGUAGE_IT_ACTIVE 0
#define LANGUAGE_ES_ACTIVE 0
#define LANGUAGE_FI_ACTIVE 0
#define LANGUAGE_SE_ACTIVE 0
#define LANGUAGE_FR_ACTIVE 0
#define LANGUAGE_CZ_ACTIVE 0
#define LANGUAGE_PL_ACTIVE 0
#define LANGUAGE_TR_ACTIVE 0
#define LANGUAGE_RU_ACTIVE 0
#define UI_PRINTER_COMPANY "Goncalo"
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 2
#define UI_REVERSE_ENCODER 0
#define UI_KEY_BOUNCETIME 20
#define UI_KEY_FIRST_REPEAT 1000
#define UI_KEY_REDUCE_REPEAT 700
#define UI_KEY_MIN_REPEAT 500
#define FEATURE_BEEPER 0
#define CASE_LIGHTS_PIN -1
#define UI_DYNAMIC_ENCODER_SPEED 0
#define UI_SET_MIN_HEATED_BED_TEMP  30
#define UI_SET_MIN_EXTRUDER_TEMP   170
#define UI_SET_MAX_EXTRUDER_TEMP   260
#define NUM_MOTOR_DRIVERS 0
#endif
    "editMode": 1,
    "processor": 0,
    "baudrate": 250000,
    "bluetoothSerial": -1,
    "bluetoothBaudrate": 115200,
    "xStepsPerMM": 200,
    "yStepsPerMM": 200,
    "zStepsPerMM": 200,
    "xInvert": 0,
    "x2Invert": 0,
    "xInvertEnable": 0,
    "eepromMode": 2,
    "yInvert": 0,
    "y2Invert": 0,
    "yInvertEnable": 0,
    "zInvert": 0,
    "z2Invert": 0,
    "z3Invert": 0,
    "z4Invert": 0,
    "zInvertEnable": 0,
    "extruder": [
            "id": 0,
            "heatManager": 3,
            "pidDriveMin": 40,
            "pidDriveMax": 230,
            "pidMax": 255,
            "sensorType": 1,
            "sensorPin": "TEMP_0_PIN",
            "heaterPin": "HEATER_0_PIN",
            "maxFeedrate": 1500,
            "startFeedrate": 20,
            "invert": "1",
            "invertEnable": "0",
            "acceleration": 5000,
            "watchPeriod": 1,
            "pidP": 7,
            "pidI": 2,
            "pidD": 40,
            "advanceK": 0,
            "advanceL": 0,
            "waitRetractTemp": 150,
            "waitRetractUnits": 0,
            "waitRetract": 0,
            "stepsPerMM": 234,
            "coolerPin": -1,
            "coolerSpeed": 255,
            "selectCommands": "",
            "deselectCommands": "",
            "xOffset": 0,
            "yOffset": 0,
            "zOffset": 0,
            "xOffsetSteps": 0,
            "yOffsetSteps": 0,
            "zOffsetSteps": 0,
            "stepper": {
                "name": "Extruder 0",
                "step": "ORIG_E0_STEP_PIN",
                "dir": "ORIG_E0_DIR_PIN",
            "advanceBacklashSteps": 0,
            "decoupleTestPeriod": 12,
            "jamPin": -1,
            "jamPullup": "0",
            "mirror": "0",
            "invert2": "0",
            "stepper2": {
            "preheat": 190
    "uiLanguage": 0,
    "uiController": 0,
    "xMinEndstop": 0,
    "yMinEndstop": 0,
    "zMinEndstop": 4,
    "xMaxEndstop": 2,
    "yMaxEndstop": 4,
    "zMaxEndstop": 4,
    "x2MinEndstop": 0,
    "y2MinEndstop": 0,
    "x2MaxEndstop": 0,
    "y2MaxEndstop": 0,
    "motherboard": 33,
    "driveSystem": 3,
    "xMaxSpeed": 200,
    "xHomingSpeed": 40,
    "xTravelAcceleration": 100,
    "xPrintAcceleration": 1000,
