Nema 8 Stalls at high speeds
Hello Everyone,
I'm experimenting with an extruder that I made that has a 40:1 reduction ratio; This is necessary since the motor moving the extruder is a tiny Nema 8. In order to make the extruder push the filament at a desired rate, I had to set the Steps per mm of the extruder motor at 5841 and that bring the stalling Problem:
With those steps per mm, I can't move the extruder with feed rates above 220mm/min because it starts Stalling.
I tried a couple of things to fix it, First I change the current from the board but the problem remains. Then I tried to place a Nema 17 instead of the Nema 8 and it still has the same issue, at the same feedrate.
How can I fix this? Is there any setup that I'm missing that could let me move the motor faster?
I have seen plenty of NEMA 8 and 17 running really fast so I don't think the problem is on the motor itself.
Thanks!
Thanks!
The board that I'm using is a very shitty MKS Base V1.4 which is base in an arduino Mega 2560, It doesn't have any jumper to change the microstepping of the motor. All the tests that I mention above were done with no load, so the load is not a problem (yet...). I will try the same extruder on another printer that actually has jumpers and see if I can make it work.
I already search everywhere and I'm pretty sure is not possible, but is there any way to reduce the microstep level from the firmware? or, do you know if there is any method to reduce the microsteps on this shitty boards?
(the drivers of the board are A4982 and are integrated)
After some time I purchase a propper Arduino Mega 2560 + Ramps 1.6 and DRV8825 for my printer. I'm going over this idea again and I found some issues:
I set the driver to run on full steps (withoud any jumper), then I enter the correct step/mm on the firmware (200 steps/Revolution, 40:1 reduction, 7mm diameter pusher gear so -> 364 step/mm) and the extruder keeps stalling. I tried lowering the frequence when double and quad stepping kicks in to 10000hz and changing the DOUBLE_STEP_DELAY from 0 to 1ms, but it didn't chage anything. Then I Tried disabling quad stepping and the results where the same, what leads me to believe that the quadstepping wasn't kicking in in my previous test
Just to give a little more information:
I tried the same test with Marlin and the results were promising but not entirely, in that case the extruder run Perfectly ok at any RPM when the Steps/mm where 200, but as soon as I put 364, the extruder couldn't go above 5.5mm/s. This is VERY weird since with 200 the extruder could easily go to up to 150mm/s.
Thanks in advance for your help,
With 100 steps/mm, can literallty run at any speed, I tested even with G1 E200 F48000 and it spined like a propeller. But as soon as I change the steps/mm to 200 or 400, it can not go above F1800. All this test were done with the quadstepping turned off and on with the same result.
Why is this happenning? In my mind, if the extruder is able to run at 200mm/s with 100step/mm, it SHOULD be able to run 100mm/s with 200 step/mm, since the signals send to the stepper are technically the same. I want to clarify that I don't know anything on how the firmware internally works so I could be saying really dumb things.
Thanks,
