Firmware Update Melzi 2.0v5
I recently bought a cheap knockoff printer modeled after a Tronxy P802E that has a Melzi 2.0v5 control board. The current Repetier firmware installed on the board is 0.91, and I would like to update to a more recent version. After much serching I was able to find a Configuration.h (the complete file is included below) that is purported to be for the installed 0.91 firmware. I have been going through the file and the Repetier-Firmware configuration tool trying to configure a new firmware. I'm stuck trying to configure the heated bed and the extruder. The relavent portion of the configuration file is:
#if 0
#define EXT0_TEMPSENSOR_TYPE 1#define HEATED_BED_SENSOR_TYPE 1
#elif 0
#define EXT0_TEMPSENSOR_TYPE 97
#define HEATED_BED_SENSOR_TYPE 97
#define USE_GENERIC_THERMISTORTABLE_1
#define GENERIC_THERM1_T0 25
#define GENERIC_THERM1_R0 100000
#define GENERIC_THERM1_BETA 3950
#define GENERIC_THERM1_MIN_TEMP -20
#define GENERIC_THERM1_MAX_TEMP 300
#define GENERIC_THERM1_R1 0
#define GENERIC_THERM1_R2 4700
#else
#define EXT0_TEMPSENSOR_TYPE 5
#define NUM_TEMPS_USERTHERMISTOR0 58
#define USER_THERMISTORTABLE0 { \
{ 56,300*8},{ 59,295*8},{ 64,290*8},{ 70,285*8},{ 76,280*8},{ 82,275*8},{ 89,270*8},{ 98,265*8},\
{ 108,260*8},{ 118,255*8},{ 128,250*8},{ 145,245*8},{ 156,240*8},{ 168,235*8},{ 187,230*8},{ 208,225*8},\
{ 227,220*8},{ 248,215*8},{ 272,210*8},{ 301,205*8},{ 336,200*8},{ 370,195*8},{ 400,190*8},{ 450,185*8},\
{ 492,180*8},{ 552,175*8},{ 615,170*8},{ 690,165*8},{ 750,160*8},{ 830,155*8},{ 920,150*8},{1010,145*8},\
{1118,140*8},{1215,135*8},{1330,130*8},{1460,125*8},{1594,120*8},{1752,115*8},{1900,110*8},{2040,105*8},\
{2200,100*8},{2350, 95*8},{2516, 90*8},{2671, 85*8},{2831, 80*8},{2975, 75*8},{3115, 70*8},{3251, 65*8},\
{3375, 60*8},{3480, 55*8},{3580, 50*8},{3660, 45*8},{3740, 40*8},{3869, 30*8},{3912, 25*8},{3948, 20*8},\
{4077,-20*8},{4094,-55*8}}
#define HEATED_BED_SENSOR_TYPE 6
#define NUM_TEMPS_USERTHERMISTOR1 33
#define USER_THERMISTORTABLE1 { \
{ 56,300*8},{ 187,250*8},{ 615,190*8},{ 690,185*8},{ 750,180*8},{ 830,175*8},{ 920,170*8},{1010,165*8},\
{1118,160*8},{1215,155*8},{1330,145*8},{1460,140*8},{1594,135*8},{1752,130*8},{1900,125*8},{2040,120*8},\
{2200,115*8},{2350,110*8},{2516,105*8},{2671, 98*8},{2831, 92*8},{2975, 85*8},{3115, 76*8},{3251, 72*8},\
{3480, 62*8},{3580, 52*8},{3660, 46*8},{3740, 40*8},{3869, 30*8},{3912, 25*8},{3948, 20*8},{4077,-20*8},\
{4094,-55*8}}
If I read this correctly, then the HEATED_BED_SENSOR_TYPE, and the EXT0_TEMPSENSOR_TYPE are defined as user defined tables 1 and 0 respectively. I'm not sure exactly how to enter the data in USER_THERMISTORTABLE1, and USER_THERMISTORTABLE0 using the web interface. I read the comments in another configuration file that the above tables are (adc,temperature) values, but the web interface asks for temperature and resistance.
If I do the calculations for the resistance using the first entry, {56,300*8}, I get 56.148148... ohms. Since 56.148148... is a repeating decimal, I can never put in a value for the resistance that will recover the adc value. What is the correct way to input the data tables?