    "yMaxSpeed": 200,
    "yHomingSpeed": 40,
    "yTravelAcceleration": 100,
    "yPrintAcceleration": 1000,
    "zMaxSpeed": 200,
    "zHomingSpeed": 40,
    "zTravelAcceleration": 100,
    "zPrintAcceleration": 100,
    "xMotor": {
        "name": "X motor",
        "step": "ORIG_X_STEP_PIN",
        "dir": "ORIG_X_DIR_PIN",
        "enable": "ORIG_X_ENABLE_PIN"
    "yMotor": {
        "name": "Y motor",
        "step": "ORIG_Y_STEP_PIN",
        "dir": "ORIG_Y_DIR_PIN",
        "enable": "ORIG_Y_ENABLE_PIN"
    "zMotor": {
        "name": "Z motor",
        "step": "ORIG_Z_STEP_PIN",
        "dir": "ORIG_Z_DIR_PIN",
        "enable": "ORIG_Z_ENABLE_PIN"
    "enableBacklash": "0",
    "backlashX": 0,
    "backlashY": 0,
    "backlashZ": 0,
    "stepperInactiveTime": 360,
    "maxInactiveTime": 0,
    "xMinPos": 0,
    "yMinPos": 0,
    "zMinPos": 0,
    "xLength": 200,
    "yLength": 200,
    "zLength": 314.2,
    "alwaysCheckEndstops": "0",
    "disableX": "0",
    "disableY": "0",
    "disableZ": "0",
    "disableE": "0",
    "xHomeDir": "-1",
    "yHomeDir": "-1",
    "zHomeDir": 1,
    "xEndstopBack": 1,
    "yEndstopBack": 1,
    "zEndstopBack": 0,
    "deltaDiagonalRod": 473,
    "deltaHorizontalRadius": 228,
    "deltaAlphaA": 210,
    "deltaAlphaB": 330,
    "deltaAlphaC": 90,
    "deltaDiagonalCorrA": 0,
    "deltaDiagonalCorrB": 0,
    "deltaDiagonalCorrC": 0,
    "deltaMaxRadius": 160,
    "deltaRadiusCorrA": 0,
    "deltaRadiusCorrB": 0,
    "deltaRadiusCorrC": 0,
    "deltaXOffsetSteps": 0,
    "deltaYOffsetSteps": 0,
    "deltaZOffsetSteps": 0,
    "deltaSegmentsPerLine": 24,
    "stepperHighDelay": 0,
    "directionDelay": 0,
    "allowQuadstepping": "1",
    "doubleStepDelay": 1,
    "maxJerk": 20,
    "maxZJerk": 0.3,
    "moveCacheSize": 16,
    "moveCacheLow": 10,
    "lowTicksPerMove": 250000,
    "enablePowerOnStartup": "1",
    "echoOnExecute": "1",
    "sendWaits": "1",
    "ackWithLineNumber": "1",
    "killMethod": 1,
    "useAdvance": "0",
    "useQuadraticAdvance": "0",
    "powerInverting": 0,
    "mirrorX": 0,
    "mirrorXMotor": {
        "name": "Extruder 1",
        "step": "ORIG_E1_STEP_PIN",
        "dir": "ORIG_E1_DIR_PIN",
    "mirrorY": 0,
    "mirrorYMotor": {
    "mirrorZ": 0,
    "mirrorZMotor": {
    "mirrorZ3": "0",
    "mirrorZ3Motor": {
        "name": "Extruder 2",
        "step": "ORIG_E2_STEP_PIN",
        "dir": "ORIG_E2_DIR_PIN",
    "mirrorZ4": "0",
    "mirrorZ4Motor": {
        "name": "Extruder 3",
        "step": "ORIG_E3_STEP_PIN",
        "dir": "ORIG_E3_DIR_PIN",
    "dittoPrinting": "0",
    "featureServos": "1",
    "servo0Pin": 6,
    "servo1Pin": -1,
    "servo2Pin": -1,
    "servo3Pin": -1,
    "featureWatchdog": "0",
    "hasHeatedBed": "1",
    "enableZProbing": "1",
    "extrudeMaxLength": 160,
    "featureController": 2,
    "uiPrinterName": "RepRap",
    "uiPrinterCompany": "Goncalo",
    "uiPagesDuration": 4000,
    "uiHeadline": "",
    "uiDisablePageswitch": "1",
