Problem compiling
Hello!
I'm having the following error.
1.0.4dev with LCD2004 display.
Any guidance plz?
sketch\Commands.cpp: In static member function 'static void Commands::commandLoop()':
Commands.cpp:37:13: error: 'sd' was not declared in this scope
         if (sd.sdmode == 20) {
sketch\Commands.cpp:37:13: note: suggested alternative: 'sq'
             sq
Commands.cpp:42:13: error: 'sd' was not declared in this scope
         if (sd.sdmode == 21) {
sketch\Commands.cpp:42:13: note: suggested alternative: 'sq'
             sq
Commands.cpp:54:17: error: 'sd' was not declared in this scope
             if (sd.savetosd) {
sketch\Commands.cpp:54:17: note: suggested alternative: 'sq'
             if (sd.savetosd) {
                 sq
sketch\Commands.cpp: In static member function 'static void Commands::waitUntilEndOfAllBuffers()':
Commands.cpp:151:17: error: 'sd' was not declared in this scope
             if (sd.savetosd) {
sketch\Commands.cpp:151:17: note: suggested alternative: 'sq'
             if (sd.savetosd) {
                 sq
sketch\Commands.cpp: In static member function 'static void Commands::processMCode(GCode*)':
Commands.cpp:2184:9: error: 'sd' was not declared in this scope
         sd.ls();
sketch\Commands.cpp:2184:9: note: suggested alternative: 'sq'
         sd.ls();
         sq
sketch\Printer.cpp: In static member function 'static void Printer::setup()':
Printer.cpp:1388:5: error: 'sd' was not declared in this scope
     sd.mount();
sketch\Printer.cpp:1388:5: note: suggested alternative: 'sq'
     sd.mount();
     sq
sketch\Printer.cpp: In static member function 'static void Printer::pausePrint()':
Printer.cpp:2821:9: error: 'sd' was not declared in this scope
         sd.pausePrint(true);
sketch\Printer.cpp:2821:9: note: suggested alternative: 'sq'
         sq
sketch\Printer.cpp: In static member function 'static void Printer::continuePrint()':
Printer.cpp:2836:9: error: 'sd' was not declared in this scope
         sd.continuePrint(true);
sketch\Printer.cpp:2836:9: note: suggested alternative: 'sq'
         sq
sketch\Printer.cpp: In static member function 'static void Printer::stopPrint()':
Printer.cpp:2851:9: error: 'sd' was not declared in this scope
         sd.stopPrint();
sketch\Printer.cpp:2851:9: note: suggested alternative: 'sq'
         sd.stopPrint();
         sq
Multiple libraries were found for "SPI.h"
 Used: C:\Program
exit status 1