**************************Full Configuration.h file*****************************
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
This file is optimized for version 0.91
generator: http://www.repetier.com/firmware/v091/
#define NUM_EXTRUDER 1
#define MOTHERBOARD 63
#include "pins.h"
// ################## ADD BY Hally ################
//#define ENABLE_BLUETOOTH
//for ADC KEYPAD
#define HAVE_ADC_KEYPAD true
#define HAVE_LCD true
#define AUXILIARY_LEVELING true
#define AUX_LEVEL_GOTOP1_SCRIPT "G1 Z3 F600\nG1 X10 Y10 F6000\nG1 Z0.2 F600\n"
#define AUX_LEVEL_GOTOP2_SCRIPT "G1 Z3 F600\nG1 X190 Y10 F6000\nG1 Z0.2 F600\n"
#define AUX_LEVEL_GOTOP3_SCRIPT "G1 Z3 F600\nG1 X190 Y190 F6000\nG1 Z0.2 F600\n"
#define AUX_LEVEL_GOTOP4_SCRIPT "G1 Z3 F600\nG1 X10 Y190 F6000\nG1 Z0.2 F600\n"
#define FAN_BOARD_PIN -1//ORIG_FAN2_PIN
// Uncomment the following line if you are using arduino compatible firmware made for Arduino version earlier then 1.0
// If it is incompatible you will get compiler errors about write functions not beeing compatible!
//#define COMPAT_PRE1
#define DRIVE_SYSTEM 0
#define XAXIS_STEPS_PER_MM 100
#define YAXIS_STEPS_PER_MM 100
#define ZAXIS_STEPS_PER_MM 400
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_STEPS_PER_MM 90
#define EXT0_INVERSE 0
#define EXT0_ENABLE_PIN E0_ENABLE_PIN
#define EXT0_ENABLE_ON 0
#define EXT0_MAX_FEEDRATE 50
#define EXT0_HEAT_MANAGER 3
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_INTEGRAL_DRIVE_MIN 50
#define EXT0_PID_P 7
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 1
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define HEATER_PWM_SPEED 0
#define HAVE_HEATED_BED 1
#define SKIP_M190_IF_WITHIN 3
#define HEATED_BED_PID_PGAIN 196
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 275
#if 0
#elif 0
#else
{4094,-55*8}}
#endif
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 0
#define INVERT_Y_DIR 0
#define INVERT_Z_DIR 1///0
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define X_MAX_LENGTH 265
#define Y_MAX_LENGTH 235
#define Z_MAX_LENGTH 180
#define X_MIN_POS -45
#define Y_MIN_POS -5
#define Z_MIN_POS 0
// ## Movement settings ##
#define FEATURE_BABYSTEPPING 0///1
#define BABYSTEP_MULTIPLICATOR 100///1
// Delta settings
#define DELTA_HOME_ON_POWER 0
#define MAX_DELTA_SEGMENTS_PER_LINE 24
#define STEPPER_INACTIVE_TIME 360L//S
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 400
#define MAX_FEEDRATE_Y 400
#define MAX_FEEDRATE_Z 4
#define HOMING_FEEDRATE_X 100
#define HOMING_FEEDRATE_Y 100
#define HOMING_FEEDRATE_Z 2
#define HOMING_ORDER HOME_ORDER_XYZ
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define ALLOW_QUADSTEPPING 1
#define MAX_HALFSTEP_INTERVAL 1999
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 400
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 400
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 400
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 400