    "uiAutoReturnAfter": 30000,
    "featureKeys": "0",
    "uiEncoderSpeed": 2,
    "uiReverseEncoder": "0",
    "uiKeyBouncetime": 20,
    "uiKeyFirstRepeat": 1000,
    "uiKeyReduceRepeat": 700,
    "uiKeyMinRepeat": 500,
    "featureBeeper": "0",
    "uiMinHeatedBed": 30,
    "uiMaxHeatedBed": 120,
    "uiMinEtxruderTemp": 170,
    "uiMaxExtruderTemp": 260,
    "uiExtruderFeedrate": 2,
    "maxBedTemperature": 100,
    "bedSensorType": 1,
    "bedSensorPin": "TEMP_1_PIN",
    "bedHeatManager": 0,
    "bedPreheat": 60,
    "bedUpdateInterval": 5000,
    "bedPidDriveMin": 80,
    "bedPidDriveMax": 255,
    "bedPidP": 196,
    "bedPidI": 33,
    "bedPidD": 290,
    "bedPidMax": 255,
    "bedDecoupleTestPeriod": 300,
    "caseLightPin": -1,
    "caseLightDefaultOn": "1",
    "bedSkipIfWithin": 3,
    "gen1T0": 25,
    "gen1R0": 100000,
    "gen1Beta": 4036,
    "gen1MinTemp": -20,
    "gen1MaxTemp": 300,
    "gen1R1": 0,
    "gen1R2": 4700,
    "gen2T0": 25,
    "gen2R0": 100000,
    "gen2Beta": 4036,
    "gen2MinTemp": -20,
    "gen2MaxTemp": 300,
    "gen2R1": 0,
    "gen2R2": 4700,
    "gen3T0": 25,
    "gen3R0": 100000,
    "gen3Beta": 4036,
    "gen3MinTemp": -20,
    "gen3MaxTemp": 300,
    "gen3R1": 0,
    "gen3R2": 4700,
    "userTable0": {
        "r1": 0,
        "r2": 4700,
        "temps": [],
        "numEntries": 0
    "userTable1": {
        "r1": 0,
        "r2": 4700,
        "temps": [],
        "numEntries": 0
    "userTable2": {
        "r1": 0,
        "r2": 4700,
        "temps": [],
        "numEntries": 0
    "tempHysteresis": 0,
    "pidControlRange": 20,
    "skipM109Within": 2,
    "extruderFanCoolTemp": 50,
    "minTemp": 150,
    "maxTemp": 275,
    "minDefectTemp": -40,
    "maxDefectTemp": 290,
    "arcSupport": "1",
    "forceChecksum": "0",
    "sdExtendedDir": "1",
    "featureFanControl": "1",
    "fanPin": "ORIG_FAN_PIN",
    "featureFan2Control": "0",
    "fan2Pin": "ORIG_FAN2_PIN",
    "fanThermoPin": -1,
    "fanThermoMinPWM": 128,
    "fanThermoMaxPWM": 255,
    "fanThermoMinTemp": 45,
    "fanThermoMaxTemp": 60,
    "fanThermoThermistorPin": -1,
    "fanThermoThermistorType": 1,
    "scalePidToMax": 0,
    "zProbePin": "ORIG_Z_MIN_PIN",
    "zProbeBedDistance": 20,
    "zProbeDisableHeaters": "0",
    "zProbePullup": "1",
    "zProbeOnHigh": "1",
    "zProbeXOffset": -34,
    "zProbeYOffset": -6,
    "zProbeWaitBeforeTest": "0",
    "zProbeSpeed": 2,
    "zProbeXYSpeed": 80,
    "zProbeHeight": 3.3,
    "zProbeStartScript": "M340 P0 S700",
    "zProbeFinishedScript": "M340 P0 S1500",
    "featureAutolevel": "1",
    "zProbeX1": -100,
    "zProbeY1": -100,
    "zProbeX2": 100,
    "zProbeY2": -100,
    "zProbeX3": -100,
    "zProbeY3": 100,
    "zProbeSwitchingDistance": 7,
    "zProbeRepetitions": 3,
    "zProbeMedian": "0",
    "zProbeEveryPoint": "",
    "sdSupport": "1",
    "sdCardDetectPin": -1,
    "sdCardDetectInverted": "0",
    "uiStartScreenDelay": 1000,
    "xEndstopBackMove": 5,
