wifi config how to
I have looked to no avail on how to configure repetier for wifi. Can someone point me to tinstuctions on how to enable wifi in repetier?
  • Normally you define wifi in your os. For your wifi image for raspberry pi there is a way to do it in General Settings->WLAN - this is just a helper interface that sends the linux commands as required.
    Here I assume you mean Repetier-Server and not firmware since firmware has no wifi support except if you have a wifi to serial module, but then you need to configure the module first.
  • Thank You for your reply. You pointed me in the right direction. Going to look at the Rep-server.