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 400
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 400
#define MAX_JERK 20
#define MAX_ZJERK 0.3
#define MOVE_CACHE_SIZE 16
#define MOVE_CACHE_LOW 10
#define X2_STEP_PIN ORIG_E2_STEP_PIN//ORIG_E2_STEP_PIN
#define X2_DIR_PIN ORIG_E2_DIR_PIN
#define X2_ENABLE_PIN ORIG_E2_ENABLE_PIN
#define Y2_STEP_PIN ORIG_E2_STEP_PIN
#define Y2_DIR_PIN ORIG_E2_DIR_PIN
#define Y2_ENABLE_PIN ORIG_E2_ENABLE_PIN
#define Z2_STEP_PIN ORIG_E2_STEP_PIN
#define Z2_DIR_PIN ORIG_E2_DIR_PIN
#define Z2_ENABLE_PIN ORIG_E2_ENABLE_PIN
#define BAUDRATE 115200
#define ENABLE_POWER_ON_STARTUP
#define POWER_INVERTING 0
#define KILL_METHOD 1
#define GCODE_BUFFER_SIZE 2
#define ACK_WITH_LINENUMBER
#define ECHO_ON_EXECUTE
#define EEPROM_MODE 16
/* ======== Servos =======
Control the servos with
#define FEATURE_SERVO 0
#define SERVO0_PIN 11
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define FEATURE_WATCHDOG 0///1
#define AUTO_LEVEL_DEBUG 0
#define FEATURE_Z_PROBE 0
#define Z_PROBE_BED_DISTANCE 4
#define Z_PROBE_PIN -1
#define Z_PROBE_PULLUP 1
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 200
#define Z_PROBE_SWITCHING_DISTANCE 0.3
#define Z_PROBE_REPETITIONS 2
#define Z_PROBE_HEIGHT 5
#define Z_PROBE_START_SCRIPT "G28 Y0 X0\n G1 X-40\n G28 Z0\n G1 Z5\n"
#define Z_PROBE_FINISHED_SCRIPT "G28 X0 Y200\n"
#define FEATURE_AUTOLEVEL 0
#define Z_PROBE_X0 -30
#define Z_PROBE_Y0 -5
#define Z_PROBE_X1 150
#define Z_PROBE_Y1 -5
#define Z_PROBE_X2 150
#define Z_PROBE_Y2 160
#define Z_PROBE_X3 -30
#define Z_PROBE_Y3 160
#define SDSUPPORT 1
#define SDCARDDETECT -1
#endif
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define FEATURE_CONTROLLER 16//8
#define UI_LANGUAGE 0
#define UI_PRINTER_NAME "X6D_8"
#define UI_FIRWWARE_VERSION "X6D_8_V1.6"
#define UI_PRINTER_COMPANY "3D Printer"
#define UI_PAGES_DURATION 5000
#define UI_ANIMATION 1
#define UI_SPEEDDEPENDENT_POSITIONING false
#define UI_AUTORETURN_TO_MENU_AFTER 50000
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 0
#define UI_KEY_BOUNCETIME 2
#define UI_KEY_FIRST_REPEAT 250
#define UI_KEY_REDUCE_REPEAT 25
#define UI_KEY_MIN_REPEAT 25
#define FEATURE_BEEPER 0
#define CASE_LIGHTS_PIN -1
#define UI_SET_PRESET_HEATED_BED_TEMP_PLA 55
#define UI_SET_PRESET_EXTRUDER_TEMP_PLA 190
#define UI_SET_PRESET_HEATED_BED_TEMP_ABS 85
#define UI_SET_PRESET_EXTRUDER_TEMP_ABS 240
#endif
"editMode": 2,
"processor": 0,
"baudrate": 115200,
"xStepsPerMM": 100,
"yStepsPerMM": 100,
"zStepsPerMM": 400,
"xInvert": 0,
"xInvertEnable": 0,
"eepromMode": 1,
"yInvert": 0,
"yInvertEnable": 0,
"zInvert": 0,
"zInvertEnable": 0,
"extruder": [
"id": 0,
"heatManager": 3,
"pidDriveMin": 40,
"pidDriveMax": 230,
"pidMax": 255,
"sensorType": 100,
"sensorPin": "TEMP_0_PIN",
"heaterPin": "HEATER_0_PIN",
"maxFeedrate": 50,
"startFeedrate": 20,
"invert": "0",
"invertEnable": "0",
"acceleration": 5000,