    "yEndstopBackMove": 5,
    "zEndstopBackMove": 2,
    "xEndstopRetestFactor": 3,
    "yEndstopRetestFactor": 3,
    "zEndstopRetestFactor": 3,
    "xMinPin": "ORIG_X_MIN_PIN",
    "yMinPin": "ORIG_Y_MIN_PIN",
    "zMinPin": "ORIG_Z_MIN_PIN",
    "xMaxPin": "ORIG_X_MAX_PIN",
    "yMaxPin": "ORIG_Y_MAX_PIN",
    "zMaxPin": "ORIG_Z_MAX_PIN",
    "x2MinPin": -1,
    "y2MinPin": -1,
    "x2MaxPin": -1,
    "y2MaxPin": -1,
    "deltaHomeOnPower": "0",
    "fanBoardPin": -1,
    "heaterPWMSpeed": 0,
    "featureBabystepping": "1",
    "babystepMultiplicator": 1,
    "pdmForHeater": "0",
    "pdmForCooler": "0",
    "psOn": "ORIG_PS_ON_PIN",
    "mixingExtruder": "0",
    "decouplingTestMaxHoldVariance": 40,
    "featureAxisComp": "0",
    "axisCompTanXY": 0,
    "axisCompTanXZ": 0,
    "axisCompTanYZ": 0,
    "retractOnPause": 2,
    "pauseStartCommands": "",
    "pauseEndCommands": "",
    "distortionCorrection": "0",
    "distortionCorrectionR": 100,
    "distortionPermanent": "1",
    "distortionEndDegrade": 1,
    "distortionXMin": 10,
    "distortionXMax": 190,
    "distortionYMin": 10,
    "distortionYMax": 190,
    "sdRunOnStop": "",
    "featureRetraction": "1",
    "autoretractEnabled": "0",
    "retractionLength": 3,
    "retractionLongLength": 13,
    "retractionSpeed": 40,
    "retractionZLift": 0,
    "retractionUndoSpeed": 20,
    "filamentChangeXPos": 0,
    "filamentChangeYPos": 0,
    "filamentChangeZAdd": 2,
    "filamentChangeRehome": 1,
    "fanKickstart": 200,
    "servo0StartPos": -1,
    "servo1StartPos": -1,
    "servo2StartPos": -1,
    "servo3StartPos": -1,
    "uiDynamicEncoderSpeed": "0",
    "uiServoControl": 1,
    "killIfSensorDefect": "0",
    "jamSteps": 220,
    "jamSlowdownSteps": 320,
    "jamSlowdownTo": 70,
    "jamErrorSteps": 500,
    "jamMinSteps": 10,
    "jamAction": 1,
    "jamMethod": 1,
    "primaryPort": 0,
    "numMotorDrivers": 0,
    "motorDrivers": [
            "t": "None",
            "s": "",
            "invertDirection": "0",
            "stepsPerMM": 100,
            "speed": 10,
            "dirPin": -1,
            "stepPin": -1,
            "enablePin": -1,
            "endstopPin": -1,
            "invertEndstop": "0",
            "minEndstop": "1",
            "endstopPullup": "1",
            "maxDistance": 20
            "t": "None",
            "s": "",
            "stepsPerMM": 100,
            "speed": 10,
            "dirPin": -1,
            "stepPin": -1,
            "enablePin": -1,
            "endstopPin": -1,
            "minEndstop": "1",
            "maxDistance": 20
            "t": "None",
            "s": "",
            "stepsPerMM": 100,
            "speed": 10,
            "dirPin": -1,
            "stepPin": -1,
            "enablePin": -1,
            "endstopPin": -1,
            "minEndstop": "1",
            "maxDistance": 20
            "t": "None",
            "s": "",
            "stepsPerMM": 100,
            "speed": 10,
            "dirPin": -1,
