Feeds slower than F300 (mm/min) are not respected
I have a Monoprice Maker Select which reports that it is running Repetier 0.91. I'm sure this is quite old, and that upgrading is probably the fix for this. Nevertheless, I wanted to see if anyone is aware of this as a feature, etc:
Any G0/G1 commands with F < 300 (mm/min) travel at 300. Faster speeds behave as expected.
Thanks for any input.
  • There is in deed a technical required minimum speed so acceleration works as expected. That speed depends on the acceleration. Lower accelerations also allow lower speeds. I guess that is what you are experiencing. Only with V2 where we switched the math for motion this can be slower.
  • Thanks for the information, this is helpful!