"watchPeriod": 1,
"pidP": 7,
"pidI": 2,
"pidD": 40,
"advanceK": 0,
"advanceL": 0,
"waitRetractTemp": 150,
"waitRetractUnits": 0,
"waitRetract": 0,
"stepsPerMM": 160,
"coolerPin": -1,
"coolerSpeed": 255,
"selectCommands": "",
"deselectCommands": "",
"xOffset": 0,
"yOffset": 0,
"xOffsetSteps": 0,
"yOffsetSteps": 0,
"stepper": {
"name": "Extruder 0",
"step": "ORIG_E0_STEP_PIN",
"dir": "ORIG_E0_DIR_PIN",
"enable": "E0_ENABLE_PIN"
"advanceBacklashSteps": 0
"uiLanguage": 0,
"uiController": 0,
"xMinEndstop": 1,
"yMinEndstop": 1,
"zMinEndstop": 1,
"xMaxEndstop": 1,
"yMaxEndstop": 1,
"zMaxEndstop": 1,
"motherboard": 701,
"driveSystem": 0,
"xMaxSpeed": 50,
"xHomingSpeed": 40,
"xTravelAcceleration": 200,
"xPrintAcceleration": 200,
"yMaxSpeed": 50,
"yHomingSpeed": 40,
"yTravelAcceleration": 200,
"yPrintAcceleration": 200,
"zMaxSpeed": 2,
"zHomingSpeed": 2,
"zTravelAcceleration": 100,
"zPrintAcceleration": 100,
"xMotor": {
"name": "X motor",
"step": "ORIG_X_STEP_PIN",
"dir": "ORIG_X_DIR_PIN",
"enable": "ORIG_X_ENABLE_PIN"
"yMotor": {
"name": "Y motor",
"step": "ORIG_Y_STEP_PIN",
"dir": "ORIG_Y_DIR_PIN",
"enable": "ORIG_Y_ENABLE_PIN"
"zMotor": {
"name": "Z motor",
"step": "ORIG_Z_STEP_PIN",
"dir": "ORIG_Z_DIR_PIN",
"enable": "ORIG_Z_ENABLE_PIN"
"enableBacklash": "1",
"backlashX": 0,
"backlashY": 0,
"backlashZ": 0,
"stepperInactiveTime": 360,
"maxInactiveTime": 0,
"xMinPos": 0,
"yMinPos": 0,
"zMinPos": 0,
"xLength": 200,
"yLength": 200,
"zLength": 120,
"alwaysCheckEndstops": "1",
"disableX": "0",
"disableY": "0",
"disableZ": "0",
"disableE": "0",
"xHomeDir": "-1",
"yHomeDir": "-1",
"zHomeDir": "-1",
"xEndstopBack": 1,
"yEndstopBack": 1,
"zEndstopBack": 0,
"deltaDiagonalRod": 445,
"deltaAlphaA": 210,
"deltaAlphaB": 330,
"deltaAlphaC": 90,
"deltaDiagonalCorrA": 0,
"deltaDiagonalCorrB": 0,
"deltaDiagonalCorrC": 0,
"deltaMaxRadius": 150,
"deltaRadiusCorrA": 0,
"deltaRadiusCorrB": 0,
"deltaRadiusCorrC": 0,
"deltaXOffsetSteps": 0,
"deltaYOffsetSteps": 0,
"deltaZOffsetSteps": 0,
"deltaSegmentsPerLine": 24,
"stepperHighDelay": 0,
"allowQuadstepping": "1",
"doubleStepDelay": 1,
"maxHalfstepInterval": 1999,
"maxJerk": 20,
"maxZJerk": 0.3,
"moveCacheSize": 16,
"moveCacheLow": 10,
"lowTicksPerMove": 250000,
"enablePowerOnStartup": "1",
"echoOnExecute": "1",
"sendWaits": "1",
"ackWithLineNumber": "1",
"killMethod": 1,
"useAdvance": "0",
"useQuadraticAdvance": "0",
"powerInverting": 0,
"mirrorX": 0,
"mirrorXMotor": {
"name": "Extruder 1",
"step": "ORIG_E1_STEP_PIN",
"dir": "ORIG_E1_DIR_PIN",
"enable": "E1_ENABLE_PIN"
"mirrorY": 0,
"mirrorYMotor": {
"mirrorZ": 0,
"mirrorZMotor": {
"dittoPrinting": "0",
"featureServos": "0",
"servo0Pin": 11,
"servo1Pin": -1,
"servo2Pin": -1,
"servo3Pin": -1,
"featureWatchdog": "1",
"hasHeatedBed": "0",
"enableZProbing": "0",
"extrudeMaxLength": 160,
"homeOrder": "HOME_ORDER_XYZ",
"featureController": 8,
"uiPrinterName": "RepRap",