            "stepPin": -1,
            "enablePin": -1,
            "endstopPin": -1,
            "minEndstop": "1",
            "maxDistance": 20
            "t": "None",
            "s": "",
            "stepsPerMM": 100,
            "speed": 10,
            "dirPin": -1,
            "stepPin": -1,
            "enablePin": -1,
            "endstopPin": -1,
            "minEndstop": "1",
            "maxDistance": 20
            "t": "None",
            "s": "",
            "stepsPerMM": 100,
            "speed": 10,
            "dirPin": -1,
            "stepPin": -1,
            "enablePin": -1,
            "endstopPin": -1,
            "minEndstop": "1",
            "maxDistance": 20
    "manualConfig": "",
    "zHomeMinTemperature": 0,
    "zHomeXPos": 999999,
    "zHomeYPos": 999999,
    "zHomeHeatHeight": 20,
    "zHomeHeatAll": "1",
    "zProbeZOffsetMode": 0,
    "zProbeZOffset": 0,
    "zProbeDelay": 0,
    "uiBedCoating": "0",
    "langEN": "1",
    "langDE": "0",
    "langNL": "0",
    "langPT": "0",
    "langIT": "0",
    "langES": "0",
    "langFI": "0",
    "langSE": "0",
    "langFR": "0",
    "langCZ": "0",
    "langPL": "0",
    "langTR": "0",
    "langRU": "0",
    "accelerationFactorTop": 100,
    "bendingCorrectionA": 0,
    "bendingCorrectionB": 0,
    "bendingCorrectionC": 0,
    "supportLaser": "0",
    "laserPin": -1,
    "laserOnHigh": "1",
    "laserWarmupTime": 0,
    "defaultPrinterMode": 0,
    "laserPwmMax": 255,
    "laserWatt": 2,
    "supportCNC": "0",
    "cncWaitOnEnable": 300,
    "cncWaitOnDisable": 0,
    "cncEnablePin": -1,
    "cncEnableWith": "1",
    "cncDirectionPin": -1,
    "cncDirectionCW": "1",
    "cncPwmMax": 255,
    "cncRpmMax": 8000,
    "cncSafeZ": 150,
    "startupGCode": "",
    "jsonOutput": "0",
    "bedLevelingMethod": 1,
    "bedCorrectionMethod": 0,
    "bedLevelingGridSize": 5,
    "bedLevelingRepetitions": 5,
    "bedMotor1X": 0,
    "bedMotor1Y": 0,
    "bedMotor2X": 200,
    "bedMotor2Y": 0,
    "bedMotor3X": 100,
    "bedMotor3Y": 200,
    "zProbeRequiresHeating": "0",
    "zProbeMinTemperature": 150,
    "adcKeypadPin": -1,
    "sharedExtruderHeater": "0",
    "extruderSwitchXYSpeed": 100,
    "dualXAxis": "0",
    "boardFanSpeed": 255,
    "keepAliveInterval": 2000,
    "moveXWhenHomed": "0",
    "moveYWhenHomed": "0",
    "moveZWhenHomed": "0",
    "preheatTime": 30000,
    "multiZEndstopHoming": "0",
    "z2MinMaxPin": -1,
    "z2MinMaxEndstop": 0,
    "extruderIsZProbe": "0",
    "boardFanMinSpeed": 0,
    "doorPin": -1,
    "doorEndstop": 0,
    "zhomePreRaise": 0,
    "zhomePreRaiseDistance": 10,
    "dualXResolution": "0",
    "x2axisStepsPerMM": 100,
    "coolerPWMSpeed": 0,
    "maxFanPWM": 127,
    "raiseZOnToolchange": 0,
    "distortionLimitTo": 2,
    "automaticPowerup": 0,
    "hasTMC2130": "0",
    "TMC2130Sensorless": "0",
    "TMC2130Steathchop": "1",
    "TMC2130Interpolate256": "1",
    "TMC2130StallguardSensitivity": 0,
    "TMC2130PWMAmpl": 255,
