RepRapdiscount full graphics smart controller won't work in Repetier
I built an adapter for my Melzi board so I could use the RepRapdiscount graphics smart controller with Repetier firmware but I can't get it to compile without an error about dio49. It works ok with Marlin firmware flashed but I can't get all the parameters correct in Marlin. I tried to change the eeprom parameters in Repetier-host but all I get is a blank window. What am I doing wrong?
which starts definition of pins. Followed by parts for each board like line 380
You are falling into the else part for RAMPS since your board is not listed so there you have to change the pin numbers.
In ui.h you also find in line 733
Here you see where the pin 49 comes from which you also need to adjust to your used pin..