"uiPrinterCompany": "Home made",
"uiPagesDuration": 4000,
"uiAnimation": "1",
"uiDisablePageswitch": "1",
"uiAutoReturnAfter": 30000,
"featureKeys": "0",
"uiEncoderSpeed": 1,
"uiKeyBouncetime": 10,
"uiKeyFirstRepeat": 500,
"uiKeyReduceRepeat": 50,
"uiKeyMinRepeat": 50,
"featureBeeper": "1",
"uiPresetBedTempPLA": 60,
"uiPresetBedABS": 110,
"uiPresetExtruderPLA": 190,
"uiPresetExtruderABS": 240,
"uiMinHeatedBed": 30,
"uiMaxHeatedBed": 120,
"uiMinEtxruderTemp": 170,
"uiMaxExtruderTemp": 260,
"uiExtruderFeedrate": 2,
"maxBedTemperature": 120,
"bedSensorType": 1,
"bedSensorPin": "TEMP_1_PIN",
"bedHeatManager": 0,
"bedUpdateInterval": 5000,
"bedPidDriveMin": 80,
"bedPidDriveMax": 255,
"bedPidP": 196,
"bedPidI": 33,
"bedPidD": 290,
"bedPidMax": 255,
"caseLightPin": "ORIG_FAN2_PIN",
"caseLightDefaultOn": "1",
"bedSkipIfWithin": 3,
"gen1T0": 25,
"gen1R0": 100000,
"gen1Beta": 4036,
"gen1MinTemp": -20,
"gen1MaxTemp": 300,
"gen1R1": 0,
"gen1R2": 4700,
"gen2T0": 25,
"gen2R0": 100000,
"gen2Beta": 4036,
"gen2MinTemp": -20,
"gen2MaxTemp": 300,
"gen2R1": 0,
"gen2R2": 4700,
"gen3T0": 25,
"gen3R0": 100000,
"gen3Beta": 4036,
"gen3MinTemp": -20,
"gen3MaxTemp": 300,
"gen3R1": 0,
"gen3R2": 4700,
"userTable0": {
"r1": 0,
"r2": 4700,
"temps": [
"userTable1": {
"r1": 0,
"r2": 4700,
"temps": [
"userTable2": {
"r1": 0,
"r2": 4700,
"temps": [
"tempHysteresis": 0,
"pidControlRange": 20,
"skipM109Within": 2,
"extruderFanCoolTemp": 50,
"minTemp": 150,
"maxTemp": 275,
"minDefectTemp": -10,
"maxDefectTemp": 290,
"arcSupport": "1",
"forceChecksum": "0",
"sdExtendedDir": "1",
"featureFanControl": "1",
"fanPin": "ORIG_FAN_PIN",
"scalePidToMax": "1",
"zProbePin": -1,
"zProbeBedDistance": 10,
"zProbePullup": "0",
"zProbeOnHigh": "0",
"zProbeXOffset": 0,
"zProbeYOffset": 0,
"zProbeWaitBeforeTest": "0",
"zProbeSpeed": 2,
"zProbeXYSpeed": 150,
"zProbeHeight": 40,
"zProbeStartScript": "",
"zProbeFinishedScript": "",
"featureAutolevel": "1",
"zProbeX1": 20,
"zProbeY1": 20,
"zProbeX2": 160,
"zProbeY2": 20,
"zProbeX3": 100,
"zProbeY3": 160,
"zProbeSwitchingDistance": 1,
"zProbeRepetitions": 1,
"sdSupport": "1",
"sdCardDetectPin": "SDCARDDETECT",
"sdCardDetectInverted": "1",
"uiStartScreenDelay": 1000,
"xEndstopBackMove": 5,
"yEndstopBackMove": 5,
"zEndstopBackMove": 2,
"xEndstopRetestFactor": 3,
"yEndstopRetestFactor": 3,
"zEndstopRetestFactor": 3,
"xMinPin": "ORIG_X_MIN_PIN",
"yMinPin": "ORIG_Y_MIN_PIN",
"zMinPin": "ORIG_Z_MIN_PIN",
"xMaxPin": "ORIG_X_MAX_PIN",
"yMaxPin": "ORIG_Y_MAX_PIN",
"zMaxPin": "ORIG_Z_MAX_PIN",
"deltaHomeOnPower": "0",
"fanBoardPin": "ORIG_FAN2_PIN",
"heaterPWMSpeed": 0,
"featureBabystepping": "1",
"babystepMultiplicator": 1,
"hasMAX6675": false,
"hasMAX31855": false,
"hasGeneric1": false,
"hasGeneric2": false,
"hasGeneric3": false,
"hasUser0": false,
"hasUser1": false,
"hasUser2": false,
"numExtruder": 1,
"version": 91.7
#include "pins.h"
//for ADC KEYPAD
#define MAXTEMP 275