    "TMC2130PWMGrad": 1,
    "TMC2130PWMAutoscale": "1",
    "TMC2130PWMFreq": 2,
    "TMC2130CSX": -1,
    "TMC2130CSY": -1,
    "TMC2130CSZ": -1,
    "TMC2130CSE0": -1,
    "TMC2130CSE1": -1,
    "TMC2130CSE2": -1,
    "TMC2130CSE3": -1,
    "TMC2130CSE4": -1,
    "TMC2130CurrentX": 1000,
    "TMC2130CurrentY": 1000,
    "TMC2130CurrentZ": 1000,
    "TMC2130CurrentE0": 1000,
    "TMC2130CurrentE1": 1000,
    "TMC2130CurrentE2": 1000,
    "TMC2130CurrentE3": 1000,
    "TMC2130CurrentE4": 1000,
    "TMC2130CoolstepTresholdX": 300,
    "TMC2130CoolstepTresholdY": 300,
    "TMC2130CoolstepTresholdZ": 300,
    "microstepX": 16,
    "microstepY": 16,
    "microstepZ": 16,
    "microstepE0": 16,
    "microstepE1": 16,
    "microstepE2": 16,
    "microstepE3": 16,
    "microstepE4": 16,
    "parkPosX": 0,
    "parkPosY": 0,
    "parkPosZ": 10,
    "emergencyParser": -1,
    "hostRescue": "1",
    "MAX31855SwCS": -1,
    "MAX31855SwCLK": -1,
    "tempGain": "0",
    "maxHalfstepInterval": 1999,
    "uiAnimation": "1",
    "uiPresetBedTempPLA": 60,
    "uiPresetBedABS": 110,
    "uiPresetExtruderPLA": 190,
    "uiPresetExtruderABS": 240,
    "hasMAX6675": false,
    "hasMAX31855": false,
    "hasGeneric1": false,
    "hasGeneric2": false,
    "hasGeneric3": false,
    "hasUser0": false,
    "hasUser1": false,
    "hasUser2": false,
    "numExtruder": 1,
    "version": 100.4,
    "primaryPortName": "",
    "hasMAX31855SW": false
  • Positions should be reachable even with z probe offset. You also span rectangle correctly with the given values as it seems. So please have a look into eeprom if there are different values from an earlier upload.
  • Thank you for your answer, it really means a lot to me.
    Here are the values that I have on my eeprom:
    <epr pos="808" type="3" value="3.300">Z-probe height</epr>
    <epr pos="929" type="3" value="10.000">Max. z-probe - bed dist.</epr>
    <epr pos="812" type="3" value="2.000">Z-probe speed</epr>
    <epr pos="840" type="3" value="80.000">Z-probe x-y-speed</epr>
    <epr pos="800" type="3" value="-34.000">Z-probe offset x</epr>
    <epr pos="804" type="3" value="6.000">Z-probe offset y</epr>
    <epr pos="816" type="3" value="100.000">Z-probe X1</epr>
    <epr pos="820" type="3" value="-100.000">Z-probe Y1</epr>
    <epr pos="824" type="3" value="-100.000">Z-probe X2</epr>
    <epr pos="828" type="3" value="-100.000">Z-probe Y2</epr>
    <epr pos="832" type="3" value="-100.000">Z-probe X3</epr>
    <epr pos="836" type="3" value="100.000">Z-probe Y3</epr>
    <epr pos="1036" type="3" value="0.000">Z-probe bending correction A</epr>
    <epr pos="1040" type="3" value="0.000">Z-probe bending correction B</epr>
    <epr pos="1044" type="3" value="0.000">Z-probe bending correction C</epr>
    <epr pos="880" type="0" value="0">
    I think they are NOT OK. The P1, P2 and P3 have different values from the ones on the firmware.
    I will change them and see if it works.
  • I worked.
    Thank you.
