Anet ET4
I have an Anet ET4 printer. When using Repetier, I can connect to the printer, but when I go to print nothing happens.  Anyone else having similar problems?  Suggestions?
  • Enable export mode so you have a log and see if you are really communicating. See also in status bar at bottom for x commands waiting message. If you see it there is a good chance that there is no communication. Typically wrong baud rate or port. In some cases RTS/DTR bust be high/low or low/high instead of default.