#if 0
#elif 0
#else
{4094,-55*8}}
#endif
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define Z_MIN_POS 0
// Delta settings
#define MAX_JERK 20
#define SDSUPPORT 1
#endif
#endif
"editMode": 2,
"processor": 0,
"baudrate": 115200,
"xStepsPerMM": 100,
"yStepsPerMM": 100,
"zStepsPerMM": 400,
"xInvert": 0,
"xInvertEnable": 0,
"eepromMode": 1,
"yInvert": 0,
"yInvertEnable": 0,
"zInvert": 0,
"zInvertEnable": 0,
"extruder": [
"id": 0,
"heatManager": 3,
"pidDriveMin": 40,
"pidDriveMax": 230,
"pidMax": 255,
"sensorType": 100,
"maxFeedrate": 50,
"invert": "0",
"watchPeriod": 1,
"pidP": 7,
"pidI": 2,
"pidD": 40,
"advanceK": 0,
"advanceL": 0,
"waitRetract": 0,
"stepsPerMM": 160,
"coolerPin": -1,
"coolerSpeed": 255,
"xOffset": 0,
"yOffset": 0,
"xOffsetSteps": 0,
"yOffsetSteps": 0,
"stepper": {
"uiLanguage": 0,
"uiController": 0,
"xMinEndstop": 1,
"yMinEndstop": 1,
"zMinEndstop": 1,
"xMaxEndstop": 1,
"yMaxEndstop": 1,
"zMaxEndstop": 1,
"motherboard": 701,
"driveSystem": 0,
"xMaxSpeed": 50,
"xHomingSpeed": 40,
"yMaxSpeed": 50,
"yHomingSpeed": 40,
"zMaxSpeed": 2,
"zHomingSpeed": 2,
"xMotor": {
"name": "X motor",
"yMotor": {
"name": "Y motor",
"zMotor": {
"name": "Z motor",
"backlashX": 0,
"backlashY": 0,
"backlashZ": 0,
"xMinPos": 0,
"yMinPos": 0,
"zMinPos": 0,
"xLength": 200,
"yLength": 200,
"zLength": 120,
"disableX": "0",
"disableY": "0",
"disableZ": "0",
"disableE": "0",
"xHomeDir": "-1",
"yHomeDir": "-1",
"zHomeDir": "-1",
"xEndstopBack": 1,
"yEndstopBack": 1,
"zEndstopBack": 0,
"deltaAlphaA": 210,
"deltaAlphaB": 330,
"deltaAlphaC": 90,
"maxJerk": 20,
"maxZJerk": 0.3,
"moveCacheLow": 10,
"sendWaits": "1",
"killMethod": 1,
"useAdvance": "0",
"mirrorX": 0,
"mirrorXMotor": {
"mirrorY": 0,
"mirrorYMotor": {
"mirrorZ": 0,
"mirrorZMotor": {
"servo0Pin": 11,
"servo1Pin": -1,
"servo2Pin": -1,
"servo3Pin": -1,
"uiAnimation": "1",
"featureKeys": "0",
"bedSensorType": 1,
"bedPidP": 196,
"bedPidI": 33,
"bedPidD": 290,
"bedPidMax": 255,
"gen1T0": 25,
"gen1R0": 100000,
"gen1Beta": 4036,
"gen1MinTemp": -20,
"gen1MaxTemp": 300,
"gen1R1": 0,
"gen1R2": 4700,
"gen2T0": 25,
"gen2R0": 100000,
"gen2Beta": 4036,
"gen2MinTemp": -20,
"gen2MaxTemp": 300,
"gen2R1": 0,
"gen2R2": 4700,
"gen3T0": 25,
"gen3R0": 100000,
"gen3Beta": 4036,
"gen3MinTemp": -20,
"gen3MaxTemp": 300,
"gen3R1": 0,
"gen3R2": 4700,
"userTable0": {
"r1": 0,
"r2": 4700,
"temps": [
"userTable1": {
"r1": 0,
"r2": 4700,
"temps": [
"userTable2": {
"r1": 0,
"r2": 4700,
"temps": [
"minTemp": 150,
"maxTemp": 275,
"arcSupport": "1",
"zProbePin": -1,
"zProbeXOffset": 0,
"zProbeYOffset": 0,
"zProbeSpeed": 2,
"zProbeHeight": 40,
"zProbeX1": 20,
"zProbeY1": 20,
"zProbeX2": 160,
"zProbeY2": 20,
"zProbeX3": 100,
"zProbeY3": 160,
"sdSupport": "1",
"hasUser0": false,
"hasUser1": false,
"hasUser2": false,
"numExtruder": 1,
"version": 91.7
#undef MACRONAME
before each #define MACRONAME to remove the old definition without warning.
